Xenon
Old 09-29-16, 06:50 PM
Jgamboa91
Jgamboa91's Avatar
Default Xenon
Hi. I have a 98 gs400 with xenon auto leveling headlights. But the tabs on the right headlight are broken. I have a set of regular halogen headlights. Can I dismount both lights & assemble the xenon on the regular housing headlight since the tabs on that one are good. Thanks
Old 09-29-16, 07:23 PM
jspecvtec
jspecvtec's Avatar
Wrong section plus u need to ask the GS guys in that group
Old 09-29-16, 07:49 PM
Jgamboa91
Jgamboa91's Avatar
Default Xenon
Old 09-29-16, 08:18 PM
Tank
Tank's Avatar
Nah, regular Xenon housings don't have the slots for the auto-level actuator motors.
Old 09-29-16, 09:29 PM
Mr Jokster
Mr Jokster's Avatar
Actually yes you can do what you are asking. Its going to take some precision though. If you look closely at the halogen lights and put them side by side with the HID lights, you'll see tabs that can be "punched" out to match the extra accessories that the HID housings have, even the for the ballasts. Both housings are exactly the same, just the HID's have the extra little 'thingamajigs' for the added 'thingies'
So yea, if you have them side by side, look for the differences. Then look closely at the halogen housing where its different, you'll see the markings in the shape of the added 'holes' for the accessories such as the auto-leveling motors and the ballasts. I did this exact thing for my headlamps, I just cant remember how I did it and the details, but it is possible. I cant remember though if it was easy to punch out, or if I had to use a Dremel tool to cut it out. I vaguely remember using a small file for the sharp corners of the tabs I had to punch out.
If you're a hands on type of guy, you should be able to figure it all out once you see them side by side... The biggest difference though is for the actual bulbs, dont forget to cut the tabs for the 'backing' cover for the HID's
Good luck, keep us posted on your progress
Old 09-29-16, 09:34 PM
Mr Jokster
Mr Jokster's Avatar
Crap, I just remembered! Theres a LOT more to this than you're thinking. Yes this all can be done, however, the reflector bowls are COMPLETELY different!!! Unless you plan on pulling them completely apart, dont do it PLEASE! FOR THE LOVE OF GOD DONT!!! LoL
The halogen bowls have a different reflector bowl than the HID's, so if you put HID's in the halogen bowl, you will be that A-hole that blinds everyone with illegal HID's in a halogen housing. The HID bowls have a natural cutoff that the halogens dont. If you put them side by side, you will see a significant difference on how the pattern looks on the 2 bowls. When I did this 'conversion', I did it because I did a retro-fit, so it didnt matter.
My suggestion, if you want to do all the work... Do what I mentioned above, but open BOTH housings up and swap all the guts. I have a write up on the retro-fit I did that explains how to disassemble them if you want to look it up. The whole process (once removed from the vehicle) should only take about 2 hours.
I say do it!
Old 09-30-16, 02:24 PM
Tank
Tank's Avatar
..lol Good luck!
Might be easier just to source a good replacement housing. You will be pissed if those beam cut offs don't look right...that is if you care about that stuff.
Old 09-30-16, 07:29 PM
speedkar9
speedkar9's Avatar
Cut the tabs off the halogen housing and JB Weld them onto the HID one
Old 10-01-16, 09:20 AM
Tank
Tank's Avatar
Nah, JB won't hold there. I've tried. perhaps he might have better luck..
Old 10-03-16, 10:33 AM
Tank
Tank's Avatar
You could try and plastic 'weld' the old piece on there with a low voltage sodering iron.
AlliCoops
Lighting
12-18-18 06:23 AM
NickTomsyc
08-12-12 12:33 AM
Sykotic336
07-27-12 07:49 PM
Stevoe88
04-26-11 02:11 PM
scooter58
Lighting
03-13-08 05:08 PM
Quick Reply: Xenon
