Lock/Unlock speaker beep suddenly very quiet - 2000 LS -
Old 09-27-16, 09:19 PM
bornking
bornking's Avatar
Default Lock/Unlock speaker beep suddenly very quiet - 2000 LS -
As the title says:
2000 LS400 w 199,000 km on her.
Runs clean and smooth as a whistle, sharp as a thistle.
This morning, for the first time, the beep the car makes when locking or unlocking with the key FOB (and the continuous tone when opening the door with the key still in the ignition) is suddenly almost inaudible.
Thoughts?
BNastee (02-15-24)
Old 09-29-16, 04:58 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
There's a small button far under the dash roughly in line with the steering wheel on the driver's side that mutes the lock/unlock beep.
Old 09-30-16, 07:03 AM
bornking
bornking's Avatar
found th ebutton. it was on..turned it off. no beep (as expected) turned back on, seems better now. Will check back in after a few hours
BNastee (03-23-22)
Old 09-30-16, 10:22 AM
wolfy53
wolfy53's Avatar
So I can get rid of that beep noise?! I may have to find this hidden button.
Old 09-30-16, 07:18 PM
bornking
bornking's Avatar
ok it wasn't the button, damn...what else can it be? It beeps but it's almost inaudible
Old 10-01-16, 12:16 AM
Yamae
Yamae's Avatar
There is a non volatile memory in the MPX network body computer and it is holding the beep sound level and others. As long as the memory and the system are working right, the beep sound level should not be changed. Below is the way to change the sound level using the remote key commander for a JDM Celsior 98-00. I don't know it's effective for a USDM but may be the same.
1, Press UNLOCK button for about 5 seconds until you can hear the beep twice and then release the button.
2, The 1st beep should lasts only 0.13 second and the 2nd beep 0.5 seconds. These tell you that the car is in the phase of sound level adjustment mode.
3, Press UNLOCK button once and you can hear the beep for 0.13 second.
4, Every time you press it, the sound level goes up and after reaching the MAX, it drops.
Does this work for your car?
BNastee (03-23-22)
Old 10-01-16, 01:10 AM
PureDrifter
BahHumBug
first off the door chime is completely independent from the alarm answer back. What happens when you trigger the alarm panic?
it's possible that the siren has gone bad, or the wiring between the siren and the MPX has been compromised. Or an array of other things that I would want to check prior to blaming the MPX system off the bat. But as theMPX is relatively easy to diagnose with Yamae's procedures it's quick to be ruled in or out.
Old 10-03-16, 12:07 PM
bornking
bornking's Avatar
I will follow Yamae's instructions today and let you know!
Thank you!
Old 10-04-16, 03:02 PM
bornking
bornking's Avatar
update:
Alarm works fine
Tried Yamae's instructions...but pressing and holding unlock just opens my windows and sunroof.
beep still almost inaudible
Could it be the ECU?
Old 10-04-16, 04:28 PM
Yamae
Yamae's Avatar
Sorry that I forgot to inform you one important condition while doing it. The driver's door should be opened.
BNastee (03-23-22)
Old 10-04-16, 07:26 PM
bornking
bornking's Avatar
cool I will try it!!!
Old 03-14-19, 04:21 PM
winowally
winowally's Avatar
Thank You! I found the button, and have my door lock/unlock sounds back.
Old 03-17-22, 08:08 AM
ncdiolosa
ncdiolosa's Avatar
Unhappy
Did you ever figure it out? Mine has just started to get quieter and its upsetting because I love the beep. Also I'm today years old finding out that holding the button rolls down all windows and sunroof hahaha. But anyways please let me know if you solved the issue.
Old 03-21-22, 01:16 PM
bornking
bornking's Avatar
Seems to be related to weather. I am in Canada. When it is COLD, the sound is muffled. When it is Warm, it is back to normal... Strange?
Old 03-22-22, 08:40 AM
ncdiolosa
ncdiolosa's Avatar
that definitely IS strange, but come to find out mine wasn't working because when I washed my car, I guess it somehow got filled up with water. Poured the water out and she's back to normal beeping hahahaha
Quick Reply: Lock/Unlock speaker beep suddenly very quiet - 2000 LS -
