Longevity of the 460
Good day LS460 owners!
I don't normally post in this section, but I came across something I had to share. I frequent the Manheim Auction site for dealers and I always am looking for something I can turn and make a few dollars on. I usually focus on cheaper cars that don't need a lot of work, but as a proud Lexus owner, I always peruse the Lexus listings to see what's out there.
So, low and behold there's a 2008 LS460 listed with.... 280,000 miles on the clock! Unfortunately there were no pictures of the car in the auction listing.
That's a lotta driving. The car was maintained at Bergstrom Lexus in Appleton Wi. and had quite a lot done to it. If you're really bored, you can plug in the VIN on the owner's site and read through all the maintenance history.
JTHBL46F385081608
It gives a good sense of what may need attention at what mileage. Whoever owned the car, took it to the dealer very regularly.
It'll be interesting to see what it sells for tomorrow.
JTHBL46F385081608
Thanks for sharing that info. It is very helpful on knowing what could go wrong or needs service as time/miles progress. I essentially do the same thing with ES forum as my ES is at 270k. Fortunately I don't have post often there with repair info as its a rock solid car ..........
Wow, well maintained car with such a detailed service history. I currently am in 2014 service history and long way to go to finish with zero miles!. This is the kind of info I have been looking for on LS. I prefer to own vehicles 10+ years. But have doubts about LS when it comes to 150k+ miles. This car gives enough confidence in me ...........
Just wondering if there is a way to know what type miles were put on the car. If someone spent years of highway driving, generally it's less harm than years of stop start, start stop . . . I personally couldn't pull the trigger on a car with that kind of mileage, but that's just me. A flip is a flip if it makes good dollar sense.
Blindsided (05-04-18)
Here's the complete service history from drivers.lexus.com, minus some boilerplate text.
SERVICE HISTORY FOR: 280K
VIN: JTHBL46F385081608
Filter History by Year
274226 miles
DATE: 08/04/2016
Repair# 0054845
reported by: Bergstrom Lexus
Service: DEFAULT
description: DEFAULT |TIRE ROTATION | |1 30 PERFORMED TIRE ROTATION, CHECK AIR PRESSURES AND TIRE CONDITION FRONT BRAKES HAVE 4MM REMAINING* REAR BRAKES HAVE 5MM REMAINING* TIRES HAVE 5/32NDS OF
TREAD DEPTH REMAINING* ENGINE BATTERY PASSED A LOAD TEST* * RECOMMENDED MAINTENANCE: TRANSMISSION FDEFAULT | |
Service: LOF- CHANGE ENGINE OIL AND FILTER
description: LOF- CHANGE ENGINE OIL AND FILTER |LOF--SYNTHETIC OIL CHANGE | |1 40 PERFORMED LUBE, OIL AND FILTER CHANG, CHECK AND TOP OFF ALL FLUIDS. CHECK / ADJUST TIRE PRESSURES AS NEEDED AND
VISUALLY INSPECT TIRES FOR WEAR AND DAMAGE.
268770 miles
DATE: 06/30/2016
Repair# 0053887
Service: AIR FILTER
description: AIR FILTER |BOTH ENGINE AIR FILTERS ARE DIRTY |
Service: BATTERY REPLACE
description: BATTERY REPLACE |THE ENGINE BATTERY HAS A POOR STATE OF HEALTH RELATIVE TO A NEW BATTERY |BATTERY REPLACEMENT, CHARGING SYSTEM TEST, INITIALIZE VEHICLE SYSTEMS.
Service: CABIN AIR FILTER
description: CABIN AIR FILTER |INTERIOR CABIN AIR FITLER IS DIRTY | |268769 REMOVE OLD CABIN FILTER, INSPECT HOUSING, REMOVED DEBRIS AND INSTALL NEW CABIN FILTER
description: LOF- CHANGE ENGINE OIL AND FILTER |LOF- CHANGE ENGINE OIL AND FILTER | |268769 PERFORMED OIL AND FILTER CHANGE, CHECK AND TOP OFF ALL FLUIDS. CHECK / ADJUST TIRE PRESSURES AS NEEDED
AND VISUALLY INSPECT TIRES FOR WEAR AND DAMAGE. * RECOMMENDED MAINTENANCE: TRANSMISSION FLUID REPLACEMENT IS $289.99* SPARK PLUG REPLACEMENT WITH
Service: TIRE ROTATION
description: TIRE ROTATION |TIRE ROTATION |
263353 miles
DATE: 05/18/2016
Repair# 0052696
Service:
description: | |
description: LOF- CHANGE ENGINE OIL AND FILTER |LOF- CHANGE ENGINE OIL AND FILTER | |1 PERFORMED LUBE, OIL AND FILTER CHANGE, CHECK AND TOP OFF ALL FLUIDS. CHECK / ADJUST TIRE PRESSURES AS
NEEDED AND VISUALLY INSPECT TIRES FOR WEAR AND DAMAGE.
description: TIRE ROTATION |TIRE ROTATION | |1 PERFORMED TIRE ROTATION, CHECK AIR PRESSURES AND TIRE CONDITION FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 10MM REMAINING* TIRES MEASURE
7/32NDS OF TREAD DEPTH REMAINING*
258008 miles
DATE: 04/08/2016
Repair# 0051564
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 5K MAINTENANCE INTERVAL COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. INSPECT AND MEASURE BRAKE PADS, CHECK
CALIPERS AND SLIDES FOR PROPER MOVEMENT, ROTATED TIRES AS NEEDED AND SET TIRE PRESSURES. TIRE TREAD 8/32 FRODEFAULT | |
252277 miles
DATE: 02/25/2016
Repair# 0050531
Service: DEFAULT
description: DEFAULT |LOF--SYNTHETIC OIL CHANGE | |1 PERFORMED LUBE, OIL AND FILTER CHANGE, CHECK AND TOP OFF ALL FLUIDS. CHECK / ADJUST TIRE PRESSURES AS NEEDED AND VISUALLY INSPECT TIRES FOR
WEAR AND DAMAGE. FRONT AND REAR BRAKES HAVE 11MM REMAINING* SUMMER TIRES HAVE 8/32NDS OF TREAD DEPTH REMAINING* *DEFAULT |MOUNT AND BALANCE THE SUMMER TIRES | |1 MOUNTED AND BALANCED SUMMER
TIRES DISCARDED WINTER TIRES FOR A NEW SET TO BE MOUNTED IN THE FALL OF 2016DEFAULT | |
249365 miles
DATE: 01/28/2016
Repair# 0049827
Service: DEFAULT
description: DEFAULT |GUEST WAS ON FREEWAY TRAVELING HOME TONIGHT WITH CRUISE CONTROL ON. POWER LOST/FELT CHECK ENGINE LIGHT APPEARED ALONG WITH VSC LIGHTS. |P0171 BANK 1 SYSTEM TOO LEAN,
RECOMMEND REPLACE BANK 1 A/F SENSOR DUE TO CONFIRMED DURING A/F SWEEP, ONLY .4 VOLTS OF OPERATING RANGE DURING TEST. 5.0 HRS 1X SENSOR REMOVAL AND REPLACEMENT. |1 REPLACED BANK 1 A/F SENSOR. THE
PART REMOVED SUCCESSFULLY WITHOUT REQUIRING THE REPLACEMENT OF THE BANK 1 MANIFOLD... CLEARED FAULT CODES RE-TESTED A/F SWEEP NOW HAS AN OPERATING RANGE OF 2.5-3.7 VOLTS. AND THE EMISSIONS
SYSTEM IS OPERATING CORRECTLY ASDEFAULT | |
247062 miles
DATE: 01/08/2016
Repair# 0049407
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |247061 100 5K MAINTENANCE INTERVAL COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. INSPECT AND MEASURE BRAKE PADS,
CHECK CALIPERS AND SLIDES FOR PROPER MOVEMENT, ROTATED TIRES AS NEEDED AND SET TIRE PRESSURES. TIRE TREADDEFAULT | |
1 miles
DATE: 11/24/2015
Repair# 0048034
Service: TIRE DAMAGED AND HAD TO BE TOWED IN AND REPAIRED
description: TIRE DAMAGED AND HAD TO BE TOWED IN AND REPAIRED |TOW-IN VEHICLE |
241052 miles
DATE: 11/13/2015
Repair# 0048007
Service: DEFAULT
description: DEFAULT |LOF--STANDARD | |241051 40 REPLACED ENGINE OIL AND FILTER* FRONT BRAKES HAVE 9MM REMAINING* REAR BRAKE HAVE 9MM REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE COOLANT
IS GOOD THRU -32 DEGREES*DEFAULT |TIRE SWAP--WINTER/SUMMER TIRES | |241051 180 SWAPPED SUMMER TIRES FOR SNOW TIRES. SNOW TIRES HAVE 6/32 REMAINING. SUMMER TIRES HAVE 8/32 AND ARE LABELED AND
STORED FOR SEASONDEFAULT | |
235993 miles
DATE: 09/30/2015
Repair# 0046807
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |235991 100 5K MAINTENANCE INTERVAL COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. INSPECT AND MEASURE BRAKE PADS,
230180 miles
DATE: 08/18/2015
Repair# 0045591
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE |DEFAULT | |
224259 miles
DATE: 07/06/2015
Repair# 0044130
Service: DEFAULT
description: DEFAULT | |RADIATOR
Service: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H
description: ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H |ELF-REPL FUEL PRESSURE GASKE T-IS F,GS460,LS460,LS600H |FUEL PRESSURE SENSOR GASKET PER SSC ELF |224257 410 PERFORMED RECALL
FOR FUEL PRESSURE SENSOR GASKET REPLACEMENT
Service: MOVED TO: 44130C LINE: A
description: MOVED TO: 44130C LINE: A |MOVED TO: 44130C LINE: A |
Service: MOVED TO: 44130C LINE: B
description: MOVED TO: 44130C LINE: B |MOVED TO: 44130C LINE: B |
Service: MOVED TO: 44130C LINE: C
description: MOVED TO: 44130C LINE: C |MOVED TO: 44130C LINE: C |
Service: MOVED TO: 44130C LINE: D
description: MOVED TO: 44130C LINE: D |MOVED TO: 44130C LINE: D |
Service: MOVED TO: 44130C LINE: E
description: MOVED TO: 44130C LINE: E |MOVED TO: 44130C LINE: E |
Service: MOVED TO: 44130C LINE: F
description: MOVED TO: 44130C LINE: F |MOVED TO: 44130C LINE: F |
Service: MOVED TO: 44130C LINE: G
description: MOVED TO: 44130C LINE: G |MOVED TO: 44130C LINE: G |
224259 miles
DATE: 07/02/2015
Repair# 044130C
Service: 5,000 MILE SERVICE
description: 5,000 MILE SERVICE |5,000 MILE SERVICE | |224257 100 5K MAINTENANCE INTERVAL COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. INSPECT AND MEASURE
BRAKE PADS, CHECK CALIPERS AND SLIDES FOR PROPER MOVEMENT, ROTATED TIRES AS NEEDED AND SET TIRE PRESSURES. TIRE TREAD
Service: BULB REPLACEMENT--EXTERIOR
description: BULB REPLACEMENT--EXTERIOR |THE PASSENGER SIDE FRONT MARKER LIGHT/RUNNING LIGHT BULB IS OUT | |224257 50 REPLACED PASSENGER SIDE MARKER BULB
Service: DEFAULT
description: DEFAULT |REAR DIFFERENTIAL GEAR LUBE SUGGESTED TO BE REPLACED EVERY 60,000 MILES | |224257 30 REPLACED REAR DIFFERENTIAL GEAR LUBE FLUIDDEFAULT |LOANER VEHICLE |
Service: FRONT BRAKE REPAIR
description: FRONT BRAKE REPAIR |C/S: SHIMMY IN FRONT WHEN APPLYING THE BRAKE | |224257 200 PERFORMED FRONT BRAKE SERVICE, REMOVE OLD BRAKE PADS, CLEAN CALIPER SLIDE SURFACE, MEASURE THE ROTORS
FOR CORRECT THICKNESS, REPLACE ROTORS, REPLACE BRAKE PADS AND ROAD TEST.
Service: RADIATOR ASSEMBLY
description: RADIATOR ASSEMBLY |RADIATOR ASSEMBLY |
Service: REAR BRAKE REPAIR
description: REAR BRAKE REPAIR |REAR BRAKE PADS WITH ROTORS | |224257 REPLACED THE REAR BRAKE PADS, REPLACED THE REAR BRAKE ROTORS, LUBRICATED THE CALIPER SLIDE BOLTS AND THE BRAKE PAD SHIMS AND
RETENTION CLIPS*
218496 miles
DATE: 05/08/2015
Repair# 0042562
Service: DEFAULT
description: DEFAULT |ALIGNMENT-(4) WHEEL *SHIMS ADDITIONAL |THE DRIVER SIDE FRONT AND THE PASSNGER SIDE REAR TOE ADJUSTMENTS ARE THE FURTHEST OUT AND NECESSARY TO BE CORRECTED TO GET THE
ALIGMENT WITHIN THE MINIMUM AND MAXIMUM SPECIFICATIONS |218496 150 PERFORMED FOUR WHEEL ALIGNMENT, ADJUST CASTER, CAMBER AND TOE TO THE MANUFACTURER SPECIFICATION TO PROLONG LIFE OF TIRESDEFAULT
|LOF--STANDARD | |218496 40 PERFORMED LUBE, OIL AND FILTER CHANG, CHECK AND TOP OFF ALL FLUIDS. CHECK / ADJUST TIRE PRESSURES AS NEEDED AND VISUALLY INSPECT TIRES FOR WEAR AND DAMAGE.DEFAULT | |
Service: TIRE--MOUNT & BALANCE (4) LOW PROFILE
description: TIRE--MOUNT & BALANCE (4) LOW PROFILE |BRIDEGESTONE TURANZA SERENTIY | |218496 180 DISMOUNT TIRES, CHECK WHEELS FOR DAMAGE, MOUNT AND HIGH SPEED COMPUTER BALANCE TIRES. SET AIR
PRESSURES TO THE CORRECT PSI. SUMMER TIRES ARE NEW TODAY AND ARE AT 10/32 AND SNOW TIRES HAVE 6-7/32 OF TREAD DEPTH REMAINING. SNOW TIRES ARE LABELED
213246 miles
DATE: 03/09/2015
Repair# 0040892
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |213246 5K MAINTENANCE INTERVAL COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. INSPECT AND MEASURE BRAKE PADS,
CHECK CALIPERS AND SLIDES FOR PROPER MOVEMENT, ROTATED TIRES AS NEEDED AND SET TIRE PRESSURES. TIRE TREAD 8/3DEFAULT | |
207865 miles
DATE: 01/30/2015
Repair# 0040052
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 8MM REMAINING* REAR BRAKES HAVE 7MM REMAINING* TIRES HAVE 7/32NDS OF TREAD DEPTH
REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE COOLANT IS GOOD THRU -35 DEGREES* RECOMMENDED MAINTENADEFAULT | |
202399 miles
DATE: 12/19/2014
Repair# 0038997
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |202000 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 8MM REMAINING* REAR BRAKES HAVE 7MM REMAINING* TIRES HAVE 7/32NDS OF TREAD
DEPTH REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE COOLANT IS GOOD THRU -32 DEGREES*DEFAULT |CABIN AIR FILTER |DEFAULT |INSPECT DRIVERS FLOOR MAT FOR PROPER MANUFACTURER INSTALLATION. |
196896 miles
DATE: 11/11/2014
Repair# 0037953
Service: DEFAULT
description: DEFAULT |LOF--STANDARD | |1 REPLACED ENGINE OIL AND FILTER* FRONT AND REAR BRAKES HAVE 4MM REMAINING UNTIL THE BRAKE PAD WEAR SENSOR* ENGINE BATTERY PASSED A LOAD TEST* ENGINE
COOLANT IS GOOD THRU -33 DEGREES*DEFAULT |TIRE SWAP--WINTER/SUMMER TIRES | |1 MOUNTED AND BALANCED THE SNOW TIRES WHICH MEASURE 7-8/32NDS OF TREAD DEPTH REMAINING* SUMMER TIRES HAVE 5/32NDS OF
TREAD DEPTH REMAINING OR LESS AND SEAM OKAY'D TO DISCARD TO MOUNT NEW TIRES IN THE SPRING*
Service: REAR BRAKES ROTORS HAVE SLIGHT WARPAGE ALLOWING FOR VIBRATION FELT
description: REAR BRAKES ROTORS HAVE SLIGHT WARPAGE ALLOWING FOR VIBRATION FELT |VSLIGHT VIBRATION FELT THROUGHOUT THE VEHICLE AT HGIHWAY SPEEDS WHEN THE BRAKE PEDAL IS APPLIED |SUGGESTED TO
RE-SURFACE THE REAR BRAKE ROTORS TO BEGIN WITH DUE TO NO VIBRATION FELT IN THE STEERING WHEEL WHEN THE BRAKE PEDAL IS APPLIED |1 RE-SURFACED THE REAR BRAKE ROTORS, TEST DROVE AND THE VIBRATION
WAS DIMINISHED YET NOT GONE ENTIRELY, THE FRONT BRAKE ROTORS WILL BE SUGGESTED TO BE RE-SURFACED*
191696 miles
DATE: 10/09/2014
Repair# 0037026
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 4MM REMAINING* REAR BRAKES HAVE 3MM REMAINING* TIRES HAVE 5/32NDS OF TREAD DEPTH
REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE COOLANT IS GOOD THRU -33 DEGREES*DEFAULT | |
185627 miles
DATE: 08/29/2014
Repair# 0035859
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 4MM REMAINING* REAR BRAKES HAVE 3MM REMAINING* ENGINE BATTERY PASSED A LOAD TEST*
180067 miles
DATE: 07/23/2014
Repair# 0034737
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |180067 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES AND MEASURED THE BRAKES* FRONT BRAKES HAVE 9MM REMAINING* REAR BRAKES HAVE 7-8MM REMAINING* TIRES
HAVE 6-7/32NDS OF TREAD DEPTH REMAINING* ENGINE BATTERY PASSED A LOAD TEST*DEFAULT | |
174881 miles
DATE: 06/18/2014
Repair# 0033638
description: 5,000 MILE SERVICE |5,000 MILE SERVICE | |174876 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 9MM REMAINING* REAR BRAKES HAVE 7MM REMAINING* TIRES HAVE 6/32NDS
Service: AIR FILTER
description: AIR FILTER |AIR FILTERS FOR ENGINE IS DIRTY | |174876 REPLACED BOTH ENGINE AIR FILTERS
description: CABIN AIR FILTER |CABIN AIR FILTER IS DIRTY SUGGESTED TO BE REPLACED | |174876 REPLACED THE INTERIOR CABIN AIR FILTER AND CLEANED THE BLOWER MOTOR*
Service: DEFAULT
description: DEFAULT |C/S: DIAGCEL* |SCANNED FOR CODES AND FOUND EMISSION MALFUNCTION DETECTED |174876 REPLACED BANK 2 A/F SENSOR, CLEARED THE DIAGNOSTIC TROUBLE CODES AND TEST DROVE, THE
VEHICLE WAS OPERATING CORRECTLY AS DESIGNED WITHOUT THE RETURN OF ANY MALFUNCTION INDICATOR LIGHTSDEFAULT |OIL LEAK FOUND OCCURRING FROM THE HIGH PREESURE FUEL PUMP | |174876 REPLACED BOTH
GASKETS FOR THE HIGH PRESSURE FUEL PUMP WHERE OIL WAS FOUND LEAKING FROMDEFAULT | |
Service: GUEST REQUESTS COMPLETE VEHICLE DETAIL
description: GUEST REQUESTS COMPLETE VEHICLE DETAIL |GUEST REQUESTS COMPLETE VEHICLE DETAIL |
172523 miles
DATE: 06/02/2014
Repair# 0033189
Service: DEFAULT
description: DEFAULT |THE CHECK ENGINE LIGHT AND THE VSC LIGHT WAS ON |SCANNED FOR CODES AND FOUND DIAGNOSTIC TOUBLE CODE PO174 STORED FOR SYSTEM RUNING LEAN |172523 WHEN INSPECTED, ALL
COMPONENTS WERE OPERATING CORRECTLY AS DESIGNED*
Service: GENERIC CONCERN
description: GENERIC CONCERN |THE CRUISE CONTROL WAS INOPERATIVE WHILE THE LIGHTS WERE ON |
168340 miles
DATE: 05/02/2014
Repair# 0032301
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |168339 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 9MM REMAINING* REAR BRAKES HAVE 8MM REMAINING* TIRES HAVE 7/32NDS OF TREAD
description: GENERIC CONCERN |AQUAPEL | |168339 INSTALLED AQUAPEL*
Service: WIPER BLADE INSERTS
description: WIPER BLADE INSERTS |WIPER BLADE INSERTS | |168339 REPLACED BOTH WIPER BLADE INSERTS
163080 miles
DATE: 03/25/2014
Repair# 0031226
Service: 2
description: 2 | | |163080 GUEST REQUESTED NEW SET OF CARPET FLOORMATS BE ORDERED IN TAN COLOR*
Service: DEFAULT
description: DEFAULT |VALET SERVICE |DEFAULT |C/S: WORLDS STANDARD FLUID CHANGE PROCEDURE* | |1 PERFORMED WORLDS STANDARD TRANSMISSION FLUID CHANGE PROCEDURE*DEFAULT |TIRE SWAP--WINTER/SUMMER
TIRES | |1 MOUNTED AND BALANCED GUEST SUMMER TIRES WHICH HAVE 8/32NDS OF TREAD DEPTH REMAINING* WINTER TIRES HAVE 7/32NDS OF TREAD DEPTH REMAINING*
Service: FLUSH BRAKE FLUID
description: FLUSH BRAKE FLUID |BRAKE FLUID FLUSH SUGGESTED EVERY 30,000 MILES | |1 FLUSHED THE BRAKE FLUID AND FILLED THE RESERVOIR*
Service: GUEST REQESTS REAR DIFFERENTIAL SERVICE
description: GUEST REQESTS REAR DIFFERENTIAL SERVICE |REAR DIFFERENTIAL SERVICE SUGGESTED TO BE COMPLETED | |1 REPLACED THE REAR DIFFERENTIAL GEAR LUBE*
Service: LOF--SYNTHETIC OIL CHANGE
description: LOF--SYNTHETIC OIL CHANGE |LOF--SYNTHETIC OIL CHANGE | |1 REPLACED ENGINE OIL AND FILTER* FRONT BRAKES HAVE 5MM REMAINING UNTIL THE BRAKE WEAR SENSOR* REAR BRAKES HAVE 5MM REMAINING
UNTIL THE BRAKE WEAR SENSOR* ENGINE BATTERY PASSED A LOAD TEST*
Service: RECOMMENDED REPAIRS
description: RECOMMENDED REPAIRS |DRIVE BELT TO BE REPLACED DRIVE BELT IS ORIGINAL | |1 REPLACED ENGINE DRIVE BELT (V-BELT)
Service: SPARK PLUG REPLACEMENT
description: SPARK PLUG REPLACEMENT |SPARK PLUG REPLACMENT WITH A TUNE UP | |1 CLEANED THE INTAKE AND THROTTLE BODY AND REPLACED ALL (8) SPARK PLUGS*
156758 miles
DATE: 02/04/2014
Repair# 0030062
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 5MM REMAINING* REAR BRAKES HAVE 5MM REMAINING* TIRES HAVE 8/32NDS OF TREAD DEPTH
REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE COOLANT IS GOOD THRU -33 DEGREES* RECOMMENDED MAINTENA
Service:
description: | |
151578 miles
DATE: 12/11/2013
Repair# 0028811
Service: DEFAULT
description: DEFAULT |TIRE SWAP--WINTER/SUMMER TIRES | |1 MOUNTED AND BALANCED WINTER TIRES WHICH HAVE 8/32NDS OF TREAD DEPTH REMAINING OR MORE* SUMMER TIRES HAVE BEEN STORED AND HAVE 8/32NDS OF
Service: LOF--STANDARD
description: LOF--STANDARD |LOF--STANDARD | |1 REPLACED ENGINE OIL AND FILTER* FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 10MM REMAINING* ENGINE BATTERY PASSED A LOAD TEST* ENGINE
145976 miles
DATE: 11/01/2013
Repair# 0027822
Service: DEFAULT
description: DEFAULT |LOF--STANDARD | |1 REPLACED ENGINE OIL AND FILTER* FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 10MM REMAINING* TIRES HAVE 9/32NDS OF TREAD DEPTH REMAINING AND
INFLATED TO 35PSI WARM* ENGINE BATTERY PASSED A LOAD TEST WHEN TESTED TODAY*
Service:
description: |
142408 miles
DATE: 10/15/2013
Repair# 0027328
Service: TIRE REPAIR (1)
description: TIRE REPAIR (1) |C/S: THE DRIVER SIDE REAR TIRE WAS DOWN TO 26PSI*INLFATED TO 36PSI AND THEN DROPPED AGAIN. INSPECT TIRE AND DETERMINE WHERE THE LEAK IS EXISITNG FROM* |THE DRIVER
SIDE REAR TIRE HAD A NAIL IN IT |1 REMOVED THE NAIL AND PLUGGED THE TIRE*MONITORED THE TIRE AND THE TIRE IS HOLDING PRESSURE CORRECTLY AT THIS TIME*
140590 miles
DATE: 10/02/2013
Repair# 0026967
description: 5,000 MILE SERVICE |5,000 MILE SERVICE | |139000 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 10MM REMAINING* TIRES HAVE 9/32NDS
OF TREAD DEPTH REMAINING, TIRES INFLATED TO 35PSI* ENGINE BATTERY PASSED A LOAD TEST* COOLANT IS GOOD THRU -32 DEGR
134643 miles
DATE: 08/26/2013
Repair# 0026023
description: CABIN AIR FILTER |C/S: A/C FILTER LIGHT IS ON* | |134643 REPLACED THE INTERIOR CABIN AIR FILTER AND CLEANED THE BLOWER MOTOR BENEATH IT, RE-SET THE A/C FILTER REMINDER*
Service: DEFAULT
description: DEFAULT |10,000 MILE SERVICE | |134643 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 9MM REMAINING*TIRES HAVE 8/32NDS OF TREAD
DEPTH REMAINING AND HAVE BEEN INFLATED TO 35PSI WARM* ENGINE BATTERY PASSED A LOAD TEST WHEN TESTED TODAY*DEFAULT |C/S: LOW KEY FOB BATTERY IN KEYS* | |134643 REPLACED REMOTE FOB BATTERY*
139051 miles
DATE: 07/30/2013
Repair# 0025243
description: GENERIC CONCERN |RATTLE COMING FROM THE DRIVER SIDE FRONT OF THE VEHICLE |VERIFIED NOSIE ABS ACTUATOR IS CONTACTING THE DRIVER SIDE FIREWALL AREA IN THE ENGINE AND CONTINUALLY
RATTLING |1 REPOSITIONED AND TEST DROVE THE VEHICLE AND NO NOISE HEARD WHEN TEST DRIVEN*
description: RECOMMENDED REPAIRS |DOOR DENT TO BE REMOVED FROM DENT DOCTOR | |1 TOUCHED UP PAINT CHIP ON THE DRIVER SIDE DOOR EDGE*
128498 miles
DATE: 07/11/2013
Repair# 0024762
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 8-9MM REMAINING* REAR BRAKES HAVE 8-9MM REMAINING* TIRES HAVE 9/32NDS OF TREAD
DEPTH REMAINING* ENGINE BATTERY PASSED A LOAD TEST*DEFAULT |C/S: GUEST STATES RATTLE NOISE IN DASH RETURNED. |VERIFIED NOISE FOUND THAT THE BRAKE ACTUATOR IS RUBBING AGAIANST THE FIREWALL TO THE
ENGINE AND MAKING A TAPPING/SQEAK METALLIC NOISE* |128497 FURTHER TIME NECESSARY TO REMOVE AND ADJUST AND POSSIBLE INSULATE THE SURROUNDING AREA* GUEST DECLINED REPAIR TODAY WHEN SHOWN WHAT WAS
FOUND*
122774 miles
DATE: 05/30/2013
Repair# 0023612
Service: DEFAULT
description: DEFAULT |5,000 MILE SERVICE | |1 REPLACED ENGINE OIL AND FILTER* ROTATED TIRES* FRONT BRAKES HAVE 10MM REMAINING* REAR BRAKES HAVE 10MM REMAINING* TIRES HAVE 8/32NDS OF TREAD DEPTH
REMAINING* ENGINE BATTERY PASSED A LOAD TEST*DEFAULT |C/S: CUSTOMER STATES THERE IS A RATTLE IN THE DASH ON CHOPPY ROADS, PLEASE CHECK AND ADVISE. |VERIFIED THE NOISE OVER A BUMP ON TEST DRIVE
AND COULD HEAR RATTLE NOIES FROM THE FRONT DASH AREA |1 INSTALLED INSULATION IN BETWEEN THE WINDSHIELD AND DASHBOARD AREA TO ""PAD"" THE CONTACT AREAS AND PREVENT ANY RATTLE FROM RETURNING* TEST
DROVE AND NO RATTLE COULD BE VERIFIED ANY LONGER*
116956 miles
DATE: 04/24/2013
Repair# 0022582
Service: DEFAULT
description: DEFAULT |LOF--STANDARD | |116956 CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. SET TIRE PRESSURES. TIRE TREAD /32 FRONT AND /32 REAR. VISUALLY INSPECT
BRAKES. BRAKE LININGS MM FRONT AND MM REAR REMAINING. RESET MAINTENANCE REMINDER.DEFAULT |C/S: GUEST STATES RATTLE IN DASH NEAR STEERING COLUMN. CHECK AND AD VISE. | |116956 ROAD TEST. UNABLE TO
DUPLICATE CONCERN AT THIS TIME.DEFAULT |CUSTOMER REQUESTED A LOANER
description: TIRE--MOUNT & BALANCE (4) |TIRE--MOUNT & BALANCE (4) | |116956 MOUNT AND BALANCED 4 NEW TIRES TO IMPROVE THE PERFORMANCE AND SAFETY OF YOUR LEXUS. * DOT #
111635 miles
DATE: 03/13/2013
Repair# 0021528
description: FRONT BRAKE REPAIR |FRONT BRAKE REPAIR BRAKE PADS HAVE 1-2MM REMAINING UNTIL THE BRAKE PAD WEAR SENSOR | |111633 REPLACED THE FRONT BRAKE PADS, RESURFACED THE FRONT BRAKE ROTORS,
LUBRICATED THE CALIPER SLIDE BOLTS AND THE BRAKE PAD SHIMS AND RETENTION CLIPS***
description: LOF--STANDARD |55,000 MILE SERVICE | |111633 REPLACED ENGINE OIL AND FILTER*ROTATED TIRES*FRONT BRAKES ARE NEW TODAY*REAR BRAKES ARE NEW TODAY*TIRES HAVE 10/32NDS OF TREAD DEPTH
REMAINING*ENGINE BATTERY PASSED A LOAD TEST*ENGINE COOLANT IS GOOD THRU -33 DEGREES*
description: REAR BRAKE REPAIR |REAR BRAKES HAVE 1-2MM REMAINING | |111633 REPLACED REAR BRAKE PADS, RESURFACED REAR BRAKE ROTORS, LUBRICATED THE CALIPER SLIDE BOLTS AND THE BRAKE PAD SHIMS AND
CLIPS*
109482 miles
DATE: 02/21/2013
Repair# 0021066
Service: DEFAULT
description: DEFAULT |C/S: THE CHECK ENGINE LIGHT, VSC, TRAC OFF LIGHTS ARE ALL ON, CAME ON WHILE THE GUEST WAS DRIVING YESTERDAY EVENING ON THEIR WAY HOME |SCANNED FOR CODES AND FOUND
DIAGNOSTIC TROUBLE CODE C0205 FOR A WHEEL SPEED CIRCUIT MALFUNCTION* TESTED ALL WHEEL SPEED SENSORS AND FOUND BRAEK IN THE SIGNAL FROM THE DRIVER SIDE FRONT WHEEL SPEED SENSOR. SUGGES TO REPLACE
THE SENSOR WIRE TO BEGINE WITH D |1 REPLACED THE DRIVER SIDE FRONT WHEEL SPEED SENSOR WIRING HARNESS*CLEARED THE MALFUNCTION INDICATOR LIGHTS AND TEST DROVE* THE VEHICLE WAS DRIVING AS DESIGNED
WITHOUT THE RETURN OF ANY MALFUNCTION INDICATORS*
106237 miles
DATE: 01/25/2013
Repair# 0020544
description: BATTERY REPLACE |BATTERY REPLACE | |106237 REPLACED BATTERY FOR OPTIMUM STARTING POWER.
Service: DEFAULT
description: DEFAULT |15,000 MILE SERVICE | |106237 105K MAINTENANCE COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED ENGINE OIL AND FILTER. ROTATED TIRES AND SET TIRE PRESSURES. TIRE
TREAD 10/32 FRONT AND 10/32 REAR. VISUALLY INSPECT BRAKES. BRAKE LININGS 4MM FRONT AND 4MM REAR REMAINING
description: WIPER BLADE INSERTS |WIPER BLADE INSERTS | |106237 REPLACED WIPER INSERTS SO YOU CAN SEE CLEARLY AND SAFELY OPERATE YOUR LEXUS IN ALL TYPES OF WEATHER CONDITIONS.
100776 miles
DATE: 12/18/2012
Repair# 0019584
Service: MOVED TO: 19584C LINE: A
description: MOVED TO: 19584C LINE: A |MOVED TO: 19584C LINE: A
Service: MOVED TO: 19584C LINE: B
description: MOVED TO: 19584C LINE: B |MOVED TO: 19584C LINE: B
Service: WATER PUMP ASSY &/OR GSKT
description: WATER PUMP ASSY &/OR GSKT |DIAGNOSIS FLUID LEAK |COOLANT LEAK FROM WATER PUMP SHAFT SEAL. |100776 REPLACED WATER PUMP. RECHECK FOR LEAKS. OK.
100776 miles
DATE: 12/14/2012
Repair# 019584C
Service: DEFAULT
description: DEFAULT |15,000 MILE SERVICE | |100776 100K MAINTENANCE COMPLETED. CHECK AND ADJUST FLUID LEVELS AS NEEDED. CHANGED OIL. ROTATED TIRES. INSPECT BRAKES. TIRE TREAD 12/32"". BRAKE
LININGS 6MM REMAINING.DEFAULT |COOLANT DRAIN AND FILL | |100776 DRAINED AND FILLED COOLANT SYSTEM WHEN REPLACING WATER PUMP.
94692 miles
DATE: 11/06/2012
Repair# 0018618
Service: DEFAULT
description: DEFAULT |LOF--STANDARD | |1 REPLACED ENGINE OIL AND FILTER*FRONT BRAKES HAVE 5MM REMAINING UNTIL THE BRAKE WEAR SENSOR*REAR BRAKES HAVE 4MM REMAINING UNTIL THE BRAKE WEAR
SENSOR*ENGINE BATTERY PASSED A LOAD TEST*ENGINE COOLANT IS GOOD THRU -32 DEGREES********************** ********DEFAULT |CUSTOMER REQUESTED A LOANERDEFAULT |MOUNT AND BALANCE 4 NEW BRIDGESTONE
BLIZZAK TIRES ALREADY PAID FOR DURING THE LAST SERVICE VISIT | |1 MOUNTED AND BALANCED 4 BRIDGESTONE BLIZZAK TIRES****SUMMER TIRES HAVE 6/32NDS OF TREAD DEPTH REMAINING ON (3)/ (1) TIRES HAS
LESS THAN 5/32NDS OF TREAD DEPTH REMAINING*
89332 miles
DATE: 10/02/2012
Repair# 0017707
Service: DEFAULT
description: DEFAULT |90,000 MILE SERVICE | |89332 REPLACED ENGINE OIL AND FILTER*ROTATED TIRES*REPLACED ENGINE AIR FILTERS*REPLACED THE INTERIOR CABIN AIR FILTER AND CLEANED THE BLOWER
MOTOR*FRONT AND REAR BRAKES HAVE 5MM REMAINING UNTIL THE BRAKE WEAR SENSOR*DEFAULT |C/S: GUEST STATES BRAKES PULSATE WHEN APPLIED AT HIGHWAY SPEEDS. CHECK AND ADVISE. |VERIFIED THE PULSATION IS
FELT IN THE FOOT PEDAL WHEN THE BRAKE IS APPLIED AND THE STEERING WHEEL AT TIMES* |89332 THE FRONT BRAKE PADS AND THE REAR BRAKE PADS HAVE 5MM REMAINING UNTIL THE BRAKE PADS NEED REPLACEMENT*AT
THAT TIME WE WILL REPLACE THE BRAKE PADS AND RE-SURFACE THE ROTORS TO ELIMINATE ANY VIBRATION UPON APPLYING THE BRAKE PEDAL*
description: TIRE--MOUNT & BALANCE (4) LOW PROFILE |BRIDGESTONE BLIZZAK TIRES 235-50-18
83760 miles
DATE: 08/21/2012
Repair# 0016574
description: 5,000 MILE SERVICE |5,000 MILE SERVICE | |83760 REPLACED ENGINE OIL AND FILTER*ROTATED TIRES*FRONT BRAKES HAVE 6MM REMAINING*REAR BRAKES HAVE 6MM REMAINING*TIRES HAVE 8/32NDS OF
TREAD DEPTH REMAINING*ENGINE BATTERY PASSED A LOAD TEST*
78813 miles
DATE: 07/10/2012
Repair# 0015419
description: 5,000 MILE SERVICE |5000 MILE INTERVAL SERVICE | |78813 REPLACED ENGINE OIL AND FILTER*ROTATED TIRES*FRONT BRAKES HAVE 8MM REMAINING*REAR BRAKES HAVE 8MM REMAINING*TIRES HAVE
7/32NDS OF TREAD DEPTH REMAINING*ENGINE BATTERY PASSED A LOAD TEST*
73239 miles
DATE: 05/30/2012
Repair# 0014258
Service: 75,000 MILE SERVICE
description: 75,000 MILE SERVICE |75,000 MILE SERVICE | |73239 COMPLETED 75,000 MILE SERVICE, CHANGED OIL AND ROTATED TIRES. FRONT AND REAR BRAKES ARE AT 7MM, GOOD. TIRE TREAD IS 7/32NDS. TOPPED
OFF FLUIDS AND WASHED VEHICLE.
67336 miles
DATE: 04/18/2012
Repair# 0013258
Service: DEFAULT
description: DEFAULT |65,000 MILE SERVICE | |67336 COMPLETED 65,000 MILE SERVICE. FRONT AND REAR BRAKE LININGS ARE AT 8MM, GOOD. TIRE TREAD IS 7/32NDS FRONT AND 8/32NDS REAR.
62215 miles
DATE: 02/28/2012
Repair# 0012018
description: CABIN AIR FILTER |INTERIOR CABIN AIR FILTER IS DIRTY | |62215 REPLACED INTERIOR CABIN AIR FILTER AND CLEANED THE BLOWER MOTOR*
Service: DEFAULT
description: DEFAULT |55,000 MILE SERVICE | |62215 REPLACED ENGINE OIL AND FILTER*ROTATED TIRES*FRONT BRAKES HAVE 8MM REMAINING*REAR BRAKES HAVE 8MM REMAINING*TIRES HAVE 9/32NDS OF TREAD DEPTH
REMAINING*TIRES INFLATED TO 35PSI*ENGINE COOLANT IS GOOD THRU - 32 DEGREES*ENGINE BATTERY PASSED A LOAD TES
56716 miles
DATE: 01/17/2012
Repair# 0011008
Service: DEFAULT
description: DEFAULT |50,000 MILE SERVICE | |1 FRONT BRAKES AT 4MM**GOOD**REAR BRAKES AT 4MM**GOOD**TIRES AT 8/32**GOOD**BATTERY TESTED GOOD**DEFAULT |CUSTOMER REQUESTED A LOANER
50651 miles
DATE: 11/21/2011
Repair# 0009603
Service: DEFAULT
description: DEFAULT |45,000 MILE SERVICE | |1 FRONT BRAKE LININGS HAVE 9MM REMAINING. REAR BRAKE LININGS HAVE 9MM REMAINING. ALL TIRES HAVE 10/32 TREAD DEPTH REMAINING. ALL TIRES SET TO 36 PSI.
COOLANT GOOD TO -25 DEGREES. ALL OTHER CHECKS OK AT THIS TIME. THANK YOU, JEFF
45618 miles
DATE: 10/31/2011
Repair# 0008508
Service: CERTIFIED PRE-OWNED 1ST OIL CHANGE
description: CERTIFIED PRE-OWNED 1ST OIL CHANGE |45,000 MILE SERVICE |.
Service: MOVED TO: 8508C LINE: A
description: MOVED TO: 8508C LINE: A |MOVED TO: 8508C LINE: A
Service: MOVED TO: 8508C LINE: B
description: MOVED TO: 8508C LINE: B |MOVED TO: 8508C LINE: B
Service: OTHERS R&R*
description: OTHERS R&R* |KNOCKING NOISE WHEN HITTING BRAKES AT ANY SPEED, CAN HEAR IT BETTER AT MEDIUM SPEEDS |FOUND ABS ACTUATOR TO HAVE FAILED. |1 REPLACED ABS ACTUATOR AS NEEDED. Z-TIME FOR
DIAGNOSIS/ BLEEDING TIME.
45618 miles
DATE: 10/31/2011
Repair# 008508C
Service: RECOMMENDED MAINT
description: RECOMMENDED MAINT |G/S SPEEDO SEEMS OFF, IF SET AT 75, SEEMS LIKE VEHICLE IS GOING 70MPH |UPON INSPECTION FOUND ALL FUNCTIONS TO BE WORKING NORMALLY |1 TESTED SPEED SENSORS OUTPUT
AND INPUT TO SPEEDO, ALL FUNCTIONS WORKING AS DESIGNED.
40482 miles
DATE: 09/12/2011
Repair# 0007594
Service: TOUCH UP
description: TOUCH UP |TOUCH UP
40480 miles
DATE: 09/08/2011
Repair# 0007515
Service: PACKAGE A--PAINT, INTERIOR, RTPB, AND DENT/DING PROTECTION, WHEEL APPEARANCE
description: PACKAGE A--PAINT, INTERIOR, RTPB, AND DENT/DING PROTECTION, WHEEL APPEARANCE |PACKAGE A--PAINT, INTERIOR, RTPB, AND DENT/DING PROTECTION, WHEEL APPEARANCE
40478 miles
DATE: 08/31/2011
Repair# 0007312
Service: NEENAH DETAIL
description: NEENAH DETAIL |NEENAH DETAIL
40476 miles
DATE: 08/26/2011
Repair# 0007117
Service: LEXUS CERTIFIED PRE-OWNED INSPECTION
description: LEXUS CERTIFIED PRE-OWNED INSPECTION |LEXUS CERTIFIED PRE-OWNED INSPECTION
description:
description:
description:
38838 miles
DATE: 07/26/2011
Repair# 0006284
Service: DEFAULT
description: DEFAULT |35,000 MILE SERVICE | |1 ALL BRAKE LININGS HAVE 7MM REMAINING. TIRE FROM LT FRONT HAD 5/32 TREAD DEPTH REMAINING. ALL OTHER TIRES HAVE 0/32 TREAD DEPTH REMAINING, WORN ON
INSIDE EDGES. TIRE FROM LT REAR WORN THROUGH PRIMARY RUBBER, WILL HAVE CORDS SHOWING SOON. ALL OTHER CHECKS
33576 miles
DATE: 04/22/2011
Repair# 0002622
Service: AIR FILTER
Service: DEFAULT
description: DEFAULT |25,000 MILE SERVICE | |33576 FRONT BRAKES HAVE 5MM REMAINING.REAR BRAKES HAVE 5MM REMAININGTIRES HAVE 4/32NDS OF TREAD DEPTH REMAINING.TIRES SET TO 36PSI.COOLANT IS GOD
THRU -32 DEGREES
Service: REPLACE BRAKE FLUID
description: REPLACE BRAKE FLUID |FLUSH BRAKE FLUID
29393 miles
DATE: 11/08/2010
Repair# 0080649
Service: ALE-V8
description: ALE-V8 |GUEST REQUESTS TO HAVE SPRING REPAIR PERFORMED AS NEEDED. |PERFORMED SAFETY RECALL AS REQUIRED. |REPLACED ALL VALVE SPRINGS AS NEEDED AND COMPLETED SAFETY RECALL
Service: VALET SERVICE
description: VALET SERVICE |VALET SERVICE FOR GUEST
27952 miles
DATE: 09/20/2010
Repair# 0079405
description: 5,000 MILE SERVICE |GUEST REQUESTED SERVICE FOR THIS MILEAGE INTERVAL. WE REPLACE ENGINE OIL AND FILTER (GENUINE LEXUS PARTS USED) REMOVE TIRES AND INSPECT TREAD WEAR AND MEASURE
DEPTH, AND ROTATE AS NEEDED. INSPECT AND MEASURE FRONT AND REAR BRAKE PAD AND ROTOR THICKNESS CO |- - REQUESTED WORK PERFORMED TO MAINTAIN VEHICLE VALUE, SAFETY AND TROUBLE FREE OWNERSHIP BY
FOLLOWING LEXUS REQUIRED MAINTENANCE GUIDELINES. |PERFORMED VEHICLE SERVICE AS REQUESTED.
Service: REPLACE WIPER INSERT
description: REPLACE WIPER INSERT |REPLACE WIPER INSERTS | |REPLACED WIPER INSERTS
Service: WAITING
description: WAITING |GUEST WAITING DURING VEHICLE MAINTENANCE.
22328 miles
DATE: 05/20/2010
Repair# 0075801
Service: 5000 MILE INTERVAL
description: 5000 MILE INTERVAL |GUEST REQUESTED SERVICE FOR THIS MILEAGE INTERVAL. WE REPLACE ENGINE OIL AND FILTER (GENUINE LEXUS PARTS USED) REMOVE TIRES AND INSPECT TREAD WEAR AND MEASURE
Service: A/C CABIN FILTER
description: A/C CABIN FILTER |CUSTOMER STATES, A/C FILTER LIGHT COMING ON | |REPLACED A/C CABIN FILTER AS NEEDED
description: VALET SERVICE |VALET SERVICE FOR GUEST 2611 LIBAL ST GREEN BAY, WI JOCK 920-432-7444 WHEN PICKING UP 172 BRIDGE IS CLOSED GO THROUGH DE PERE TO GET TO OFFICE
15989 miles
DATE: 10/20/2009
Repair# 0070322
description: VALET SERVICE |VALET SERVICE FOR GUEST KEYS AT THE FRON DESK
10596 miles
DATE: 05/20/2009
Repair# 0066226
Service: WAITING
description: WAITING |PROVIDE SHUTTLE SERVICE
5301 miles
DATE: 12/23/2008
Repair# 0062734
Service: RE-PDI
description: RE-PDI |RE-PDI |RE-PDI |RE-PDI
5301 miles
DATE: 12/23/2008
Repair# 0062733
Service: LOANER/RENTAL
description: LOANER/RENTAL |PROVIDED LOANER/RENTAL TO GUEST DURING VEHICLE REPAIR.
10 miles
DATE: 07/30/2008
Repair# 0272345
reported by: Lexus of Brookfield
Service: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
description: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES |PERFORM THE PRE-DELIVERY INSPECTION PER THE MANUFACTURERS CHECKLIST. | |COMPLETED PRE DELIVERY INSPECTION PER THE MANUFACTURERS CHECKLIST
Service: SALES NITROGEN FILL
description: SALES NITROGEN FILL |ADD NITROGEN TO ALL TIRES FOR SALES DEPT. SPECIAL PRICING | |PURGED AIR FROM TIRES AND REFILLED WITH NITROGEN.
274226 miles
DATE: 08/04/2016
Repair# 0054845
Service: DEFAULT
268770 miles
DATE: 06/30/2016
Repair# 0053887
Service: AIR FILTER
263353 miles
DATE: 05/18/2016
Repair# 0052696
Service:
description: | |
258008 miles
DATE: 04/08/2016
Repair# 0051564
Service: DEFAULT
252277 miles
DATE: 02/25/2016
Repair# 0050531
Service: DEFAULT
249365 miles
DATE: 01/28/2016
Repair# 0049827
Service: DEFAULT
247062 miles
DATE: 01/08/2016
Repair# 0049407
Service: DEFAULT
1 miles
DATE: 11/24/2015
Repair# 0048034
241052 miles
DATE: 11/13/2015
Repair# 0048007
Service: DEFAULT
235993 miles
DATE: 09/30/2015
Repair# 0046807
Service: DEFAULT
230180 miles
DATE: 08/18/2015
Repair# 0045591
Service: DEFAULT
224259 miles
DATE: 07/06/2015
Repair# 0044130
Service: DEFAULT
224259 miles
DATE: 07/02/2015
Repair# 044130C
Service: DEFAULT
RETENTION CLIPS*
218496 miles
DATE: 05/08/2015
Repair# 0042562
Service: DEFAULT
213246 miles
DATE: 03/09/2015
Repair# 0040892
Service: DEFAULT
207865 miles
DATE: 01/30/2015
Repair# 0040052
Service: DEFAULT
202399 miles
DATE: 12/19/2014
Repair# 0038997
Service: DEFAULT
196896 miles
DATE: 11/11/2014
Repair# 0037953
Service: DEFAULT
191696 miles
DATE: 10/09/2014
Repair# 0037026
Service: DEFAULT
185627 miles
DATE: 08/29/2014
Repair# 0035859
Service: DEFAULT
180067 miles
DATE: 07/23/2014
Repair# 0034737
Service: DEFAULT
174881 miles
DATE: 06/18/2014
Repair# 0033638
Service: AIR FILTER
Service: DEFAULT
172523 miles
DATE: 06/02/2014
Repair# 0033189
Service: DEFAULT
168340 miles
DATE: 05/02/2014
Repair# 0032301
Service: DEFAULT
163080 miles
DATE: 03/25/2014
Repair# 0031226
Service: 2
Service: DEFAULT
156758 miles
DATE: 02/04/2014
Repair# 0030062
Service: DEFAULT
Service:
description: | |
151578 miles
DATE: 12/11/2013
Repair# 0028811
Service: DEFAULT
145976 miles
DATE: 11/01/2013
Repair# 0027822
Service: DEFAULT
Service:
description: |
142408 miles
DATE: 10/15/2013
Repair# 0027328
140590 miles
DATE: 10/02/2013
Repair# 0026967
134643 miles
DATE: 08/26/2013
Repair# 0026023
Service: DEFAULT
139051 miles
DATE: 07/30/2013
Repair# 0025243
128498 miles
DATE: 07/11/2013
Repair# 0024762
Service: DEFAULT
FOUND*
122774 miles
DATE: 05/30/2013
Repair# 0023612
Service: DEFAULT
116956 miles
DATE: 04/24/2013
Repair# 0022582
Service: DEFAULT
111635 miles
DATE: 03/13/2013
Repair# 0021528
CLIPS*
109482 miles
DATE: 02/21/2013
Repair# 0021066
Service: DEFAULT
106237 miles
DATE: 01/25/2013
Repair# 0020544
Service: DEFAULT
100776 miles
DATE: 12/18/2012
Repair# 0019584
100776 miles
DATE: 12/14/2012
Repair# 019584C
Service: DEFAULT
94692 miles
DATE: 11/06/2012
Repair# 0018618
Service: DEFAULT
89332 miles
DATE: 10/02/2012
Repair# 0017707
Service: DEFAULT
83760 miles
DATE: 08/21/2012
Repair# 0016574
78813 miles
DATE: 07/10/2012
Repair# 0015419
73239 miles
DATE: 05/30/2012
Repair# 0014258
67336 miles
DATE: 04/18/2012
Repair# 0013258
Service: DEFAULT
62215 miles
DATE: 02/28/2012
Repair# 0012018
Service: DEFAULT
56716 miles
DATE: 01/17/2012
Repair# 0011008
Service: DEFAULT
50651 miles
DATE: 11/21/2011
Repair# 0009603
Service: DEFAULT
45618 miles
DATE: 10/31/2011
Repair# 0008508
45618 miles
DATE: 10/31/2011
Repair# 008508C
40482 miles
DATE: 09/12/2011
Repair# 0007594
Service: TOUCH UP
40480 miles
DATE: 09/08/2011
Repair# 0007515
40478 miles
DATE: 08/31/2011
Repair# 0007312
40476 miles
DATE: 08/26/2011
Repair# 0007117
description:
description:
description:
38838 miles
DATE: 07/26/2011
Repair# 0006284
Service: DEFAULT
33576 miles
DATE: 04/22/2011
Repair# 0002622
Service: AIR FILTER
Service: DEFAULT
THRU -32 DEGREES
29393 miles
DATE: 11/08/2010
Repair# 0080649
Service: ALE-V8
27952 miles
DATE: 09/20/2010
Repair# 0079405
Service: WAITING
22328 miles
DATE: 05/20/2010
Repair# 0075801
15989 miles
DATE: 10/20/2009
Repair# 0070322
10596 miles
DATE: 05/20/2009
Repair# 0066226
Service: WAITING
5301 miles
DATE: 12/23/2008
Repair# 0062734
Service: RE-PDI
5301 miles
DATE: 12/23/2008
Repair# 0062733
10 miles
DATE: 07/30/2008
Repair# 0272345
Wow, really nothing major at all.
This car essentially had not one major problem.
Pretty phenominal for nearly 300k on the clock!
And what I found to be pretty informative, unless I missed it, nothing about the engine loosing pressure, fluid leaks or oil consumption.
I know Doublebase will enjoy this thread!
I love these high mileage stories, and this one especially because it is so well documented, there's no...oh I drove 280,00 miles and all I had to replace were my wiper blades (I wonder what kind of owner would exaggerate about that?). This is real, this is documented and it's the third high mileage older 460 I've seen, and they've all had minimal repairs.
Other than routine fluid changes, after 280,000 miles this car only needed an O2 sensor, valve cover gaskets, a wheel speed sensor and a brake actuator (which Lexus now covers under an extended warranty). Is that it? Am I missing something? Wait was there a water pump? I think so at 100,000 something miles.
The other three higher mileage stories I've seen on this site are very similar to this one.
I own a Honda Accord with 287,000 miles on it...owned it since new...it's my backup vehicle...I've replaced almost every single part in that car. From the tie rods and steering rack, to the control arms and ball joints...sway bars, links, bushings, motor mounts, every gasket imaginable, subframe, gas tank, a half dozen sensors, evap parts, transmission switches, egr, radiator, water pumps, exhaust, brake lines, countless calipers and rotors...and it's the best car I've ever owned.
These LS460's are terrible...I really regret owning one.
