2004-2006 failing LED tail light fix....
Old 09-26-16, 11:57 AM
LS430cb
LS430cb's Avatar
Default 2004-2006 failing LED tail light fix....
As you all know the only solution USE to be to buy a new tail light. Well I love a challenge and I didn't stop until I came up with an solution.I searched high and low for a fix and no luck. So I said what the hell, and opened my completely dead tail light. Our LED's are ran in series so if one LED fails or becomes loose you lose an whole string or get the flickering. (loose led) The original leds are snapon / solderless.
They are no longer made so I went with a solder in place led which will prevent the flickering like the originals from becoming lose over time.
This tail light was completely dead!
(Dead link)
I went through and found all the ones that still worked and used those until the replacement led's I ordered came in.
They arrived today. I will update when I am done.
danforth (08-15-22)
Old 09-26-16, 01:33 PM
BradTank
BradTank's Avatar
Let us know when you finish and take plenty of pictures. I'm not afraid of a little soldering.
Old 09-26-16, 01:52 PM
LS430cb
LS430cb's Avatar
More pics and wiring diagram:
Old 09-26-16, 01:57 PM
LS430cb
LS430cb's Avatar
Will do, how do you post pictures directly?
Old 09-26-16, 07:21 PM
5t341th
5t341th's Avatar
click on the little image icon. Or copy and paste the FORUM code aka IMG
BTW. thanks for the tips. Will try my hand at it if I do ever have a burned out bulb
Old 09-26-16, 07:42 PM
LS430cb
LS430cb's Avatar
Your welcome, I've learned so much from this forum happy to share knowledge.
Old 07-15-19, 10:25 AM
whooodat
whooodat's Avatar
I tried to search for the LED part number from the picture provided on FutureElectronics but come up empty. Does anyone have more information on this?
Old 08-12-22, 03:05 AM
Maybethen
1st Gear
Maybethen's Avatar
It seems the LED part# in this string is no longer available. I wonder if anyone else has successfully been able to repair this and could provide more details. I'm having the same issue, and would like to try and repair the light rather than swap it out.
If anyone can help let me know.
Thanks,
Old 08-14-22, 08:22 PM
Yamae
Yamae's Avatar
Thanks,
Those LEDs are no longer available and I use
Chanzon's LED of this Chanzon's LED of this
when I fix variety of Toyota LED tail lights requested by local shops. It's a Chinese company and the quality is not as good as Japanese manufacturer Koito or Stanley but I'd say those are so-so level. Most of Toyota's tail light LED units are designed to consume about 100mA and Chanzon's 1W red LEDs are mostly OK.
Chanzon manufactures variety of LEDs and here is a video which introduces to use a 10W LED.
Old 07-05-23, 11:03 PM
neonninja
neonninja's Avatar
Originally Posted by Yamae
Those LEDs are no longer available and I use Chanzon's LED of this when I fix variety of Toyota LED tail lights requested by local shops. It's a Chinese company and the quality is not as good as Japanese manufacturer Koito or Stanley but I'd say those are so-so level. Most of Toyota's tail light LED units are designed to consume about 100mA and Chanzon's 1W red LEDs are mostly OK.
Chanzon manufactures variety of LEDs and here is a video which introduces to use a 10W LED. https://www.youtube.com/watch?v=2ojNDKIScpI
Did anyone have any luck repairing thier lights following Yamae's always amazing advice?
Old 02-25-24, 09:37 AM
jgyula86
5th Gear
jgyula86's Avatar
Default leds
Hi! I know this thread is for a different car, but my question is about the leds, and you guys seem to be experienced.
I am trying to repair my rx400h rear outers, and Im a little stuck here. There is nothing written on the leds to get the exact type. I found the datasheet of the snapled 150:
https://www.digchip.com/datasheets/d...mber=HPWS-FH00
There are 6 different type of it. Rx400h leds are tail and stop too. Do you guys know what would be the correct type to hunt for? I am trying to get some from china, to experiment with it, but I need a little help choosing the right ones.
I would be grateful, if any of you could help me out with it!
Old 02-25-24, 11:31 AM
Received 2,707 Likes on 2,292 Posts
Can you post some pictures if the tail light?
Old 02-25-24, 11:38 AM
jgyula86
5th Gear
jgyula86's Avatar
Old 02-25-24, 11:48 AM
You need to measure the voltage going to the LEDs and go from there. Way I read that data sheet is there are 14 different versions depending on required voltage. Also bin code 3 is the deepest red bin code 1 more orange.
If I had to guess, the red LEDs will be at about 2 volts but you need to verify.
Old 02-25-24, 12:17 PM
jgyula86
5th Gear
jgyula86's Avatar
Will do that thanks!
Quick Reply: 2004-2006 failing LED tail light fix....
