F Sport Sway Bars or RR Racing USRS
Old 09-24-16, 09:53 PM
Aspect
Aspect's Avatar
Default F Sport Sway Bars or RR Racing USRS
Hey CL, just trying to get some opinions here.
Looking for my next handling mod and am torn between the two upgrades. Extensive reading of both review threads and impressions and I haven't really found my answer. People have praised them both for being essential performance upgrades for the 2IS and I do end up planning on getting them both for the car sometime in the future, but not sure what order I should go with - Sway 1st USRS 2nd or vice versa. I'd like to get them both at once ideally but have tried to slow down my modding for a little while. Both installs also being relatively easy I hear.
F Sport Sway Bars (F & R)
- tighten up the handling by reducing body roll
RR Racing USRS
- better braking
- no brake dive under heavy braking
- better steering feel
- better turn in
- eliminates inner tire wear
- does require an alignment
Old 09-24-16, 10:50 PM
aventur2
aventur2's Avatar
Sway Bars!
Old 09-25-16, 07:59 AM
Gville350
Gville350's Avatar
In my opinion, I'd just do the rear sway bar at $200 plus the RR Racing LCA bushing. Upgrading just the rear favors the way I drive; so I stopped there.
Old 09-25-16, 08:10 PM
Aspect
Aspect's Avatar
^I thought about that too but then again if I change my mind the front sway bar only comes in the set and not by itself. The rear bar makes the biggest difference but I'd probably want the set, can't stand only having one half of an upgrade
Old 09-25-16, 10:27 PM
nosurprise
nosurprise's Avatar
The upgrade is not really one half ... you can look at it as the rear makes 90% of difference and the front is 10%. But if you want both though, you should get both.
Old 09-26-16, 04:55 AM
redspencer
OG Member
redspencer's Avatar
This OP of this thread provides the most comprehensive review on whether or not you should purchase the F&R sway bar set or just the rear sway bar:
https://www.clublexus.com/forums/sus...rs-review.html
My personnel experience is that the rear sway bar is the best bang for the buck handling mod in terms of improved agility and turn-in response but the front sway bar does add a noticeable improvement to the stability and balance of the car when cornering.
Old 09-26-16, 07:10 AM
Aspect
Aspect's Avatar
Thanks for the responses. I've seen and read through that thread already. I definitely want both. Gville's post made it tempting to forfeit one of the bars in order to get both the sway bar and USRS in one go. I think I'll get the sway bar set first and the USRS later.
Old 09-26-16, 10:01 AM
Zmon
Zmon's Avatar
Any opinion on the IS-F front sway versus the one Megan sells (I believe Megan is recommending using adjustable links with their bar)? The F-Sport FSB is a bit hard to come by on it's own.
Old 09-26-16, 11:08 AM
bbaugher47
bbaugher47's Avatar
Front fsport sway for sale in classifieds here:-). Sikky makes a beefy three way adjustable rear sway as well. Hope this helps
Old 09-27-16, 03:46 PM
MikeFig82
MikeFig82's Avatar
I just recently upgraded my stock sway bar bushings to Superpro poly. They made a big difference on my 2010 IS250 AWD. I also installed lateral locks on the front bar. Great improvement for less than $100. My next mod is the RR USRS.
Old 09-28-16, 01:07 PM
SeanO
SeanO's Avatar
I have both Front and Rear F sport sway bars and it they definitely improved the handling of the vehicle.. If you able to buy the set I would do that
I8ABMR
Suspension
235
12-07-21 01:21 PM
FSportIS
Suspension and Brakes
24
03-12-21 02:52 PM
ruikito
12-25-18 07:06 PM
ghorn
11-19-18 11:29 AM
astromoose
16
05-16-14 06:45 PM
Quick Reply: F Sport Sway Bars or RR Racing USRS
