Tire sizes for Linea Corse LC818?
Old 09-24-16, 09:46 AM
jt321
jt321's Avatar
Default Tire sizes for Linea Corse LC818?
Hey guys,
I got new LC818 rims for my 2008 ISF. I had Discount Tire swap my current tires on to the new rims (225/40/19 and 255/35/19), but noticed the rim sticks out alot further then the tires. Im thinking of getting wider tires and going with 245/35/19 and 275/30/19. I do have Tein H tech springs and Bilstein B6 shocks on the car. The wheels are 19x8.5 + 30mm and 19x10 +38mm.
Will i run into any issues with rubbing?
Old 09-24-16, 12:59 PM
shyguyF
shyguyF's Avatar
The front should be fine, the rear I think you just need to get fenders rolled. With 38 offsets and 275 in the rear is not a so aggressive setup. You can check on WHEELDUDE.COM there are so many setups that you will follow.
Old 09-24-16, 04:04 PM
Lmood
Lmood's Avatar
I run a 275 on the rear with my lc818s I'm stock height back there and I rub on dips. I'll be rolling the rears soon.
Old 09-25-16, 12:09 PM
jt321
jt321's Avatar
Does it rub pretty bad? I rolled my rear fenders today.
Do you guys think a 265 in the rear would be better?
Old 09-25-16, 12:41 PM
Lmood
Lmood's Avatar
It only rubbed in dips. Keep in mind I'm stock height in the rear.
Old 09-25-16, 01:58 PM
shyguyF
shyguyF's Avatar
265/35 it would be ok . If you really want to get the wide tire why you dont get 275 bc your fenders just got rolled. This guys he is running 265/35 in the rear.
http://www.wheeldude.com/wordpress/f.../11/panda-is-f
Old 09-25-16, 04:10 PM
jt321
jt321's Avatar
I dont need the wide tire per say. Just dont like the way the outer edge of the rim sticks out further then the tire...
Old 09-25-16, 05:09 PM
shyguyF
shyguyF's Avatar
It's too bad man ! Bc LC818 with +38 offsets will be 30mm stick out to the fenders compared to the stock wheel 9" +55.
Old 09-27-16, 10:24 AM
Kojak77
Kojak77's Avatar
I think Wheeldude suggests 235/35/19's for the front, and 265/30/19's for the rear.
Old 09-27-16, 12:15 PM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
On an ISF, you can go with a 19x10 +38 set up on all 4 corners. This is fairly common with the LC818 on the ISF. Tire sizes needed are 255/35 Front and 265/35 Rear. I had this setup and it was perfect, no rubbing (I am lowered on Tein Springs).
Since you already have staggered wheels, that obviously doesn't help you... but you can definitely go with a 265/35 in the rear without issues, and probably even a 275/30 without issues. 245/35 should also be fine in the front.
Old 09-27-16, 06:41 PM
robtown
robtown's Avatar
I'm very close to pulling the trigger on a set of these as well unless I can find some RCF wheels and thinking about a square set up. All 4 - 19x10 +38.
I'll roll the rear fenders and might relocate the bumper tab if necessary but don't want a pull. I'm open to rolling the front fenders and might even consider camber and toe arms to be able to run a little negative camber to fit meatier tires. I'm currently at stock height. At most I'd do a minimal drop like the OP.
What would be required to fit the following...
Option 1 - 275/30 Michelin PSS all around. Will that fit in the front?
Option 2 - 275/30 Bridgestone Potenzas, slimmer than the MPSS.
Option 3 - 265/35 MPSS
thanks,
Rob
Old 09-28-16, 12:16 PM
zmcgovern4
zmcgovern4's Avatar
I doubt any of those options fit easily...
The wheel specs are relatively aggressive, especially if you're wanting meaty tires and are lowered... here is my car when I had the 19x10 setup for reference.
Front fitment with 255/35
Rear fitment with 265/35
Tires shown are cheap Nankangs which are much slimmer than MPSS or Potenzas.
My car is only dropped in the front on Tein H Tech (1"). Rear is factory height.
I had no rubbing with rolled rears, but if you're lower and/or want wider tires you will likely be needing modifications.
Old 09-30-16, 06:16 AM
robtown
robtown's Avatar
Thanks for the detailed pics. I think the 10 in the front might be too much. If I can't run a square set up I think I'll try 255/35 in the front and 295/30 in the rear but need some different wheels and offsets. I have something in the works and will post once completed.
Thanks, Rob
Old 09-30-16, 11:17 AM
flowrider
flowrider's Avatar
Received 1,829 Likes on 1,291 Posts
Thanks, Rob
I'm running Bridgestone S-04s in the sizes you mentioned on RCF 9s and 10s.
Lou
Old 05-30-17, 11:14 PM
Guedzou
Guedzou's Avatar
Hello,
I am writing from France and I hesitate for the purchase of LC818 rims.
Here is the size choice I have for copies of LC818 (ROTA Wheels) : http://www.driftshop.fr/jantes.html?color=95&diam=92&modele=3835&pcd=157
My car is full stock (not lowered) and i don't want to roll the fender.
Which setup do you advise ?
19x10 ET38 all around / 255 front and 265 (or 275) rear
19x8.5 ET38 Front and 19x10 ET38 rear / 235 front and 265 rear
The ET30 for the front wheels doesn't exist in France for the LC818. But with 5 mm spacers for example it might seem wider?
Quick Reply: Tire sizes for Linea Corse LC818?
