Tow options for 2014 if I don't have tow package?
I have a trailer and car with a combined weight just around 3,500 pounds. From what I understand, that is right around the limit for the RX, but I don't have the tow package. What are my options?
i wouldn't tow anything with out the tow package. especially with the ws fluid in these transmissions. that stuff breaks down in a helluva hurry with out towing anything.
Interesting that you say that. The maintenance schedule seems to imply that the transmission fluid never needs to be changed with normal, non towing use.
If you're going to do it a couple times, just go ahead and tow it unless you're in a mountainous or very hot area, or have a route with lots of stop and go. Steady state cruising puts some load on the vehicle due to aerodynamics, but won't overheat the tranny. Your fuel mileage will go straight to heck.
IIRC the tow package has an auxiliary tranny cooler and a bigger battery, but if you don't power anything in the trailer the battery is irrelevant. Before someone mentions it, it doesn't have a bigger alternator because we don't have alternators. Tranny cooler is a good idea but not critical unless you're really putting a constant excess load on the engine/transmission.
Lexus114, do you have any evidence of these claims about the tranny fluid?
Jonas
Jonas
Jonas
Jonas
I did my first ATF drain and fill at 30 some thousand miles, followed by 2 more and am now on an annual schedule. Note that a drain and fill only drains about 2 quarts. I used MAG 1 low viscosity synthetic ATF which is listed as compatible for Toyota WS.
http://www.mag1.com/ProductDetails.a...a-55f0b5c590fe
https://www.bobistheoilguy.com/forum...Number=3042591
I noticed the old fluid was almost black. The vehicle appeared to shift faster and smoother with the new fluid after 3 drain and fills.
On page 377 of the owners there is a table that shows for a 350 without the towing package the max trailer weight is 2000lb, with 3500lb being for one that does. For the 450h it gets kind of vague, there is no data/spec for one that does not have the package, with 3500lb being what is given for one that has the package.
If you have a 350 without the tow package, I would suggest using a different tow vehicle until you can get the right pieces installed.
I know the numbers Lexus has published are conservative and there is probably a good chance you'll be fine (according to the book, 1000lb is the max unbraked trailer weight which is way under what the realistic max is) but I wouldn't go as far over what is published as you would be on this one.
No tow package? Retrofit or do the equivalent at hitch shop. Tranny oil cooler, hitch, wiring, suspension. What kind trailer? Does it have surge brake or electric brake? Combined weight 3500 lbs and how many passengers, loaded stuffs, etc.......
I did cold drain and fills after sitting overnight in my garage with the new ATF also stored there so both are at the same temperature. This allows for accurate comparative measurement of what was drained so the same amount will be poured back in without the heat induced volume increase. There is an overflow plug inside the drain hole that has to be removed after the drain plug to drain the whole 2 quarts. It is removed with an Allen wrench. It is plastic and fragile. Then measure what is drained.
I had a 2008 MINI Cooper S with almost the same Aisin 6 speed automatic transmission and on the MINI forum we figured out the drain and fill procedure. I did it on the MINI several times before I got rid of it (shortly after the warranty expired as they are terribly unreliable). However the MINI did not have an easy access fill hole via the driver side front wheel well. There is another thread here on ATF drain and fills where I posted the MINI change procedure PDF and another Lexus PDF that shows the overflow plug etc.
Changing ATF without using the fluid exchange machine tapped into the cooler lines is like changing one sock.
