front end popping/clicking
Old 09-19-16, 03:06 PM
dlap
dlap's Avatar
Default front end popping/clicking
Hello everyone. I have a 2011 LS460 w/ 77,861 miles on it that I bought back in March. I have been hearing a popping/clicking noise when I turn the wheel. It's not always present but it is at it's loudest after the car has been parked for a while. I also hear it more when I am turning the wheel in reverse. I took it to the dealership (2 yr/unlimited mile warranty) and they kept it for a week and found inner tie rod end loose, replaced the power steering rack and adjusted front toe. Well two days later after getting my car back, I heard the noise again. Before I take it back to the dealership (and possibly lose it), what do you guys think it may be? I have always highly appreciated your input. Thank you.
Old 09-19-16, 06:06 PM
tlk2megoos
tlk2megoos's Avatar
I had this problem compounded with drifting steering during bumps and at low speed turning. Changed out the control arms (all were worn out) and clicking stopped (along with all the other problems).
Old 09-19-16, 06:07 PM
Doublebase
Doublebase's Avatar
Is it AWD? Sounds like a CV joint.
Old 09-19-16, 06:21 PM
dlap
dlap's Avatar
No it is not AWD.
Old 09-19-16, 06:23 PM
dlap
dlap's Avatar
And I do hear it most at low apeed turning. Thanks for your replies.
Old 09-19-16, 06:25 PM
dlap
dlap's Avatar
Speed* (spell chk)
Old 09-19-16, 06:26 PM
dlap
dlap's Avatar
Should control arms be worn out under 78,000 miles?
Old 09-19-16, 09:05 PM
superdenso
superdenso's Avatar
This thread is a puzzlement because 11's were not implicated in the TSB below:
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=173798
The symptoms in the description sound familiar, and they led to replacement of 8-arms at 60k miles. However, the situation can't be 100% diagnosed over the net. Fortunately, you have an active warranty. A diagnosis and a deductible should be the extent of the inconvenience.
Be well, let us know how you work things out
Old 09-20-16, 08:30 PM
Falbz
Falbz's Avatar
Had same problem and it turned out the front wheel bearings were bad and needed new hub assemblies. Would click repeadedly when wheels were turned left / right and rolling slowly as mentioned. Both were replaced and covered under my warranty at the time. Thought they were going to stick me with the bill because I have aftermarket 22 inch wheels but they gave me no problems. Best of luck
The control arms on our cars are notorious for having issues and you would notice the issue more going over bumps when hearing a little clunking noise. From what you are describing as the wheels are turning left and right you hear a clicking noise. The noise did also seem louder during initial cold startups ( or car was sitting for awhile) but was always present in my situation. As mentioned problem went away after they replaced both front wheel hub bearing assemblies.
Old 09-20-16, 10:50 PM
dlap
dlap's Avatar
Thanks Fablz. I was thinking in that area too but I'm no trained mechanic. Going back to dealership tmrw/tday. Thanks a lot guys for your input.
Old 09-20-16, 10:51 PM
dlap
dlap's Avatar
I'm sorry for misspelling your name Falbz. Again, thank you.
Old 09-21-16, 02:56 PM
Falbz
Falbz's Avatar
No problem - keep us posted how it goes. Best of luck
Old 09-22-16, 05:43 PM
ronsmoove
ronsmoove's Avatar
Im having this problem also. If it is the Bearings, Is it an expensive fix?
Old 09-22-16, 07:09 PM
Falbz
Falbz's Avatar
OEM hub assemblies are around $325 each or you can source aftermarket rock auto ones for around $200-$240 each side. Depends on brand etc. Then you will have to factor in install if you are not doing the job yourself. Hope it helps
Old 09-23-16, 08:28 AM
roadfrog
roadfrog's Avatar
There are members here who have replaced their bearings for a fraction of dealer price. FYI.
Quick Reply: front end popping/clicking
