2015 IS250 tire rotation?
Old 09-19-16, 09:03 AM
benj0
benj0's Avatar
Default 2015 IS250 tire rotation?
Nub here on IS. With the different tire size for front/rear, I assume that you don't do rotation. My IS is NOT FSport and NOT 4WD. This car used to be my daughters..
Old 09-19-16, 09:40 AM
E46CT
E46CT's Avatar
Received 2,209 Likes on 1,655 Posts
Correct. If staggered, no rotation.
Old 09-19-16, 04:39 PM
toyoman29
toyoman29's Avatar
I rotate mine side to side if the tires are not directional...
LaZeR (01-30-21)
Old 09-19-16, 04:42 PM
benj0
benj0's Avatar
My fronts are 225/40/18 and the tears are 255/35/18.
Old 09-27-16, 08:39 AM
bob4256
bob4256's Avatar
You can always flip the fronts and the rears to help out with camber wear. Thats what I do with my aftermarket wheels/tires
Old 01-29-21, 07:11 AM
Jflex15
Jflex15's Avatar
I haven’t had my is250 long and was planning to rotate tires today when I stumbled on this post. Curiousity here what are the side effects of rotating these wheels if they are staggered? I thought mine were the same but after looking just now I’m 225/40z R18 in the front and 255/35z R18 in the rear. Apples and oranges here but on my camaro my rear rims physically have a different offset so the tire has to be dismounted then remounted on rear rim to rotate them. Are the factory rims on these cars like that as well with different offsets?
Old 01-29-21, 08:07 AM
Sasnuke
Sasnuke's Avatar
Received 1,738 Likes on 1,371 Posts
The rim specs are:
Front: 18x8 +45
Rear: 18x8.5 +50
You can't dismount the tires and rotate them as the rim they would go to would either be too big or too small.
Old 01-29-21, 05:53 PM
Jflex15
Jflex15's Avatar
Originally Posted by Sasnuke
The rim specs are:
Front: 18x8 +45
Rear: 18x8.5 +50
that explains a lot that I was unsure of and explain why my rear tire is that much wider. What are most guys on here doing in terms of tire maintenance? I was thinking mine were directional but after looking at the outer wall I don’t see the directional arrow. From what I’ve read swapping the tires/rim from left to right doesn’t seem to be a popular option. And thanks for answering that question also.
Old 01-29-21, 09:51 PM
Sasnuke
Sasnuke's Avatar
For tire maintenance just check the pressure periodically and get an alignment every couple years, or as needed, or when replacing the tires...not much more you can do than that.
Old 01-30-21, 07:23 AM
Jflex15
Jflex15's Avatar
I’m curious is there another style rim from the factory that has all 4 identical rims/tires? I honestly love the rims on it so it would take a really good looking one for me to swap just so I could rotate. Although they would likely last a bit longer being able to rotate them so they wear even.
Old 01-30-21, 10:09 AM
Sasnuke
Sasnuke's Avatar
The 3IS comes with a few different rims...only the F Sport rims and the optional IS350 rims are staggered. There's another 18 inch and a 17 inch option that are squared.
Personally I like the mesh style 18 that comes in a square setup:
18 inch square
Optional 350 staggered rim
F Sport staggered rim
LaZeR (01-30-21)
Old 01-30-21, 09:50 PM
Jflex15
Jflex15's Avatar
18 inch square
mine are definitely the bottom rim. I like that style by far the most so I probably won’t swap them out for the square set. Do the staggered rims offer any performance in terms of handling? I would imagine there’s some gain since they come on f sport.
LaZeR (01-30-21)
Old 01-30-21, 10:31 PM
LaZeR
LaZeR's Avatar
Do you see "OUTSIDE" imprinted on your tires? If yes, they're usually NOT (uni)directional, and swapping from left to right is OK, but doesn't accomplish a helluva lot.
What about the infamous & wildly popular replacement of OEM lower control arm bushings with firmer ones?
Old 01-31-21, 06:21 AM
Sasnuke
Sasnuke's Avatar
There is that too...replacing the lower control arm bushings with the RCF/GSF ones.
Although some people claim to not have the infamous inner tire wear on the front, although a lot do.
Old 01-31-21, 10:14 AM
Jflex15
Jflex15's Avatar
@lazer yes all 4 of mine have “outside” imprinted on them. I’ve seen a few post about rotating side to side but having to dismount tires from rim to do so. I’m not sure you have to dismount though if the aren’t directional.
Ive also seen a few post on here discussing upgrading lower control arms to a more solid version. I haven’t had my car to long but so far I haven’t noticed to much excess wear on my inner tire. Maybe a bit feathered on the outer part though.
Quick Reply: 2015 IS250 tire rotation?
