Battery life/replacement? (merged threads)
Old 09-01-16, 10:41 AM
relax221
relax221's Avatar
Default Battery life/replacement? (merged threads)
I have a 2013 rx 350 whats the average battery life ?
Old 09-01-16, 11:16 AM
F250
F250's Avatar
Most 12V batteries these days last at least 4 years, and some last 6-7. Personally, if I reach 5 years and have not had to change the battery (regardless of vehicle make/model), I change the battery... even on my Ford diesels which require TWO 850 CCA batteries every time they are changed.
Proactive replacement will minimize your being potentially stranded.
Old 09-02-16, 07:17 AM
lexus114
lexus114's Avatar
i would replace after 4 years. the factory battery will most likely last a good five years, but why take the chance?
Old 09-02-16, 07:47 AM
Buzzer777
Buzzer777's Avatar
Default Proactive rerplacement at 3+ Yrs here
. I purchased my 2013 RX with 54k + miles on the clock. By my reasoning, that would amount to a bit less than 20k per yr by the previous owner (carfax shows 1 other owner besides me) and when I had the battery checked by a tire shop, they indicated that normal discharge was occurring and that there was still decent "time" left on what appeared to be the original battery (the Lexus service records did not show a battery replacement and the battery "label" showed "LEXUS" so I presume it was the original Battery. LIKE YOU SAID..."PROACTIVE REPLACEMENT"..I did so at my local Lexus dealer just to be safe.I know better, but I bought the oem battery for a hefty $175!! Could have had an Interstate (Johnson Controls) for about $125 or less!!
Old 09-02-16, 12:04 PM
relax221
relax221's Avatar
Default battery
Thanks for all your help
Old 09-04-16, 07:02 AM
NateJG
NateJG's Avatar
My 2013 RXh's battery wouldn't hold enough charge at three or four months of ownership to start the car after two weeks garaged (the car sat in the Southern Florida dealership's inventory for a year prior to my purchase - which likely accounts for some early life trauma due to heat/discharge/storage). This happened multiple times. Dealer reported that it checked at the lower end of acceptable. Replaced under warranty, it's been starting the car (well, not technically, of course - as the car's the hybrid) for the past 2.5 years.
Old 09-04-16, 09:31 AM
ColAngus
ColAngus's Avatar
I wouldn't dream of touching it for at least 7 years and likely 8. The first battery I've ever proactively replaced was in my Nissan and it's a 2003 with over 120,000km on it. It also experienced winters with temps as low as -35°C.
Stranded with a dead battery is the Diet Coke of stranded, too. A variety of readily available car batteries will instantly get you out of that bind compared to a severe mechanical issue. The crappy thing is that it'll likely happen in extreme cold if you live in a place like that.
$0.02
Old 09-04-16, 04:04 PM
SteveCraig
SteveCraig's Avatar
Replaced the OEM battery in our '10 last week. While in for service I asked them to load test it & results were marginal. Winter is coming down the tracks here pretty soon. A 6 year old battery doesn't owe me anything.
$177 for new OEM. Cheaper out there yes.
Battery pricing usually revolves around the metals market. Many batteries are using recycled lead. Higher end (priced) are for the most part using virgin lead.
Old 09-29-16, 10:18 PM
Sandi_k
Sandi_k's Avatar
Yep, just replaced the OEM battery on my 2010 RX350 with 180K miles. It's done its time.
Old 09-30-16, 04:46 AM
JT4
JT4's Avatar
Not too bad, 6 years and 180K on the original battery.. Yeah, I would say it's done it's time...
Old 10-01-16, 07:08 AM
mandyfig
mandyfig's Avatar
To extend the life of your battery, specially if it is not your daily, you must use a trickle charger, a $30 investment. This keeps the battery refreshed. Then you can bank on at least 6 years of trouble free start ups.
Who uses their SC as a daily? If you do, then when the 1st hint of a non-crank, time to replace. Still look at 6 years minimum.
Old 10-01-16, 01:43 PM
MellonC00
MellonC00's Avatar
i don't know why but every one of my batteries did not last until the end of the warranty period. It was always the corroded terminals (this impacts the cells inside). Who know why but I must be making the oxygen molecules very voracious around my batteries.
Old 10-01-16, 04:02 PM
SteveCraig
SteveCraig's Avatar
Every battery I've ever had in a daily vehicle, classic car, work truck or boat gets the same treatment.
Cleaned battery terminals get a light dab of Vaseline on top. Engine heat will melt it & let it migrate throughout the connection.
No battery corrosion, ever.
Old 10-03-16, 09:21 AM
MellonC00
MellonC00's Avatar
Hold on a second there. Are we supposed to clean to the battery terminals??? Like a regular maintenance such as oil change? How often should we do this?
Old 10-03-16, 09:44 AM
F250
F250's Avatar
I would say that you need to "check" the condition of your terminals every 6-12 months, and if they show signs of corrosion, clean them and coat them with either the CRC or Permatex batterry terminal cleaner/protectors. Both products are readily available. You can also use the green and red felt washers under the cable connectors on the posts as an additional anti-corrosion measure.
When using the protective coating sprays, only spray the terminals AFTER the cables are cleaned, reconnected, and tightened.
Quick Reply: Battery life/replacement? (merged threads)
