Front license plate delete
Old 08-30-16, 03:22 PM
sseaman
sseaman's Avatar
Default Front license plate delete
Any suggestions on how to cover or fill the holes left from removing the front license plate holder?
Old 08-30-16, 03:25 PM
F250
F250's Avatar
How about some of those plastic trim rivets/holders? You can get them in different colors and sizes. Here is a link to one size/color option -->>> https://www.amazon.com/Interior-Pane.../dp/B008FZD5MM
Here is another source (company) which has a large selection of options and sizes as well. -->> http://www.thefastenerwarehouse.com/...age/584919.htm
If you search for Plastic Auto Fasteners, you cna find several options... some with a simple rounded head that only push into place, some with an internal rivet pin which pushes into place and spreads two "wings" on the back side, and some with screw heads which spread out expansion wings on the back side behind the bumper surface.
I'm really glad you asked that question because I, myself, had wanted to eventually investigate how to clean up that front license plate holder since we do not require front plates in my state. Now I know what I'm going to do!
Old 08-30-16, 04:40 PM
Freds430
Freds430's Avatar
Received 1,059 Likes on 693 Posts
Bumper Plugs sells color matching plugs to fill those holes.
Old 08-30-16, 05:46 PM
sseaman
sseaman's Avatar
Thanks F250 and Freds430, I will look into these options
Old 09-02-16, 08:08 AM
Buzzer777
Buzzer777's Avatar
Default When you get stopped and...
I got stopped recently at a safety check and having nothing better to do,the officer actually checked my front plate which I had recently installed..LOL!
Old 09-04-16, 07:02 AM
TeeDog
TeeDog's Avatar
+1 on the Bumper Plugs, I put these on my Porsche and the color match is spot on..
https://www.bumperplugs.com/index.ph...gory&path=1_11
Old 12-28-16, 02:13 PM
Kopavi
Kopavi's Avatar
The RX I recently purchased had the dreaded front plate holes. I live in AZ and the front plate is not required here. I purchased a pack of two Hillman nylon 1/4" hole plugs in natural from Lowes for $1.04. I painted the plugs with about 6 coats of touch-up paint and two coats of clearcoat. I carefully cut away the rough spots using a precision knife. Then I used a hair dryer to warm the hole and the plug which allowed for easier insertion.
I looked at Bumper Plugs but didn't want the larger plug area that they provide. The 1/4" is about as small as you can get. I also bought the 3/16" in black but they were a tad small for my application.
The picture below is a bumper plug to show the size difference.
insite4U
LX - 3rd Gen (2008-2021)
35
09-21-17 03:30 AM
gumbylude
IS F (2008-2014)
16
06-27-17 05:45 AM
smackman
08-07-11 07:09 PM
Little E
06-22-08 10:32 AM
shimmers
12-05-06 06:28 PM
Quick Reply: Front license plate delete
