Lexus LS 2012 AWD - ? New tires
Old 08-29-16, 11:12 PM
DM2
DM2's Avatar
Default Lexus LS 2012 AWD - ? New tires
My 2012 Lexus LS has about 49000 miles on it . I bought it a year ago when it had 40, 000 miles on it. It presumably has the original tires. One tire was damaged and had a tear in the sidewall, ( Hit the sharp iron edge of a drain) . I have driven 250 miles on the full size spare tire. Should I replace all four tires. I have heard that is necessary in an AWD vehicle.
Old 08-30-16, 05:16 AM
Doublebase
Doublebase's Avatar
Technically you should, especially whereas you have AWD. Different tread design/depth at different wheels, changes rolling resistance, which could lead to damage to the drive train (so they say). Also there is a chance you could effect your ABS, traction control and stability assist - the wheel speed sensors could register different signals.
Old 08-30-16, 05:52 AM
Received 2,499 Likes on 1,802 Posts
I would replace all 4.
I have the Pirelli Cinturato P7 Plus on mine and they're excellent, very smooth and quiet.
Old 08-30-16, 06:35 AM
vfr700f2
vfr700f2's Avatar
I agree. Not as much because of possible computer confusion, but because your other tires are ~2/3 worn out already. If you replace just one, then in in another 20K you'll be wondering whether to replace just 3. Treat your car to some new shoes...
Old 08-30-16, 07:14 AM
DM2
DM2's Avatar
Thanks everybody. Will change all of them.
Old 08-30-16, 08:10 AM
DJWLDW
DJWLDW's Avatar
Go with the Pirelli P7's you will love them.
Dennis
Old 08-30-16, 08:33 AM
comotiger
comotiger's Avatar
Yeah, I am worried about this in my case. I have three Michelin MXM4s that were installed about 20,000 miles ago by first owner. My 4th tire is a Michelin Pilot Sport that was probably installed about 9000 miles ago by the dealer I bought from. My spare is a Pirelli Pzero, and I don't know how old it is. All tires have lots of tread, and I am hoping to wait another 10-15K before changing all four. But I am wondering if I am doing any damage to the transmission. Car runs well and very smooth.
BTW, shouldn't we all be getting five new tires every time we replace?
Old 08-30-16, 08:46 AM
roadfrog
roadfrog's Avatar
Originally Posted by comotiger
Yeah, I am worried about this in my case. I have three Michelin MXM4s that were installed about 20,000 miles ago by first owner. My 4th tire is a Pirelli Pzero that was probably installed about 9000 miles ago by the dealer I bought from. My spare is another Pzero, but not the same model as the 4th tire, and I don't know how old it is. All tires have lots of tread, and I am hoping to wait another 10-15K before changing all four. But I am wondering if I am doing any damage to the transmission. Car runs well and very smooth.
Unless the tires all all different SIZES, no worries about any damage to your vehicle. As for getting 5 new tires......meh. I wouldn't. I've been driving for nearly forty years and I think I've had to use a spare twice. My spare only needs to get me to the nearest tire shop to fix the tire that went flat. Heck....most cars come with a temporary spare from the factory.
Old 08-30-16, 09:02 AM
comotiger
comotiger's Avatar
Thanks! Yes all tires are the same size. I guess I was wondering about the 5th tire because we have full size alloy spares that look like the regular wheel, unlike the temporary spare that is skinny or even a steel rim with the correct tire size. So, I was thinking people may install the 5th tire and not bother to but it back in the trunk after fixing the flat. Then again, as you say, I have also replaced a flat tire only twice in over 25 years of driving (I am a bit younger than you ), so it is best to keep the spare tire only for emergency use.
Old 08-30-16, 10:28 AM
Kennyr44
Kennyr44's Avatar
We had customers blow out their bevel gears (center diffs) in AWD Volvos by mismatching tires. 2k back then. Probably 10k to fix now.
Old 08-30-16, 10:40 AM
comotiger
comotiger's Avatar
The dealership I use made a note of the different tire during a recent multipoint inspection, but they did not recommend replacing all tires, or even that one to match the remaining three. The potential for problems could be worse by using a brand new tire with three that are about 20K miles older.
What would be the symptoms of drive train or center diff damage due to mismatched tires?
Old 08-31-16, 07:15 AM
seanl
seanl's Avatar
Yeah, there's no reason to buy 5 tires. That full size spare is good for at least 10 years, as others have said it's not like you're going to drive on it for more than a day or two.
I'm currently on Bridgestone Turanzas that the previous owner put on the car, I can't wait to get out of them....I will go with the much loved Pirellis P7s or possibly Michelins.
Unless you're running different tire sizes (diameter is what really matters) there is almost no chance that you're going to have diff. problems.
Old 08-31-16, 08:36 AM
enoch861
enoch861's Avatar
On AWD vehicles, if you're going to replace 1 tire, replace all 4. No need to replace the 5th unless you really want to. In fact many tire places I've been to with my Audi simply refuse to install just 1 tire even if it's the same brand and model. Could just be a Minnesota thing though and other states don't care as much.
Old 08-31-16, 08:42 AM
DJWLDW
DJWLDW's Avatar
enoch861
My son in Charlottesville, VA had the some problem at Costco on his 2015 AWD Ford Flex. Costco would not install just one new tire after his wife drove over something and trashed a tire. They would install a pair. I think the damaged tire had 12-13K on it.
Dennis
Old 08-31-16, 08:48 AM
comotiger
comotiger's Avatar
Originally Posted by DJWLDW
enoch861
Dennis
I did not notice that the 4 tires did not match when I bought the car a few months ago. Clearly, the selling dealer (in NJ) didn't care that they replaced only one tire. I will give them another 10K before changing. The Pirelli P7s seem to be the way to go!
Tcagle
05-29-18 04:18 PM
DP03
08-08-17 05:30 AM
psychodog7
Wheels, Tires & Brakes Forum
05-22-13 09:05 PM
bcg02
12-28-11 08:57 PM
pauljcl
05-21-11 11:09 PM
Quick Reply: Lexus LS 2012 AWD - ? New tires
