Poor man bluetooth
Old 08-28-16, 10:43 PM
GmanSC
GmanSC's Avatar
Default Poor man bluetooth
For those who don't want to spend couple hundred dollars for the DVD player with bluetooth, here is the option:
1. Monster cassette adapter 19 bucks
2. Bluetooth receiver 19 bucks
Connect the cassette adapter to the bluetooth receiver then pair your phone with the receiver.
Now you can listen to your favorite songs from your phone wirelessly.
One thing that I don't understand that while the bluetooth in the NAV only for the phone and not for the music, and the bluetooth receiver just for the music but not the phone. So you need both. Crazy huh?
Old 08-29-16, 09:23 AM
sideswipe
sideswipe's Avatar
OK..but how does it SOUND? And where did you purchase these items?
Old 08-29-16, 02:36 PM
Harold57
Harold57's Avatar
I don't understand this statement. Can you expound on it?
Old 08-29-16, 05:24 PM
Poqman
Poqman's Avatar
I think he means there are two Bluetooth protocols. My 2006 supported BT connection for the phone, but you could not stream music. I needed a VAIS Tech BT adapter to add A2DP protocol for streaming music.
Old 08-29-16, 07:14 PM
GmanSC
GmanSC's Avatar
The sound quality is superb (as long as you don't buy a cheap cassette adapter). You can get these items from EBay or Amazon.
Old 08-29-16, 07:59 PM
ShawnOk
ShawnOk's Avatar
I believe this concept is specific to each bluetooth device. My Arion dongle has both protocols, phone and music. So I can play music, change track, adjust volume to the ML headunit and take/make phone calls from it that will play through the car audio system, as it has its own built in microphone. So theoretically, the OP's description of needing two devices is due to the limited capabilities of each respective device. I'm sure I've read (actually on this forum if I recall correctly), of someone who posted a product that is a rechargable bluetooth cassette that connects to any bluetooth device and can supply phone and music playback protocol. Of course, none of the track remote buttons on the headunit or steering wheel will work, but the volume toggle buttons will work. Additionally, every time you want to change track, you would have to pull out your device. (Hehe that last sentence sounded dirty. )
https://www.walmart.com/ip/ION-ITR20...apter/39577143 (Doubt this one does phone protocol, so only music. But removes the need of two devices as stated by the OP). Fair priced.
As a side note, I don't understand why this turned out to be a new thread... there is an existing thread called POOR MAN'S AUX Input. This thread would have flowed nicely there but I digress.
Old 08-29-16, 09:12 PM
GmanSC
GmanSC's Avatar
Shawn,
First, Thanks for the Infos on the Bluetooth cassette. I didn't know such thing existed. I'd have saved 20 bucks. Second, the only reason I started the new thread cuz I thought the Bluetooth is completely differ from the aux. You're right, I could continue that thread. Thanks again.
ppineira
CT 200h Model (2011-2017)
06-16-15 11:12 AM
CG lover
01-26-07 10:28 AM
cmalley
10-16-06 08:31 PM
Lex7
GX - 1st Gen (2004-2009)
07-06-05 10:29 AM
Quick Reply: Poor man bluetooth
