Sport mode
Sport mode
Can someone tell me all the things that change when your in sports mode eg throttle response, gears steering etc the whole list would be good please ps did a quick search only found a little bit. cheers. and when i use the manual paddles (in manual mode)it holds that gear until i rev it to almost red line before it changes is this normal cheers
If you pull a paddle while in auto mode, the paddles become gear limiters. This means that you get to choose what's the highest gear the transmission will shift to. So if you choose 3 Rd, the transmission will shift 1, 2, 3rd gear and hold it there. The only thing I'm unsure in this mode is if it will shift up to the next gear if you take it to red line.
Slowly roll away from a stop in 'D' and downshift to '1' without engaging manual mode through the gear shift lever. Floor it and the transmission will shift into second gear once you reach the end of first.
Nope, there is no way to do that, also it is not a recommended as you should be turning on your sports mode when your oil temperature is about two bars or more. You will notice, when the car is cold and the sports mode is on, the transmission is holding the gears much longer than it should.
Tech Info Resource
There is no mechanical reason to wait to turn on Sport mode. There are lots of mechanical reasons not to beat on your engine with rpm over 3k when the oil is cold. The gearbox will self limit, and I have experienced this with both my F and my IS350. Lexus has done a lot to make it hard to hurt the drivetrain.
