Won't start after sitting for 2 days
My car sat for two days. I tried to unlock the doors and got nothing so I unlocked it manually. I had to give it a jump. I replaced my battery about 3-4 mos ago so I don't think that's it's. I must say I never had more problems with any other car I've owned. From day one its one thing after another.
Did you buy your car new or used? Just wondering if it might be a problem carryover from a prior owner.
What kind of battery did you put in it? A bad battery is possible.
Occasionally I leave the vehicle without it shutting completely off, there is a power on mode before engine ready mode, then finally engine on. Usually the car dings at me when it happens, one time I ignored it and the car wouldn't start the next morning. Had it jumped and it started right away, battery charged up and since then (2 years ago) no dead batteries. I have been careful to notice whether the car is completely off or not before I walk away.
Here's some reading for you about battery 'issues' in the GS 350:
► https://www.clublexus.com/forums/gs-...no-reason.html
► https://www.clublexus.com/forums/gs-...tery-dead.html
► https://www.clublexus.com/forums/gs-...ry-issues.html
► https://www.clublexus.com/forums/gs-...d-battery.html
► https://www.clublexus.com/forums/gs-...y-is-dead.html
► https://www.clublexus.com/forums/gs-...ery-drain.html
► https://www.clublexus.com/forums/gs-...ead-again.html
I had the same problem with my car a few months ago. Turns out there was a recall or TSB for one of the power control units that was defective. It would draw a small load even when the car was off causing the battery to die. I don't remember the exact name of the unit but if you search the forum I know there's a thread about it.
Redfire03
04-05-10 05:49 AM
