TMPS sensor
Old 07-26-16, 03:04 PM
waltsox
waltsox's Avatar
Default TMPS sensor
Using techstream software can I register a new tpms sensor, then have a tire place install it in the tire replacing the bad sensor then put the tire on the car and expect to work?? Or do I have to go through the whole process again?? Thanks Walt..... I did register a FOB and it worked beautifully..
Old 07-28-16, 09:50 AM
LexRuger
LexRuger's Avatar
As long as you upload the sensor id to the car, it should be fine.
Old 07-29-16, 02:27 PM
DenverRx
DenverRx's Avatar
Great Video on how to do this:
Old 07-30-16, 05:30 AM
waltsox
waltsox's Avatar
TMPS sensor-img_20160730_065444.jpgTMPS sensor-img_20160730_065145.jpgI agree whoever made that video did a fabulous job. I followed everything including the releasing of air from tires to determine which tire sensor was problematic. I then tried registering the tires but I didn't get a window asking which set of tires to use as in the video.I still registered he tires whithout that window just like in the video and when all four tires were registered i pressed next and then I got the message shown in the first pic and I dont know what to do. The second pic shows that the 4th tire sensor is a problem Anyone have any ideas?? Thanks
Old 07-30-16, 07:07 AM
waltsox
waltsox's Avatar
Has anyone connected wire TC to wire CG successfully in the DLC3 connector???? How safe is this??? Thanks Walt
7Train
05-17-18 06:51 PM
cwmoore
ES - 5th Gen (2007-2012)
12-21-17 11:56 AM
madouglas2
HS 250h Model (2010-2012)
06-26-17 07:35 PM
swooopeno
03-02-11 08:34 AM
ward1016
10-19-07 12:14 PM
Quick Reply: TMPS sensor
