Hesitation
Hesitation
Having hesitation at 2000 rpm like a bucking but if I let off or push on gas it go's away, my guess was a bad coil pack but its only throwing a maf sensors code any ideas?
I don't know about the bucking at 2000rpm but the MAF will affect the transmission and shifting. It might be bouncing back and forth between the convertor locking and unlocking. Clean it or replace the MAF. it really is a maintenance part and wears out.
Coil pack should trigger misfire.
Salim
Salim
Thanks for the quick responses I put a used maf sensor on bt the cel came back on it also checked the four of the six coils replaced the one that I thought was bad didn't work cell is back on today after work going to check vacuum lines.
My bet is the oil control valves. I had this problem a few years ago, but the error codes in the computer don;t indicate it. the OCVs do not have a feedback loop to the computer so if they act up you get weird error codes such as bad banks of coil packs, MAF sensor, A/F sensors on exhaust. There are several combinations of bad codes, depends on the bank and how bad it is malfunctioning.
I found a seller on ebay who was selling a pair of OCVs from toyota OEM for $75. It might be worth grabbing them now rather than wait and have to buy Dorman aftermarket parts.
armanxpm
02-24-10 11:04 PM
