2007 es 350 A/C vent issue
Old 07-24-16, 06:47 AM
mattward19
mattward19's Avatar
Default 2007 es 350 A/C vent issue
The driver side only blows hot air, the passenger side is fine. I believe a vent is stuck open. How can I repair. I cant seem to find a vent diagram online.
Old 07-27-16, 06:24 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
Have you tried cycling through all the air direction settings to see if it changes or possibly loosens up the vent damper? Do you have dual a/c settings? Are both sides set to the same temp?
Old 07-27-16, 08:47 PM
scfz1000
scfz1000's Avatar
same issue would love an answer from somebody
Old 07-28-16, 06:38 AM
Clutchless
Clutchless's Avatar
Look here http://www.lexussouthatlantaparts.com/
Also, when was your cabin filter last replaced?
Old 08-01-16, 02:03 PM
vdubill
vdubill's Avatar
Have seen this condition in my '07, inspected by the dealer and diagnosed with low freon due to a leak in the evaporator. Between 1200-1800 bucks to repair.
Old 05-03-17, 09:41 PM
Moon423
Moon423's Avatar
This seems like a recurring problem. Has there been any recalls on the ac?
Old 05-14-17, 03:26 PM
Franks87
Franks87's Avatar
Check the Expansion valve or Core evaporator???
From a same model:
EXPANSION VALVE ~|~SEE
HISTORY,AC BLOWS HOT OUT DRIVERS SIDE ,A LITTLE COOL FROM RT SIDE ~|~PARTS WARRANTY ~|~173020 DEFECTIVE EXPANSION VALVE 883601 64/50 FPN: 88515-33020 140 DEFECTIVE EXPANSION VALVE, FREON LINES UNABLE TO SEAL PROPERLY, REPLACED EXPANSION VALVE, AND ORINGS, ALLOWED 12 HOURS TO PASS CHECKED FOR LEAK AGAIN, EXPANSION VALVE FITTINGS NO LONGER LEAK
adreano17
06-22-11 12:52 PM
007
GS - 1st Gen (1993-1997)
05-14-07 10:15 PM
dannyypk
13
08-25-04 09:51 AM
mikelant
09-02-03 05:12 AM
Mouse
12-10-02 04:57 AM
Quick Reply: 2007 es 350 A/C vent issue
