SC300/SC400 OEM Subwoofer Question
Old 07-23-16, 10:16 PM
SaintLexus
SaintLexus's Avatar
Default SC300/SC400 OEM Subwoofer Question
Hi All,
I hope someone can chime in. But are the SC300 OEM subwoofers similar to SC400's OEM. I have a 1997 and posted earlier on SC's classified to look for a sub.
Main question is: are they as simple as a plug and play or will there be an incompatibility issue?
Old 07-24-16, 08:49 AM
t2d2
t2d2's Avatar
Aside from the Pioneer/Nakamichi packages, I believe some of the cars have an 8" sub instead of the 10". I would imagine the cutout is the same, though, and it's just a different mounting bracket to adapt to the hole.
Old 07-24-16, 09:06 AM
pogoism9
pogoism9's Avatar
My 95 sc4 had pioneer, it was an 8. I converted to nakamichi which was a 10. Same hole, different bracket
Old 07-24-16, 10:06 AM
t2d2
t2d2's Avatar
That settles that.
My '94 SC400 had the 10" Pioneer, assuming it was original to the car and not swapped by a previous owner. I'm not seeing a pattern to which cars got which.
Old 07-24-16, 10:38 AM
pogoism9
pogoism9's Avatar
Yeah no rhyme or reason. I do know that the Nak 10s are 5ohm. I reckon you could tell them apart that way
Old 07-26-16, 08:38 PM
matguy
matguy's Avatar
Nakamichi systems have a 5 ohm 10" sub. Pioneer systems with a CD changer have a 1 ohm 10" sub. Pioneer systems without a CD changer have a 2 ohm 8" sub.
The cutouts should be the same, but the factory amps are different (well, the Pioneer amp might actually be the same between the two different Pioneer systems, I haven't double checked; I have the Nakamichi system.) While you can swap OEM subs, physically, if you stay with the factory amp you can run in to either an underpowered sub (like 15 watts if you put the Nakamichi sub in to a Pioneer system) or a over-stressed amp that won't last long and won't sound good at all as it clips fairly quickly.
Old 07-26-16, 09:16 PM
t2d2
t2d2's Avatar
Aha, there is a pattern!
Old 07-26-16, 10:42 PM
SaintLexus
SaintLexus's Avatar
Default Ok so?
Ok... cool you guys.
Since I have my OEM head unit in So. Cal. (I'm in Nor. Cal. ... 6 hrs away). How can I tell that I either have the Nakamichi or Pioneer? I did/do still have the 6 CD changer in the back but had it disconnected since there's no need for it at this time. Hope this small info. helps. Again, I have a 1997 SC300.
Old 07-27-16, 10:36 AM
BrokeEF
BrokeEF's Avatar
The Nakamichi says it on the face of the deck.
Sean
Old 07-27-16, 10:44 AM
SaintLexus
SaintLexus's Avatar
Default ?
Any other way to tell? Also, I don't recall seeing Nakamichi on the headunit. So I'm assuming I have Pioneer. I just want to make sure I have the right OEM replacement.
Thanks again!
Old 07-27-16, 10:52 AM
t2d2
t2d2's Avatar
I haven't peeked behind the Nak, but all the Pioneer speakers I've seen have the brand stamped on the magnet.
Old 07-27-16, 10:58 AM
matguy
matguy's Avatar
If you pull the trunk liner out under the back window, you can look up underneath the rear deck and see the sub. The Pioneer subs have a semi bronze colored stamped steel basket, the Nakamichi subs are a composite material resembling black plastic. You could also look under the magnet and it should say either Pioneer or Nakamichi.
Old 07-27-16, 10:59 AM
SaintLexus
SaintLexus's Avatar
Default ok
Cool.... I'm just gonna take a peek on the sub. Thanks!
Old 07-27-16, 11:00 AM
matguy
matguy's Avatar
Actually, the Nakamichi doesn't actually say Nakamichi on it, but it will say 5 ohms (well, 5 and the ohms symbol.)
Sbenesh58 (07-09-20)
Old 07-27-16, 11:03 AM
SaintLexus
SaintLexus's Avatar
Default -
Nice! If I do find a replacement. Any tips on how to remove the sub. I noticed that it has to be done from the inside. I'll try "youtube" if there's any video.
Quick Reply: SC300/SC400 OEM Subwoofer Question
