01 RX300 only starts with code reader
Old 07-23-16, 03:23 PM
08X3
08X3's Avatar
Default 01 RX300 only starts with code reader
I have been having hard starts, now no starts unless my code reader is plugged in. Cranks but no start without code reader, with it in, Ill get is started albeit a tad rough at first then after warm up, runs and idles perfectly. Sometimes check engine light is on with P1760, P1656,P1351 then others no codes at all. I checked all the ground under the hood but I am afraid this is pointing to an ECU. Any ideas on problem or best source for another ECU? Thanks so much!!!
Old 07-25-16, 07:08 AM
salimshah
salimshah's Avatar
Have you had any water damage to the ecu area?
Salim
Old 07-26-16, 06:46 PM
carguy07
carguy07's Avatar
See if the OP in this thread figured it out: https://www.clublexus.com/forums/rx-...won-t-run.html
Old 10-29-16, 07:59 AM
Boypony
Boypony's Avatar
Bad ground. especially the big one behind upper intake.
jerryparks
11-02-13 11:53 AM
BigRon239
03-19-13 11:59 AM
phongX11
04-05-11 04:04 PM
GoldieLex
Performance & Maintenance
07-01-05 11:22 AM
Derf
11-10-04 11:35 AM
Quick Reply: 01 RX300 only starts with code reader
