LS400 Information (unconfirmed)
Old 07-23-16, 01:37 AM
dicer
dicer's Avatar
Default LS400 Information (unconfirmed)
UCF10 L - A E P G K A
(1) (2) (3) (4) (5) (6) (7) (8)
1 Basic model code UCF10: 1UZ-FE Engine
2 Steering Wheel Position, L: Left Hand Drive
3 Model Name A: Lexus
4 Body Type E: 4 - Door Sedan
5 Gear Shift Type P: 4 - Speed Automatic, Floor
6 Grade G: Base
7 Engine Specification K: DOHC and EFI
8 Destination A: USA
Body
Rust resistant steel
Two types of rust - resistant steel are used; Galvannealed steel sheet and Excelite II. Galvannealed steel sheet is used on inner panels, floor panels, and other places. Excellite II is used for outer panels like the doors, hood, and trunk lid. Excelite II is made by the formation of a zinc-rich layer, creates good adhesion on the outer panels.
Wax and Sealer use.
Wax is applied to the inside of the seams of the hood, doors, and other panels to stop the ingress of water and improve rust - resistantance. Filling the seams with adhesive also acts to seal the sections .
Under Coat
PVC ( Polyvinyl Chloride) coatings are applied to most of underside of the body.
Four Layers Of Weatherstripping, are used.
Vibration Dampening Materials and Sound Absorbing Materials are used.
Reduction of Clearance Between Body Parts, to improve appearance and reduce wind noise.
Body Paint MIO (Micaceous Iron Oxide) paint, There are 6 layers above the sheet metal, 1 is Under coat, 2 is Primer surfacer, 3 is color base, 4 is MIO base, 5 and 6 are 2 layers of clear. 2 tone color is used for main body and for the side protective moldings, and front and rear bumpers, to provide 2 tone exterior coloring (except when deep red mica is used)
The antenna for the wireless door lock is the rear window defogger wiring. Range of operation with in about 3.3 ft of the driver door.
If none of the doors are opened with in 30 seconds after they are unlocked by the wireless door lock remote control, all doors are locked again automatically.
So the site formats the locations way off for the UCF stuff above.
The drag coefficient for the LS400 is .29, which is very good aerodynamic efficiency.
0 to 60 time 7.9 seconds.
Old 07-23-16, 11:04 AM
Stereorob
Stereorob's Avatar
ok you covered a lot. heres me go at it.
Lexus LS 400, model year 1990, UCF10, Production date started August, 1989, however there was a test batch put out 2nd quarter of 1989, but ive never been able to locate one of them.
  • 4-door sedan body type
  • RWD (rear-wheel drive), automatic 4-speed gearbox / overdrive and Power mode, ECT adaptive transmission
  • Gas engine with displacement: 4 liter 242 cui, advertised power: 249 hp / 253 PS ( SAE net ), Torque net: 260 lb-ft
  • characteristic dimensions: outside length: 196.7 in, wheelbase: 110.8 in
  • reference weights: base curb weight: 3759 lbs
  • how fast is this car ? top speed: (150 mph) electronically governed (declared by factory) but ive personally seen them do 155 and 160 MPH (in good running order)
  • accelerations: 0- 60 mph 7.9 s, 8.2 s (declared by factory), 1/4 mile drag time 15.6 s (simulation ©automobile-catalog.com)
  • fuel consumption and mileage: 18/23 mpg (U.S.), 121.5/27.5 mpg (imp.), EPA ratings average estimated by a-c: 15.2 mpg
  • Optional Active adjustable electronic Air suspension with height control, sport mode, and speed sensing technology
  • Open Differential
Electronics/Telematics
Electroluminecsent gauges, (florescent bulbs) w / reverse projected Idiot lights, Roll odometer (90-92) digital (93-94)
Optional hard wired analog Cellular Telephone w/ soft touch buttons and red LED display, mounted in center console, rear glass whip antenna, RF interface in trunk, steering wheel mounted controls.
digital electronic climate control w / beep confermation, dual zone climate control
Optional heated seats, memory seats, power adjustable seatbelt pretentioners, Intuitive Traction Control, Power glass moonroof, Leather interior, automatic dimming rear view mirror
Built in wireless access lock/unlock and panic from Key fob, Laser cut key, range of about 4 feet. Adjustable Lock/Unlock feedback tone (in some areas)
standard Pioneer 200 watt 7 speaker stereo cassette system with 4" full range drivers in each door, 2 2" soft dome tweeters, 8" power subwoofer in rear deck with amplifier mounted in trunk, optional 6 disc magazine changer on right side of trunk.
Optional High Performance Nakimichi 500 watt 7 speaker system w/ 6 disc cd changer, Power Amplifier mounted under rear seat
Old 07-23-16, 02:12 PM
dicer
dicer's Avatar
Maybe Trivia was not the correct word to use. Please keep more good stuff coming .
Old 07-25-16, 04:24 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
Yeah none of this is Trivia.
Unless sources are provided it's literally all just hearsay.
Old 07-25-16, 05:14 PM
dicer
dicer's Avatar
I can't change it that I can see. Please change the title to something more appropriate.
981uz
17
11-08-16 06:47 AM
SLORICK
03-16-10 03:03 PM
rustylexus
92
02-20-09 06:05 PM
OGS
Automotive Care & Detailing
22
09-22-05 08:24 PM
Quick Reply: LS400 Information (unconfirmed)
