Video comparo - stock exhaust vs JoeZ exhaust
Old 07-21-16, 08:18 PM
myidsucks
myidsucks's Avatar
Default Video comparo - stock exhaust vs JoeZ exhaust
I decided to go with the JoeZ exhaust on my car because I knew it would fit with the TVD. I shot a before and after video on my iPhone to give you guys an idea of the sound difference between stock and JoeZ. The car sounds better in person than on the video but since there's a before and after clip, at least it's apples to apples.
Stock:
JoeZ:
Old 07-21-16, 08:44 PM
MWIS350
MWIS350's Avatar
Look and sound great.
Old 07-21-16, 09:01 PM
johnnyreb
johnnyreb's Avatar
Definitely sounds alot better, it may be just me but it seems like the tubes are hanging a lil' lower than the stock ones (maybe it's just the angle of the pic) if they are just get you some Rear Diffusers & you couldn't even see them. Only other thing i'd do is paint the mufflers black so they're not so noticeable. Sounds Great though! jmo
Old 07-21-16, 11:06 PM
estoyf
estoyf's Avatar
Good vids. A few members painted the mufflers black to keep the stock look including myself. Looks good either way though.
Old 07-22-16, 07:22 AM
Ne1tHeRe
Ne1tHeRe's Avatar
Looks so much better painted! Only thing is I wish it came with oval tips. Great sounding exhaust for sure and it was my second choice over my current exhaust.
Old 07-22-16, 08:02 AM
myidsucks
myidsucks's Avatar
My wife said the same thing about the mufflers not being black; I can live with it either way although I wish the tips matched the stock tips.
For the guys that painted the mufflers: did you do it post-install? If not, did you use a rattle can of high-temp paint or a brush-on can?
Old 07-22-16, 08:31 AM
Ne1tHeRe
Ne1tHeRe's Avatar
I used high temp black spray paint when mufflers weren't installed yet. As you can see below, I only painted the rear face of the muffler cans.
Going to be very difficult to get it nicely covered black when it is on the car and you really don't want the over-spray everywhere. Since it is already installed, better to go with brush on if you are leaving it on the car. Just make sure it is thoroughly dried before you get those mufflers hot. Good luck!
Old 07-22-16, 08:47 PM
johnnyreb
johnnyreb's Avatar
^^^^what he said, you really don't need to paint the whole muffler just the end of them cause that's the only part you see from behind. & i also agree about the oval tips looking better! jmo
Old 07-23-16, 02:51 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
JoeZ adds the extra smooth growl without going over the top. Very refined and well suited to this car. Enjoy!
Old 07-24-16, 05:15 PM
Fysisist
Fysisist's Avatar
I pulled the axle back parts (the mufflers) of the Joe Z exhaust and then it's a simple job to spray paint the whole muffler or however you want to do it. Just a cautionary note - you have to be careful not to put it back together such that the mid-pipe section rattles against the frame which is what happened when I did it. So then I had to lift the car again, loosen the bolts that hold mufflers to mid-pipe and adjust to eliminate the rattle. I'm happy with the Joe Z but also would have liked the oval tips. Performance-wise, you lose one catalytic converter on each side from the OEM so less back pressure I'm sure.
Old 07-24-16, 07:36 PM
myidsucks
myidsucks's Avatar
I ended up getting a can of hi-temp paint, masking the heck out of everything and brushing the black on.
Old 07-24-16, 07:38 PM
estoyf
estoyf's Avatar
How's it look? Pics?
Old 07-24-16, 08:53 PM
myidsucks
myidsucks's Avatar
Came out pretty good...
Old 07-29-16, 09:16 AM
GGawaran
GGawaran's Avatar
Does the system trigger and CELs?
Old 07-29-16, 10:08 AM
myidsucks
myidsucks's Avatar
I can't speak for everyone but it certainly has not triggered any CELs on my car.
Quick Reply: Video comparo - stock exhaust vs JoeZ exhaust
