ES250-1990 - need right front ABS wheel speed sensor
Old 06-20-16, 09:16 AM
ES2501990
ES2501990's Avatar
Default ES250-1990 - need right front ABS wheel speed sensor
Hi all,
I have a Lexus ES250 - 1990. I am in need of an ABS wheel speed sensor right front. Any help. Dealer could not get one. Thanks.
MJ
Old 06-20-16, 06:00 PM
tomf
tomf's Avatar
Try RockAuto.com . they have them in stock
Old 06-20-16, 10:04 PM
Received 2,700 Likes on 2,286 Posts
I bought one awhile back from Rockauto.com it has been working fine I had the same one fail front right. I highly recommend you replace the wheel bearing as well the ABS sensor likely went bad because the bearing is getting hot and cooking the sensor. I've seen several ES250's and Camry's with the same problem bad bearing and sensor same location.
Old 07-23-16, 02:34 PM
ES2501990
ES2501990's Avatar
Thank you for the information.
Old 09-25-16, 10:09 AM
ES2501990
ES2501990's Avatar
Default Unfortunately Rock Auto is out of stock
Rock Auto is out of stock on this part. I signed up for email notification when it is available, but it is still out of stock. Any ideas for another source? Thank you. MJ
Old 09-25-16, 10:13 AM
ES2501990
ES2501990's Avatar
I did see a part on Ebay that says "right abs wheel speed sensor", but it does not specify front or rear ? Is the"right front" and "right rear" the same part ?
Old 09-25-16, 10:20 AM
This seller claims to have two of them if so buy quick there are hardly any of these remaining. Front and rear and completely different sensors.
http://www.ebay.com/itm/262468628963
Old 10-12-16, 03:16 PM
ES2501990
ES2501990's Avatar
Thank you. I am waiting for a response from the seller. Is the right front part the same as left front? The Ebay listing only says FRONT. Thanks again.
Old 10-12-16, 03:39 PM
Look under item specifics is says front right also the cross reference part number 89542-32010 on that listing is the front right sensor. Highly recommend you replace the wheel bearing as well.
Old 10-12-16, 11:32 PM
ES2501990
ES2501990's Avatar
Thank you !!
Old 10-13-16, 06:07 AM
ES2501990
ES2501990's Avatar
I'm back to the drawing board. Although the item is listed on Ebay, it is not in stock. I also tried ******************.com and carparts.com with no luck. Any suggestions ? Thank you.
MJ
Old 10-13-16, 10:10 AM
Give this place a call
If they don't have it then don't know can't find this sensor anywhere.
Old 10-20-16, 07:37 AM
ES2501990
ES2501990's Avatar
Thank you so much for all of your help. I placed the order and hope that I don't get an email saying the part is not in stock. Thanks again Lexus2000.
MJ
Old 10-21-16, 10:53 AM
ES2501990
ES2501990's Avatar
Well, I got the email that the part is not in stock. I'm not into restoring cars, but I am just wondering how would someone restore this car, if parts are not available.
MJ
Old 10-21-16, 11:25 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
Have you tried some of the OEM discount places such as www.lexuspartsnow.com or www.mylparts.com or http://parts.autonationtoyotasouthau...-v6-gas-engine
Quick Reply: ES250-1990 - need right front ABS wheel speed sensor
