Sway Bar end link replacement
Old 06-07-16, 06:34 AM
99rx
99rx's Avatar
Default Sway Bar end link replacement
Does anyone have any helpful hints on putting new sway bar end links on the front? I attempted to do the job and upon trying to loosen the nut holding it on, it just spins the entire ball within the link. I've sprayed everything with penetrating lubricant with no success. Anybody have any idea how to keep the ball from spinning and get the nut off? Upon fooling with it, I've caused there to be a lot of play within where it mounts, so when I do drive now, I get a lot of clunking where it's metal/metal. So any help would be greatly appreciated! Thanks!
Old 06-07-16, 07:52 AM
oldManTan
oldManTan's Avatar
there's an allen wrench hole in the front of the bolt idk if you noticed, you're supposed to put an allen in there and then you use an open end wrench to loosen the nut. most of the time though the allen end is completley rusted and trying to get an allen in there without stripping it is a pain, that's why i say just cut the link off completely, that's what i had to do on both ends of my car, it sucks lol.
Old 06-08-16, 11:14 AM
99rx
99rx's Avatar
Yeah I tried that and it stripped out almost instantly. What did you use to cut them off, and where did you cut them?
Old 06-08-16, 02:53 PM
CatManD3W
CatManD3W's Avatar
When I had to replace mine...I had to cut them off ....nuts were stripped and allen key was stripped...
I used a saw-zaw.....to cut if off on link ends....
Replaced them with MOOG end links
Old 06-08-16, 02:56 PM
1A1
1A1's Avatar
Saw zaw or cut off wheel.
Steve
Old 06-08-16, 04:23 PM
Blkexcoupe
Blkexcoupe's Avatar
Is it stripped on the sway bar side or the shock bracket side? If you can remove the sway bar side, then I would recommend removing the shock bracket and cutting it off the car.
I was able to loosen mine a little by hammering a larger SAE allen head socket into the head of the endlink, then after I got some space a I cut it off using a reciprocating saw and sharp metal blades.
If I were to do it again, then I would try using a cut off wheel and cutting a slit into the nut, so I could hammer a screw driver in there and split the nut.
Old 06-09-16, 11:22 AM
oldManTan
oldManTan's Avatar
i used an angle grinder
Old 06-10-16, 05:51 AM
99rx
99rx's Avatar
Thanks for the advice! I'm gonna try it this evening after work. I don't drive it much (couple times a month) but it's been driving me crazy!
Old 06-11-16, 12:50 PM
99rx
99rx's Avatar
I worked on it this morning! Damn what a pain in the butt. I wasn't able to cut it on the side of the nut, So I was using a Roto-Zip and had to cut on the other side towards the boot. When you do it that way, you have to make sure you cut the lip on the link as well otherwise it won't slide through. It took forever, but no more clanking and noises! MAKE SURE TO GET MOOG LINKS. They fit perfect and they are the right size. I originally had ACDELCO (don't ask why), and they are HUGE. Much longer and thicker and don't work at all! I'll be emailing them and informing them of that issue. But otherwise a success. Thanks for the advice everyone. Next will be the power steering rack bushings, any recommendations for brands?
Old 06-11-16, 10:12 PM
Blkexcoupe
Blkexcoupe's Avatar
Glad you were able to get the endlinks off.
Any brand will work for the steering rack bushings. Whiteline, super pro, or battle version solid aluminum mounts if you want a solid feel.
Old 06-14-16, 09:42 AM
oldManTan
oldManTan's Avatar
i like my whiteline bushings, feel great, easy to install, took 10 minutes.
Old 08-25-16, 02:59 PM
DA51
DA51's Avatar
The rear sway bar links are the same setup. I've got a new Milwaukee Diamond Grit 6" sawzall blade. You will need it to cut through the suspension bushings because most of the bolts are rusted inside of every bushing (unless you live outside of the Salted Roads). MOOG parts are twice the thickness of OEM part. I use rockauto.com for most parts
Lexus did not do us any favors with their OEM parts. No corrosion resistant coatings on any exposed parts.
Old 09-03-16, 06:45 AM
emLEX
emLEX's Avatar
Agreed. This has been something I've always disliked abot Toyota/Lexus. Friends who also have or had them and lIke to work on their own cars also agree.
98GSOwner
Suspension and Brakes
03-20-18 01:49 PM
08ES350oh
ES - 5th Gen (2007-2012)
08-16-15 07:29 AM
lexusben
25
07-12-15 06:24 AM
VTsuckah
02-13-15 06:44 AM
amul
09-18-06 06:19 AM
Quick Reply: Sway Bar end link replacement
