3M Reflective Red Brake Caliper Vinyl Wrap
Old 04-10-16, 12:26 AM
jaywuzhere
jaywuzhere's Avatar
Default 3M Reflective Red Brake Caliper Vinyl Wrap
I decided to try and some reflective vinyl to my calipers today. I first tried to wrap the entire caliper from a single sheet, but found it impossible and temporarily gave up. If broken down to 2 (or more) sections, the job becomes a lot easier. All I did was spray the caliper with brake cleaner and wipe, isoprohyl alcohol and wipe, and then begin the wrapping. You will need a heat gun (~180 F) or a hair dryer I hear works as well. Once the vinyl was finished, I added the lexus decal and then added a clear coat of VHT high temp
These are my results:
Its not perfect, but I'm happy with the results. Hope this helps someone out there since I only saw a tutorial of hope to wrap the rear calipers (which I hear is a lot easier)
The following 3 users liked this post by jaywuzhere:
and3re (04-27-17), diamente (07-31-18), louczar (04-18-18)
Old 04-10-16, 06:30 AM
ALE81
ALE81's Avatar
Wow, nice job! Do you have a link to the 3M material? Thanks for the tutorial.
Old 04-10-16, 07:11 PM
jaywuzhere
jaywuzhere's Avatar
ALE81 Wow, nice job! Do you have a link to the 3M material? Thanks for the tutorial.
http://www.metrorestyling.com/Red-Br...3m-ref-red.htm
*** I got 2x4' (I got extra since I never installed vinyl before and expected to make mistakes). 2x2' is likely all you need if you're experienced installing vinyl ***
High Quality Felt Edge Squeegee 4 Inch
http://www.metrorestyling.com/High-Q...-p/feltsqg.htm
VHT SP730 Gloss Clear Brake Caliper Paint Can - 11 oz.
http://www.amazon.com/VHT-SP730-Gloss-Clear-Caliper/dp/B000CPJLV2?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 http://www.amazon.com/VHT-SP730-Gloss-Clear-Caliper/dp/B000CPJLV2?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Lexus Brake Caliper Decal
Ebay: Just search for Lexus Brake Decal. After you've applied the decal, just give a quick coat of the VHT SP730 clear coat of the decal and vinyl. Dont go too crazy with it. A light coating is all ya need
Old 04-10-16, 10:41 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
I tried this before on my ISF and the caliper is a lot bigger and shaped differently so I gave up. haha!
-Josh
__________________
Orange County, CA
Text/Call: 213 394 2886
Old 04-11-16, 06:14 AM
NjDude
NjDude's Avatar
Nice, wonder if this comes in bright yellow?
Old 04-11-16, 05:15 PM
jaywuzhere
jaywuzhere's Avatar
They make Yellow
http://www.metrorestyling.com/Yellow...3m-ref-ylw.htm
Old 04-11-16, 05:25 PM
mjeds
mjeds's Avatar
pretty neat..
Old 04-11-16, 08:42 PM
Radical350
Radical350's Avatar
Looks great! Thanks for the pics.
Old 04-12-16, 05:13 AM
NjDude
NjDude's Avatar
Originally Posted by jaywuzhere
Awesome, thank you for the link.
Old 04-12-16, 11:32 PM
jaywuzhere
jaywuzhere's Avatar
Finished up the rears and decided to post if anyone might be interested.
The following 2 users liked this post by jaywuzhere:
Old 04-13-16, 04:34 AM
danh63
danh63's Avatar
Very nice!
Old 04-20-16, 10:30 PM
Fsportme
Fsportme's Avatar
Looks great I plan on doing this instead of painting. How many feet do you need to do all four calipers?
Old 04-20-16, 11:25 PM
jaywuzhere
jaywuzhere's Avatar
If you're very experienced at installing vinyl, then a 2x2' (24"x24") sheet is all you need. However, because i'm a noob and I knew I was going to make a mistake, I purchased more than I needed. I even added them to my tire valve covers lol
Old 04-22-16, 06:08 PM
LxsCf RCF
LxsCf RCF's Avatar
Default 3M brake caliper wrap
Looks good, I just placed an order. Is there a video on how to install it ?
Old 04-23-16, 10:41 PM
jaywuzhere
jaywuzhere's Avatar
and3re (04-27-17)
Quick Reply: 3M Reflective Red Brake Caliper Vinyl Wrap
