Eco, Normal or Sport? (preferred mode)
Old 04-06-16, 01:26 PM
sirtiger
sirtiger's Avatar
Default Eco, Normal or Sport? (preferred mode)
Which mode does everyone drive their RX on?
Been trying this Eco mode for a week...Pretty blah. I drive mostly very local and pushing about 16mpg...about the same as the 3RX
sirtiger is offline
Old 04-06-16, 01:30 PM
sandy14
sandy14's Avatar
Sport. Mostly local. Haven't really checked the mpg.
The sport mode just seems to have more oomph.
sandy14 is offline
milk659 (02-19-20)
Old 04-06-16, 01:31 PM
RXOwner
RXOwner's Avatar
Normal 90% of the time.
Sport when extra performance is wanted or required.
Eco, useless. Keeps the RPM way too low. Well I guess if you only had a gallon of fuel and 35 miles to the next station, but Eco is great for that Sunday drive with the family when you have no where to go.
RXOwner is offline
milk659 (02-19-20)
Old 04-06-16, 01:40 PM
sirtiger
sirtiger's Avatar
with this 8 speed, the RPM always seem ridiculously low.
I don't think this Eco really saves much gas if any...I have to mash the pedal if I really want to haul it.
sirtiger is offline
Old 04-06-16, 06:25 PM
Legolas2
Legolas2's Avatar
In the settings menu, if I turn-off ECO is only the LED notification turned-off or it never uses ECO mode?
Legolas2 is offline
Old 04-06-16, 08:09 PM
darkoozy
darkoozy's Avatar
That only turns off the LED notification. ECO mode is selected by the driver, so you dont have to use it as a driving mode.
darkoozy is offline
Old 04-06-16, 09:08 PM
noeldavid
noeldavid's Avatar
He means the ECO green light that is located at the left side of the screen behind the wheel that turns on when you press lightly on the gas pedal.
How can you leave SPORT mode permanently ON ? Do you really have to manually set it everytime you turn on your car? I am getting better gas mileage on SPORT than ECO and Normal, but someone suggested it is due to the differences of winter and summer gas.
1st tank 15.6 Normal mode OEM gas
2nd tank 16.2 Eco mode 7-Eleven regular gas
3rd tank 15.5 Eco mode Racetrac regular gas
4th tank 16.5 Eco mode 7-Eleven Regular gas (switch to 20" and 38 psi from 18" and 33 psi)
5th tank 18.3 Normal mode 7-Eleven regular gas (75% tank=13 gallons and 245 miles = 18.8 mpg
6th tank "20.1" so far few miles driven Sport mode 7-Eleven regular gas
noeldavid is offline
Old 04-06-16, 09:48 PM
dchar
dchar's Avatar
You can't leave Sport mode permanently on, and you'll need to activate it every time. EPA tested the car in Eco and Normal, so that's why the car has to default in these modes.
dchar is offline
Old 04-07-16, 01:52 AM
RXOwner
RXOwner's Avatar
Eco "should" always yield better mileage but your foot makes the biggest difference. You can come close to the same in normal with a light foot. Eco also adjust the ac compressor programming to save additional fuel. To me Eco is not an option and normal is best for everyday use.
Many say you have to train your transmission, I think the 4RX tranny taught me.
RXOwner is offline
Old 03-26-17, 05:34 PM
Kajnbabe
Kajnbabe's Avatar
I just started driving in the sport mode b/c the car runs better than eco. I've even use the normal. Everytime I get in car I have to change the mode b/c it's always on eco. I'd prefer it to default to normal if it's possible...Anyone know? And is there a way to set my RPM higher than 2000? Does your green eco light stay on while your driving in normal mode?
Kajnbabe is offline
Old 03-26-17, 11:59 PM
msh3l
msh3l's Avatar
I usually drive in normal mode with suspension tuned to sport, you do this customisations from settings.
msh3l is offline
Old 03-27-17, 01:49 AM
ggebhardt
ggebhardt's Avatar
i never use eco mode, just a gimmick. You vehical will default to normal if you put it in normal and leave it there. I prefer the comfort mode unless Sport in required. The vehicle will default back to eco, normal or comfort when restarted depending on where you left it when you shut off the motor.
The green eco light has nothing to do with the different modes. It just tells you that your foot is behaving.
ggebhardt is offline
Old 03-27-17, 01:50 PM
FastFord
FastFord's Avatar
After doing the hesitation TSB, I use normal with the occasional custom mode. Normal drive, sport suspension.
Before the hesitation, almost always eco and got worse mileage.
I believe that the 17 RX stays in the mode you left it...maybe a 17er could verify that...
FastFord is offline
Old 03-27-17, 09:15 PM
dchar
dchar's Avatar
Incorrect...It will only stay in Eco or Normal after each cycle.
dchar is offline
Old 03-28-17, 04:51 AM
FastFord
FastFord's Avatar
I think that's only for the 2016 models. I had a 2017 out a few weeks ago and thought it stayed in the mode you left it...wasn't sure if I forgot what mode I left it in. I asked the salesman yesterday and he told me in 2017 it does stay in the last selected mode....wish I had that!
as per Lexus..."Drive Mode Select
Lexus RX’s Drive Mode Select gives improved acceleration and steering performance with three distinct drive modes – Eco, Normal, and Sport S Modes – to match your mood and the terrain. F SPORT Series 3 package adds an additional Sport S+ Mode as well as Customize Mode, which enables the driver to adjust the operation of the powertrain, chassis and air conditioning functions according to personal preference. For your convenience, the last selected mode is memorized when you start your car, tailoring your drive to your desire."
FastFord is offline
Quick Reply: Eco, Normal or Sport? (preferred mode)
