ES-350 Air Fuel and Oxygen Sensor Info
Old 07-18-15, 07:48 PM
Cjet
Cjet's Avatar
Default ES-350 Air Fuel and Oxygen Sensor Info
Thought this may help others as others have helped me out on this forum.
Lexus 2007 -2012 Air/Fuel (A/F) and Oxygen (O2) Sensor Guide
This bulletin contains information that identifies engine bank 1 and engine bank 2 on
the following engines: 2GR–FE, 2GR–FSE, 4GR–FSE, 2JZ–GE, 1MZ–FE, 3MZ–FE,
1UR–FSE, 3UR–FE, 1UZ–FE, 2UZ–FE, and 3UZ–FE.
TERMINOLOGY:
�� Bank 1 (B1) refers to the bank that includes cylinder No. 1.
�� Bank 2 (B2) refers to the bank opposite bank 1.
�� Sensor 1 (S1) refers to the sensor that is located before the catalytic converters.
�� Sensor 2 (S2) refers to the sensor that is located after the catalytic converters.
Terminology Continued ---
There are a total of 4 oxygen TYPE sensors. TECHNICALLY, they are:
(2) Air/Fuel (A/F) sensors located on the exhaust manifold, 1 per bank. Also called “Upstream”.
(2) Oxygen (O2) sensors located AFTER the engine mounted catalytic converters, 1 per bank. Also called “Downstream”.
Bank 1 (B1) is located nearest the firewall. Also called “Right”.
Bank 2 (B2) is front of engine, also called “Left”.
Ex. If you need to replace the Bank 2, Sensor 2, you would look for an O2 sensor, B2S2, Downstream, Left.
If you need to replace Bank 1, Sensor 1, you would look for an A/F sensor, Upstream, Right. B1S1, OR (see note below) look for an O2 sensor, Upstream, Right.
Note: When looking for replacement parts, be aware that the term “oxygen sensor” or “02 sensor” is a broad term used by some part companies to also describe the “air fuel sensor”, so double check the part. “Upstream” for the ES-350 means an Air Fuel A/F sensor, though some companies will call it an O2 sensor.
The following 4 users liked this post by Cjet:
99RX300PDX (11-15-21), Funkdawg (03-17-22), Pebblebeac (08-29-22), User 122922 (03-23-22)
Old 07-18-15, 07:53 PM
Cjet
Cjet's Avatar
Default Continued
The following 2 users liked this post by Cjet:
Old 07-18-15, 07:55 PM
Cjet
Cjet's Avatar
Default Location of Left and Right Upstream Sensors #1. B1S1 and B2S1
Old 07-18-15, 07:56 PM
Cjet
Cjet's Avatar
Default AF/O2 Sensor ES-350 Quick Reference Chart
The following 3 users liked this post by Cjet:
Funkdawg (03-17-22), Local500 (12-08-16), Pebblebeac (08-29-22)
Old 07-18-15, 08:54 PM
Cjet
Cjet's Avatar
Default Location of Left and Right Downstream Sensors #2: B1S2, B2S2
azfj60 (07-07-21), Pebblebeac (08-29-22)
Old 08-15-16, 11:07 AM
TLPLEXUS
TLPLEXUS's Avatar
Just want to say thank you for your post here. This help me tremendously at identifying and resolving the O2 sensor issue.
Old 09-26-16, 12:01 AM
Cjet
Cjet's Avatar
Glad you were able to use it! Hope it saved you the time and frustration that I went through.
C.
Old 09-26-16, 12:36 PM
Blue Moose Engineering
Former Sponsor
Blue Moose Engineering's Avatar
This is a really good post. Just identifying Bank 1 vs Bank 2 is probably very helpful for a lot of people.
Old 09-26-16, 12:37 PM
Former Sponsor
Also, did you take these pics on your own car? Thing looks like it has 50 miles on it.
Old 11-17-16, 01:22 AM
Cjet
Cjet's Avatar
Wow, never saw this until now. Yep, my own car. It now has 99,000 miles. It had about 74K on it when the pics were taken.
Old 04-02-17, 03:12 PM
SteffieK
SteffieK's Avatar
Thanks for all the pics above. I just bought my 08 ES 350 and was trying to figure out where B2S2 was located and how to replace it. Your pics were spot on to what I have found when looking at my engine.
Question, and I am taking a gamble you will get this since the thread is a little aged. :-) Did you have to remove the carpet, console, and seat to replace? From where I'm lying, I can unscrew the sensor and pop the plug at the other end, screw and pop back in, and I am finished. Am I simplifying this too much? All the videos and other threads I watched/read seemed so labor intensive and lots of disassembling. Although not a trained mechanic, owning used cars my entire life, I know my way around an engine. My current plan is to do the above (plug and play) and if that doesn't work, continue with the wiring harness end of the plug in that appears to lie under/near the carpet/console area.
Thanks again for the pics! Very helpful to this chic!
Old 03-10-18, 09:50 PM
Cjet
Cjet's Avatar
SteffieK, I apologize for not replying soon, as I never received a notice that you had posted a question. I just happened to look at this again today (almost a year later) to find your question, which by now, I am sure you have answered.
How difficult it is to remove depends on which sensor is bad. That said, there should be NO reason to remove anything in the interior of the car, as the sensors are all accessible from the engine compartment or under the car. Looking back at what I posted, I should have stated that the sensor by the firewall was the most difficult BECAUSE you have to either go up under the car between the firewall and the engine, or take the top cross bar off to get access it from the top of the engine. Either way, it is a p.i.t.a. I hope it was an easy to access sensor fix for you.
Also, anyone else reading please note that since this was posted a few years ago, another member mentioned in a different post that DENSO changed the part number of one of the sensors, so be sure to know the exact location and name of the sensor you need.
bucfan22 (03-12-18), Funkdawg (03-17-22)
Old 04-11-18, 10:33 PM
Cjet
Cjet's Avatar
For a more detailed explanation of air/fuel and oxygen sensors, and their associated codes, check out this great article. http://www.testroete.com/car/Toyota/...Control/19.pdf
hisstojay (04-12-18)
Old 04-12-18, 08:20 AM
hisstojay
hisstojay's Avatar
Cjet, Thanks for this!!!!! Very informative and precise.
Old 03-16-19, 01:02 AM
Habir
Habir's Avatar
Default Bank 1 and Bank 2 error codes
TERMINOLOGY:
I have a 2007 Lexus GS 350 my service enigine light is on and I had multiple error codes I changed my mass airflow sensor now I have 2 codes 1 is for catalytic bank 1 and the other is for bank 2, is there any other way I can fix this problem with out shelling out 2500 to the dealer?
Quick Reply: ES-350 Air Fuel and Oxygen Sensor Info
