What Have You Done To Your RC F Today?
Old 05-28-15, 12:13 PM
RCFormante
Supercharged!
RCFormante's Avatar
Default What Have You Done To Your RC F Today?
Just ordered the Rotora Carbon Ceramic Brake System with Red Calipers and it should be installed on the car within the coming weeks!
LEXUS RC F BRAKE SPECIFICATION:
Front: Forged 8-Piston Caliper/405x36mm
Rear: Forged 4-Piston Caliper/380x32mm
45 lbs. Weight Reduction (compared to OEM brakes)
RCCBS (CARBON-CERAMIC) STANDARD COMPONENTS: (PER AXLE)
A SET OF FORGED ALUMINUM, LIGHTWEIGHT CALIPERS: WITH DUST BOOT SEALS
A SET OF CARBON FIBER REINFORCED SILICON CARBIDE (C/SiC) DISCS: CONTINUOUS FIBER CONSTRUCTION WITH FRICTION LAYER
A SET OF FORGED ALUMINUM HATS (6061-T6, BLACK ANODIZE FINISH) WITH ANTI-RATTLE FLOAT DRIVE HARDWARE
A SET OF ALUMINUM (7075-T6) CALIPER BRACKETS, WITH HARDWARE
A SET OF STAINLESS STEEL BRAIDED BRAKE LINES (DOT COMPLIANT), WITH HARDWARE
A SET OF C2 STREET/LIGHT-TRACK COMPOUND FORMULATED SPECIFICALLY FOR RCCBS
Old 05-28-15, 01:17 PM
6i9
6i9's Avatar
Replaced Brembo with Rotora...
I had a friend that wrecked his Subaru on track because of a Rotora BBK failure. Sure it's anecdotal but I wouldn't trust that brand over a proven Brembo package. If you were looking for better stopping power, I'd simply replace the pads and maybe the rotors, and paint the calipers for show if you are inclined.
But to each their own
Old 05-28-15, 02:16 PM
Z3NK1
Z3NK1's Avatar
I tip my hat to you good sir, that looks amazing and I want it
aWorkOfArt
aWorkOfArt's Avatar
45 lbs. Unsprung Weight Reduction is a huge difference! Great stuff bro!
Old 05-28-15, 02:21 PM
jkeifer3
jkeifer3's Avatar
Nothing special. I got some carbon fiber license plate frames and my new personalized plates came in.
Old 05-28-15, 02:29 PM
johnnyreb
johnnyreb's Avatar
What are we talking $$$ wise? Looks Good, but i'll probably just end up painting the Brembos (i ended up trying the Brakeing Procedure & they don't seem to be squealing as much as they were & to me it doesn't get much better than Brembos, but Dang 45 lbs. is 45 lbs.! Would Definitely be a Great Start to cutting some Weight
Old 05-28-15, 05:57 PM
Ryanmcd
Ryanmcd's Avatar
Brembo / Alcon are the best made, anything other then that is a downgrade.
LRCSALES (10-01-18)
Old 05-28-15, 10:31 PM
RCFormante
Supercharged!
RCFormante's Avatar
I’m sorry to hear that, hopefully that doesn’t happen to me!
Thanks! Yea 45lbs. of rotational weight is about 135lbs. static weight savings so it’s going to be a huge difference for this car!
Where did you get your carbon license plate frame at? I’m trying to find one that has a nice quality build to it.
It is priced at $14k-$15k, priced similar to other carbon ceramic brake systems out there.
Old 05-29-15, 05:32 AM
4TehNguyen
4TehNguyen's Avatar
new lightweight wheels would reduce rotational mass a lot as well
Old 05-29-15, 11:59 AM
jkeifer3
jkeifer3's Avatar
Default Here's a link to the carbon fiber plate frame
http://www.licenseplateframes.com/ta...FdiRHwodsyAARQ
The plate frames are of really nice quality and the mounting technique is unique!
Old 05-29-15, 12:42 PM
RCFormante
Supercharged!
RCFormante's Avatar
Nice! I might have to order one. Do you have any pictures of it on your car?
Old 05-30-15, 09:15 AM
jkeifer3
jkeifer3's Avatar
Here's a quick iPhoto..... The pic has no detail on the carbon fiber but it matches the interior's carbon trim quite well.
Old 05-30-15, 03:31 PM
johnnyreb
johnnyreb's Avatar
RCF500, you just spent 14-15k for a set of Brakes when you just got a Brand New Car with Brembro Brakes on it! you've got Waaaaay toooooo Much MONEY! Lol! WOW!
Old 05-31-15, 03:30 AM
jkeifer3
jkeifer3's Avatar
Those brakes better be: 1) zero dust, 2) zero squeal, 3) 100mph to zero on a dime
Old 05-31-15, 06:22 PM
RCFormante
Supercharged!
RCFormante's Avatar
Lol...I just got the mod bug, that's all.
Nice! I went ahead and bought one, thanks!
As for the Carbon Brake System, I know it's not worth the cost, but I believe it is one of the biggest mods you can do right now in terms of performance until someone gets forced induction working correctly and safely on this car, so I'm all for it!
Quick Reply: What Have You Done To Your RC F Today?
