NX - 1st Gen (2015-2021)
DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport
Old 12-12-14, 04:19 PM
cb80923
cb80923's Avatar
Default DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport
I changed out the Super Hot, Super Dim, fuse lights in the rear end of the NX for LED strip lights. Here is my DIY incase you want to do something similar.
I somehow skipped using the number 3, but it is in order...
-cb
Attached Thumbnails DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-1.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-2.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-3.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-4.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-5.png
Ghiggs662 (02-16-23)
Old 12-12-14, 04:21 PM
cb80923
cb80923's Avatar
Default part 2
(cont'd) DIY LED Trunk Light upgrade
Attached Thumbnails DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-6.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-7.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-8.png   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-9.png
Old 12-12-14, 04:39 PM
hypervish
hypervish's Avatar
Nice! First mod on the new NX!
Old 12-12-14, 07:23 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Almost literally a Day and Night difference. Nice work.
Old 12-12-14, 08:53 PM
AndyL
AndyL's Avatar
That is a great mod. I usually replace the factor bulb with some bright LED bulbs that I carefully consider in terms of angle of illumination, lumens and wattage. Your solution would provide the trunk with a more uniform and wider illumination :thumb up:
Old 12-13-14, 05:34 AM
rogerh00
rogerh00's Avatar
Does doing a mod like this void your warranty if you have an electrical problem?
Old 12-13-14, 07:30 AM
philwojo
philwojo's Avatar
Love that MOD, I think it will be something I do if we ever get our NX (darn wait times right now). I did a quick search for those lights, here is a direct link to them that at least works for now to make it easier for others:
http://www.amazon.com/Vehicle-Automobile-Driving-Decorative-Reversing/dp/B00KGPALB2 http://www.amazon.com/Vehicle-Automobile-Driving-Decorative-Reversing/dp/B00KGPALB2
Would love to see one more pic that mimics what you had in your first "dark" picture with all the same stuff in the same areas. I would like to see how these new lights work with the soft sided storage case in there, meaning how it lights up the area still.
Thanks for posting this great upgrade!!
Phil
Old 12-13-14, 12:08 PM
adamsmith
adamsmith's Avatar
I bet that if Lexus discovers this, they will not apply the warranty... It's money they save. My suggestion is to un mount it in case of problems.
Old 12-13-14, 05:38 PM
cb80923
cb80923's Avatar
Here is a retake of the After Shot - with everything back in the same place as the original lighting picture as much as I can get it. (both are iphone 6 plus pics for what it is worth).
Attached Thumbnails DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-img_0578.jpg   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-image623.jpg
Old 12-13-14, 09:39 PM
philwojo
philwojo's Avatar
Perfect, I still love it and really appreciate you doing that for me, what a great addition to the NX and so simple and cheap!! Enjoy your vehicle.
Phil
Old 12-16-14, 11:22 AM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default ............
Why not one of these to eliminate hacking into the panel??
http://www.ebay.com/itm/2x-42mm-8SMD-5050-LED-265-C5W-Canbus-Error-Free-White-Feston-Bulb-VOLKSWAGEN-/201055717770?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2ecfdac98a
Old 12-16-14, 11:43 AM
cb80923
cb80923's Avatar
I did think about something like this muyself, but decided to go with a flat Panel Light / Light strip.
42mm is way too long - would not fit. The little fuse bulb in the cargo/trunk area is small... I am guessing it was maybe 3/4 of an inch. I will measure it when I get home / check the bulb designator in the owners manual.
Old 12-16-14, 01:00 PM
5gears-IS
Great Deal Guru
5gears-IS's Avatar
Default .......................
Feston LED's are available in may sizes just measure the bulb from the OEM application and buy an LED feston that matches.
Old 12-16-14, 04:16 PM
cb80923
cb80923's Avatar
Looks like about a 28mm festoon for the trunk/cargo area lights. If you can find 28mm festoon LEDs bright enough to decently light up the trunk area - good on ya.
Attached Thumbnails DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-img_0624.jpg   DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport-image1.jpg
Old 01-21-15, 01:26 PM
Leelyss
Leelyss's Avatar
Great idea! just ordered the LED strips!
Thank you for sharing!
Quick Reply: DIY: LED Trunk Light Upgrade - 2015 NX 200T F-Sport
