anyone know the stock wheel weights?
Old 11-12-14, 02:42 PM
scamsel
scamsel's Avatar
Default anyone know the stock wheel weights?
anyone know if the stock wheels weight changed over the different rim design years?
Old 11-12-14, 05:50 PM
KOKISF
KOKISF's Avatar
Ill have to look it up , i know i weighted them And even posted it , dont remember well but you would be impressed they aré not as heavy as they look
Old 11-12-14, 05:55 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
I have the '08 wheels in my garage right now. They are bare. Just need a scale...
Old 11-12-14, 10:04 PM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Did a search and this was the only thread I came up with:
https://www.clublexus.com/forums/is-...el-weight.html
Lou
Old 11-13-14, 12:36 PM
Gymkata
Gymkata's Avatar
I've never weighed them myself, but I've seen posted multiple times that the 08/09 wheels weigh 23 lbs front and 27 lbs rear
Old 11-13-14, 07:09 PM
ISFPOWER
ISFPOWER's Avatar
Originally Posted by Gymkata
I've never weight them myself, but I've seen posted multiple times that the 08/09 wheels weight 23 lbs front and 27 lbs rear
this is actually correct. i remember weighing mine in at 23 lbs front and 27.xx in rear but not enough to be rounded to 28.
Old 11-14-14, 07:59 AM
NSXGuy
NSXGuy's Avatar
2012-14 wheels a bit heavier since the are 1/2" wider?
Old 11-14-14, 01:21 PM
scamsel
scamsel's Avatar
yeah this was basically my question, and i couldn't find any good info through searching
Old 02-27-17, 12:51 PM
Lextasy4
Lextasy4's Avatar
Been searching and still can't find the answer to this question. Anyone have specs for '12-'14?
Old 02-27-17, 02:39 PM
cha7Li3
cha7Li3's Avatar
ISFPOWER is pretty close when comparing them to this thread
https://www.clublexus.com/forums/is-...rt-sa-67r.html
"29 lbs for the rear and 23 lbs for the front" for the 2008-2010 models
Old 02-28-17, 06:20 AM
Lextasy4
Lextasy4's Avatar
Thanks but I am asking about the wider '12-'14 wheels.
Old 08-02-17, 08:56 PM
Vitveet
Vitveet's Avatar
Anyone ever get an answer to this question?!
V.
Old 08-04-17, 05:54 AM
Helo58
Helo58's Avatar
It is a hassle, but if anyone who has a 12-14 has just purchased new tires, you can take the tire/wheel off of the car, weigh it and then post your results. A decent bathroom scale should do the trick. Then look up the spec weights for the tires and subtract out the tire weight. Not perfect, but it should get you close. Don't forget to consider wheel weights, TPMS sensors, etc. if they apply in your case.
Old 08-06-17, 01:43 AM
gc86
gc86's Avatar
I removed my wheels the other day (2012) and they shocked me at how light they felt. The fronts are wrapped in 235/40/19 PSS at the moment which isn't exactly the lightest tire either. I was curious so I searched and found this thread but alas I don't think the information is out there on the forum. I'll weigh them the next chance I get. I'm installing brand new PSS in a little bit so it should be pretty accurate.
Old 08-06-17, 07:09 PM
tas02
tas02's Avatar
My stock wheel weights changed when they balanced my new tires.
Oh, weight...
Re3iRtH
08-04-14 02:31 PM
Lmood
IS F (2008-2014)
08-18-13 05:40 AM
clare2808
ES - 5th Gen (2007-2012)
07-22-10 01:33 PM
jns350
11-28-08 01:25 PM
Quick Reply: anyone know the stock wheel weights?
