ES300 1996 Keyless programming???
I need programming instructions for my 1996 ES300 Keyless entry. I have them for a1 998 model but they don't work soooo, I think they are different. Someone suggested ebay but the link is obsolete.
Thanks,
Thanks,
This subject has been discussed many times before. If you do a search for "keyless entry" or "keyless remote", you'll find some decent feedback. But to save you guys the trouble, I've done the research, and all I can really tell you is that you'll have to get a new chip and key from the dealership to actively operate with the existing ECU chip in your car. It is possible to program the '97+ ES on your own, but not for the earlier models.
Hope this helps.
Hope this helps.
ES300 Key programming
LexusK8,
Thank you for your response. Can you clarify something for me. Are you saying that a key cannot be re-programmed to another vehicle; ie. the chip is matched to the key? Or perhaps you are implying the key can only be programmed once? My local Lexus dealer said they could make me a new key and program it for $350 to my existing system. So unless the key can only be programmed once then this would tend to imply that there is a procedure for reprogramming keys to existing systems... Am I way off base here??
Re: ES300 Key programming
Originally posted by skelley
LexusK8,
LexusK8,
Yes from my understanding, once the key is correctly programmed in the car, it cannot be transferrable to another car. You have to bring your car in to get a new chip and key, period.
'96 Keyless Entry
The last post is INcorrect. The key can be programmed to ANY other '96 Lexus with the same frequency I.D. system. Up to four keys can be programmed and then the next key (5th) erases the first key etc I have programmed many used keys to my Lexus keyless system. Of course the key will does not work, only the entry part . Later models may indeed be different
Regards, Don
Regards, Don
Re: '96 Keyless Entry
Regards, Don
Regards, Don
-- Mods: I sincerely apologize for posting this rant up instead of by PM, but I think it's important to take note of each other's little faults in logic before confusion erupts.
I purchased my '96 Lexus with a working key and 2nd key with a bad 'corroded' chip. I purchased a correct freq. used key on ebay for about 10 bucks. It was a pretty easy job to take the chip out of the used key and replace the corroded chip in th working key. I then programmed it to the car with no problem. I then hought it would be nice if I had an extra opener with key and of course I would have to get that from a Lexus dealer for big bucks. Instead, I bought a couple of used keys with the correct freq. and programmed them as well. I then cut off the key part and use the upper part to open the doors etc. I have a Chrysler minivan and their opener (ckicker) does not have the key attached so this is the same kind of deal. It give you an extra opener for a very small price. Many cars have a separate opener without a kety attached. It just depends how much money you are willing to spend. Lexus compatable key blanks without remotes cost about $2.00 wholesale. Getting them cut is not a big problem, just a few phone calls to fine a locksmith that has the proper cutting machine.
Don
Don
ok i am truley a non beliver
i have the service manuals
talked to every dealer in 97 before this forum came about and
i am very interested to find out how you found the frequency
and then programmed it also please do inform everyone as this contradicts everything ever known
what you speak of is very possible with the seperate key fob on the 97 and newer ones
but the keys are mated to the chip
The frequency ID s stamped on the upper part of the key just above the small screw. It is an FCC ID. My '96 key ID is HYQWDT-B I found the programming instructions on this forum.
Regards, Don
Regards, Don
Keyless programming for 1996 ES300
KEYLESS ENTRY ROGRAMMING INSTRUCTIONS FOR MY 1996 ES300.
These instructions seem a bit complicated but I assure you that they worked for me and many others. You may have to do it a couple of times 'cause it gets a little confusing.
Sit in the drivers seat and LOCK all doors
Unlock and open the drivers door.
Using the MANUAL lock switch,on the drivers door, unlock the door 5 times
Close the door.
Open the door.
MANUALLY lock and unlock thye drivers door 5 times. If this sequence fails to work you can try the power switch.
Insert the key into the ignition and turn it to the 'ON' position.
Turn the key to OFF and remove key.
The drivers door will now lock and unlock itselt one time.
Press and hold the 'LOCK' button on the key fob for at least 1 second.
Close the drivers door.
Open the drivers door.
Press and hold the 'LOCK' button on the key fob for at least one second.
Press and hold the 'LOCK' button on the key fob. The door will lock.
Press and hold the 'LOCK' button on the key fob. The door will UNlock.
You should be all set.
Close the door.
Open the door.
Thanks for 1996 ES300 Key programming instructions
Tigerpilot,
Thanks for the programming instructions. Wow! I guess Toyota didn't want you (or your kid) to inadvertently reprogram your key.
I am waiting for my key off EBay. I didn't get as good a deal as you did but it was considerably less than the dealer. According to the Ebay write-up the frequency matches.
To the unbelieving user with the 97 Lexus. You probably do not have the key with the the little button on the side so your programming instructions would not be the same. There are other forum articles that cover 97 and up.
To the other mis-informed user. While your intention to help was appreciated, the Lexus forum users would be much better served if you didn't respond on topics beyond your personal expertice. Your information from the dealer may have been accurately conveyed but in my experience most dealers are in the business to make money (lots of money at the Lexus dealer) and have absolutely no problem withholding money-saving information to the auto owners.
I hope my comments were not offensive. I appreciate this forum as a recent Lexus owner and I look forward to many more pleasant information exchanges.
