Build Threads Details on Club Lexus SC owner vehicles
Tj's 95 SC300 1jz Swap
Old 08-21-13, 04:28 PM
tjmhillz
tjmhillz's Avatar
Default Tj's 95 SC300 1jz Swap
Time for me to start a build thread. I just picked up them Gem from a CL member today. Very clean car and well maintained. 95 5sp with 118k. I use to have a turbo IS but that ended up getting totaled 2 weeks ago Still deciding on which direction i want to go with the SC either 1j or 2j swap. Most likely i will be starting it over the winter time so for now i will be enjoy the sc as is. I plan on swapping the wheels from the IS to the SC for the time. Below you will see a few pics of how my IS sat and was and then my new gem. Enjoy.
went from this
engine bay. It pretty much stayed the same since 09 besides rebuilding the bottom end lol.
To this
to this
Heres my new gem
Old 08-21-13, 04:40 PM
kez
kez's Avatar
Hey now look at that SC. Damn man sorry bout the IS. Now go get ur swap or build a big boy NA-T
Old 08-21-13, 04:45 PM
tjmhillz
tjmhillz's Avatar
Updated 6/26/16 parts List. Pics of said parts start on post #82
Engine
1jzgte non vvti
Borg Warner SX256 7670 .83ar
DM Down Pipe
DM Manifold( had to modify the mani to make it fit)
Tial Wastegate 44mm
Tial Q BOV
USDM MK4 550cc injectors
Walboro 455 fuel pump
Aeromotive FPR
ARP Headstuds
OEM full gasket set
Mishimoto FMIC 24x12x3
Oem Supra TT Motor Mounts
Dual Magnaflow Mufflers( part number 14834) custom 3" piping
DM ps line
MKIV ps res
AEM 3.5 bar Map Sensor
AEM 150psi Fuel Sensor
AEM Wideband Sensor
Electronics
Aem Infinity 6 Standalone
Greddy Boost Gauge
Aem Wideband
Turbo smart Boost Controller
tweaked patch harness (wideband, IAT, Map, boost, fuel)
Old 08-21-13, 04:53 PM
JesLet
JesLet's Avatar
Go with 2JZGTE swap
Old 08-21-13, 05:21 PM
tjmhillz
tjmhillz's Avatar
Yea ive been following alot of peoples build threads lately and thats what im leaning towards. Im going to make sure though when i do it im going to do it right the first time haha.
Old 08-21-13, 06:09 PM
JesLet
JesLet's Avatar
I notice you only have 118K on that engine. I would NA-T and I think its cost effective.
Reason why I went 2JZGTE is because I had 235K on mine. I believe I can still NA-T that thing but I want a fresh motor.
Old 08-21-13, 06:39 PM
tjmhillz
tjmhillz's Avatar
Yea im going to do a compression test and make sure everything is good and i may just go na-t again and do a different set up.
Old 08-21-13, 07:10 PM
JesLet
JesLet's Avatar
New headgasket and ARP headstuds and you are good.
Old 08-21-13, 07:57 PM
tjmhillz
tjmhillz's Avatar
True. I had that done to my IS. Thinking i may just go NA-T again since it was a good set up and less hassle. My set up on my is was the following
Turbonectics Turbo 60-1 .58a/r
Turbonectics Manifold
Turbonectics 35mm Wastegate
550cc Rc Injectors Low Impedance
GTE Internals
GTE Headgasket
Arp Headstuds
Walboro fuel pump 255
Aem FIC
BamBamSC (06-24-19)
Old 08-21-13, 08:24 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Let the fun begin. I say just turbo your current setup, if the numbers come back good. Just do the head gasket and the studs, like mentioned before.
Old 08-22-13, 06:08 AM
99SC42
gte & na-t
99SC42's Avatar
Welcom to the Club my friend I can't wait till we get together!!
Either setup will work , do What you want /like etc...You are going the one driving the car, You are going to be the one that will be popping that hood ..
I got both setups and they are both money pits lol, I have more $$$$ in my na-t than my gte.
Pull the valve cover of that engine and look at the condition of the valve train, i boosted my SC at 160k miles now it has 170k on it.
You have to look at both setups to see the pros and cons and $$$ to mod each setup.
Whatever you decide to do, gte or na-t am IN!
Old 08-22-13, 07:48 AM
tjmhillz
tjmhillz's Avatar
Thanks Omar. Yea ive been doing alot of research on 1jz and 2jz. Like i mentioned not looking for alot a hp and this will be my daily. Shooting for around the 350-400hp range. This is what i was thinking.
1jz swap
motor, ecu, harness - 900-1000
fmic- 200
Tial bov- 200
NA-T
turbo- 400
mani- 150
injectors- 300
ems - 1000
fmic- 100
Tial bov- 250
Tial Wg- 250
misc- 300
Im not really on a budget because i will be taking my time with the build and will be buying parts over the winter time. But im thinking i could just go with the 1j swap and rock the twins until they blow then upgrade. Also those prices i just did an estimate. Im pretty sure i can find some of those parts used as well. Also whats a good year and car to get the 1j from. I heard that the vvti ones are the ones you want to stay away from is that correct?
Old 08-22-13, 08:34 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
That is correct. At the same time a matter of opinion. Thats up to you. I say the non vvti cause you can add cams and what not. The vvti has more power in stock form but the wiring is a bit more tedious. Just do the research and it will help you decide on which route you need to go and for your budget. If you decide on the 1jz it will be the cheapest and parts are still available today if needed. Good luck man.
Old 08-22-13, 09:54 AM
tjmhillz
tjmhillz's Avatar
Thanks. like i said i plan on doing this over the winter time so i have plenty of time to figure out what i want to do and which route. i have a decent amount of money saved up right now and also money left over from insurance so im set lol. So many decisions though haha. Ill just start buying universal parts now like bov,wg, fmic now since i can use that for any of the setups i go with.
Old 08-22-13, 10:53 AM
99SC42
gte & na-t
99SC42's Avatar
Then buy a 2jzgte and get an R154 do it once and be done with, Or 1jzgte with r154 .
There is nothing wrong with the vvti, people don't like to mess with it because it's not PNP makes decent power since it comes single Turbo from factory.
To make 350-400 on stock twins and reliable , you will more than likely have to go 2jzgte.
I would go single straight up , and do it while the engine is out ..
Quick Reply: Tj's 95 SC300 1jz Swap
