Apexi Smart Accel Throttle Controller Problem
Old 01-10-13, 07:13 AM
JDMV8
JDMV8's Avatar
Default Apexi Smart Accel Throttle Controller Problem
Hi guys.
I recently got an apexi throttle controller.
After I installed it, it keeps blinking the "white" light and doesn't work; it just blinks from start up of the car til you turn it off.
If anyone has experience with this unit, please provide any info!
I did not tap or splice the wire (which I assume) goes to the reverse lights.
Thanks
Old 01-10-13, 08:20 AM
zapa
zapa's Avatar
DId you properly calibrate it? I know you have to hold it down the top or bottom button and then push the mash the pedal into floor and press the other button. Im not sure the order.
Hope that helps
Old 01-10-13, 08:27 AM
JDMV8
JDMV8's Avatar
Yes that is definitely my problem--the calibration.
However the instructions are in Japanese, and no info online.
I will eventually call apexi when they open up...but as of now, no luck with calibration.
Thank you very much Zapa for identifying the problem!
Old 01-10-13, 09:17 AM
clifftrail
clifftrail's Avatar
I'll scan and post them up when I get home if you don't already have them by then.
Old 01-10-13, 10:19 AM
JDMV8
JDMV8's Avatar
Thanks a lot.
I don't know why I only have Japanese instructions...
Old 01-10-13, 10:31 AM
ISFPOWER
ISFPOWER's Avatar
i got only japanese instructions as well. i installed with ith the proper harness and also didnt use the reverse . i also removed the negative terminal on the battery and i never had a problem with the unit
if its blinking, i believe it means it isnt working. maybe try to reintall.
Old 01-10-13, 03:45 PM
JDMV8
JDMV8's Avatar
Hey guys. I resolved the problem.
Called up Apexi HQ, and they sent me English calibration instructions.
Very simple, hold bottom button, then depress accelerator and hold top button
Then turn off car and hold both buttons simultaneously.
Thanks for the help.
Old 01-10-13, 07:11 PM
zapa
zapa's Avatar
I knew it was something like that but was not sure the exact order. Glad you got it worked out
Old 01-11-13, 02:47 AM
clifftrail
clifftrail's Avatar
Good to hear but just in case someone is looking again in the future I've added them.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 01-12-13, 12:48 AM
JDMV8
JDMV8's Avatar
^thank you clifftrail!
Good reference.
Old 02-19-14, 03:35 PM
ct200
ct200's Avatar
very helpful!! had the same problem with mine that just installed today… I'm going down stairs to try and calibrate!!
Old 02-19-14, 04:31 PM
ct200
ct200's Avatar
it worked!!
Old 02-19-14, 06:38 PM
clarionguy
clarionguy's Avatar
Does this module work well vs Sport mode?
Old 02-19-14, 07:26 PM
ISFpat
ISFpat's Avatar
Its not meant to be a substitute but to further enhance the throttle control in sport mode.
Old 10-24-15, 01:17 AM
RickHansen
RickHansen's Avatar
does it make your takeoff a bit more aggressive, or a lot?
Quick Reply: Apexi Smart Accel Throttle Controller Problem
