Old 12-16-14, 10:54 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
Fog Light Bulb Replacement Question
Old 06-26-12, 09:00 AM
Outrage
Outrage's Avatar
Default Fog Light Bulb Replacement Question
Has anyone successfully replaced the fog light bulbs on a GS 350 (non-F Sport)? The instructions found on the manual concerning the correct movement of the fender liner, once the associated clips are removed, are vague. Any insight would be appreciated.
Old 06-26-12, 09:14 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Remove 2-3 bolts on the bottom bumper area under Fog Light... Pop out lower bumper liner downward..
Access achieved within 1-2 mins..
~ Joe Z
Old 06-26-12, 11:43 AM
mrpartsman
mrpartsman's Avatar
yep , u can do it the way Joe says it, or u take the 2 fender clips out and one screw out from the bottom and roll the cover out, and ur in.its a H11 bulb by the way if u want to know. good luck.
Old 06-26-12, 12:51 PM
rominl
exclusive matchup
rominl's Avatar
i think joe's method is much easier, especially you don't need to turn the wheels to gain access
Old 06-28-12, 05:22 AM
nkohlimd
nkohlimd's Avatar
Default Change foglight color
Quick question-I noticed that the headlight color and the foglight color is different-the headlights are more pure white and the fog lights are more of a yellow color. Are the fog lights more effective in that color? I was thinking of changing the fog lights to match the headlights-if so, what color (k) would I use? Also, is it as easy as just getting the appropriate bulb in the appropriate color or do I need to get a kit with ballasts? Any input and help would be much appreciated-thanks so much.
Old 06-28-12, 07:17 AM
jtrue28
jtrue28's Avatar
Headlights are HID (4300K), whereas the fog lights are halogen. You can try to buy 4300K halogen bulbs, but it still will not look the same. Your best bet is to do an HID conversion kit on the fog lights, using 4300K bulbs. Good luck.
Old 06-28-12, 07:42 AM
natnut
natnut's Avatar
http://www.newton.dep.anl.gov/askasc...9/phy99xx4.htm
Short answer : yellow doesn't have any advantage in fog.
Old 06-28-12, 08:18 AM
jj14
jj14's Avatar
yep... what makes a fog light a fog light is the fact that it should have a wide beam pattern up to 120 degrees, and it should have a sharp cut off at the top.
We can see in foggy roads by lighting up the road that is under the fog. The fog light should illiuminate as little of the fog as possible (to avoid glare). Regular headlights will simply produce glare by bouncing off the water droplets in the fog.
The color of the light (yellow vs white) really doesn't do anything.
Old 06-28-12, 09:01 AM
nkohlimd
nkohlimd's Avatar
Default Thanks for the tips and education
Awesomeposts-thanks so much-love the forum!
Old 08-01-12, 05:27 PM
Bill_GS3
Bill_GS3's Avatar
What is a better option? Using 4.3K LEDs or HID kit?
One of the guys I work with says to change the headlight bulbs to 6K and match with 6K LEDS.
Old 09-13-12, 01:26 PM
Bill_GS3
Bill_GS3's Avatar
Default 5K HID and LED fog lights
Will get a better picture tonight, this was in the service drive at work.
Old 09-13-12, 05:09 PM
sydtoosic
sydtoosic's Avatar
nice pic BGS3, the fogs look brighter.
Old 09-14-12, 06:08 AM
Bill_GS3
Bill_GS3's Avatar
Thanks, yeah they are. I used V-Leds 5K 28LED 13w H11 setups, probably should have used the 7.5w
Old 09-14-12, 07:24 AM
jj14
jj14's Avatar
Wow - these looks really nice!
Besides the bulbs (are these the right ones?), what else did you need to get?
Old 09-14-12, 10:53 AM
Bill_GS3
Bill_GS3's Avatar
Yeah, those are the ones. I almost would sugest the 7.5w, I think these might be bordering too bright.
I did some research, the factory halogens are 50w which is equvilant to 5w LED.
Quick Reply: Fog Light Bulb Replacement Question
