Done the 60k mile Valve Clearance Inspection yet?
Old 09-27-11, 11:49 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
Default Done the 60k mile Valve Clearance Inspection yet?
Just curious who has done this (if anyone), and I don't mean taken it to a shop, I mean actually done it.
I'm getting closer to the magic mark and just reviewed what I'll need to do on TIS. It's not pretty or simple if you have to make an adjustment - the cams have to come out according to Lexus. It really makes me appreciate the simplicity of adjusting bucket and shim valves.
FWIW, shims are available from 2.00mm to 2.80 mm in 0.02mm increments.
Everything else about this looks like a million others I've done, but strangely enough, they could have designed this set up with threaded posts and locknuts pretty easily. They chose valve stem cap shims. Only Yamaha knows why...
Also FWIW, if no one else has done it, I'll do my best to document it and post it here for the brave to follow.
Last but not least by any means, I'm hoping it will be just like my Supra - everything in spec (I've checked the Supra three times and they've never changed in 150k miles!)
**2022 Update**
I've done this three times now, read the thread for details, but if you're mostly interested in what parts you'll need for this, here you go:
Fully validated parts list for anyone who plans to do this. If you are under 100k miles, most of this won't be necessary. If you are over 100k miles, you should replace everything on this list.
11193-38030 = 8 - Gasket Spark Plug Tube
23224-38010 = 2 - Gasket Fuel Pump Spacer
23915-46011 = 2 - Insulator Fuel Pump
23279-74010 = 4 - Gasket Fuel Pressure (Pulsation Damper)
11229-38030 = 2 - Gasket Cylinder Head Cover No. 3 (Valve cover oil filter)
11159-0P010 = 2 - Gasket Camshaft Bearing Cap Oil Hole No. 1
11159-0S010 = 2 - Gasket Camshaft Bearing Cap Oil Hole No. 2
90301-A0029 = 4 - O Ring (Oil Drain Pipe)
11213-38060 = 1 - Gasket Cylinder Head Cover No. 1 RH
11214-38040 = 1 - Gasket Cylinder Head Cover No. 2 LH
90301-09028 = 1 - Oil Tube O-Ring (dipstick tube)
90210-08045 = 6 - Washer, Seal
15678-46020 = 2 - Filter (for the exhaust cam oil control valve)
You should also be replacing your spark plugs if you're doing this at the 60k mile interval recommended for the 2008 IS F.
Tools you will want to have on hand:
22mm open end crowfoot for the fuel pulsation dampers on the HPFPs.
21mm flare nut wrench or preferably socket for the HPFP's fuel connection to the rail.
16mm sparkplug socket with locking extension
Very narrow flat blade screwdriver to release the connector block from the top of the ECM box
Last edited by lobuxracer; 12-31-22 at 03:39 PM. Reason: Updated with parts list and tools list
valkISF (03-18-24)
Popular Reply
01-26-17, 10:40 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I also damaged a couple of wiring harness "protectors" in the process. Finding the part numbers for these can be really challenging. Many techs do not bother to replace the broken parts even at the dealership because it's easier just to tape it up and move along.
While you are ordering all that stuff, get the sparkplugs too. They're due at the same interval as the lash inspection on the '08.
Old 09-28-11, 10:38 AM
TURBOCARS
TURBOCARS's Avatar
I'm at 61,000 miles and would like to do this as well.
I haven't touched my supra since it's a 3.4L with no miles yet haha. Still under construction.
Old 09-28-11, 10:52 AM
stick
stick's Avatar
lobux, are you doing this as preventative maintenance or to document the ticking noise many people have or something else?
Old 09-28-11, 11:39 AM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
^^^^On Page 53 of my "Warranty & Services Guide" It lists the services to be scheduled at 72 months or 60,000 miles. "Inspect Engine Valve Clearance" is one of them.
Lou
Old 09-28-11, 11:49 AM
DCoolBeans
DCoolBeans's Avatar
How much would the dealer charge for something like this?
Old 09-28-11, 04:53 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
No ticking noises here. I can fix worn guides on my own anyway, and I'd port the head while I was at it.
Lou
Exactly why I'm asking! Lou always seems to get it right...
Looking at the procedure, I'm betting this would be at least 6 hours flat rate. One of the alarming things is they tell you to remove the high pressure fuel pump, and one of the connections is a flare nut to a fitting on the pump. There is a very strict warning telling the tech if the fitting on the pump turns (the directions say you MUST hold it with a second wrench), you must replace the pump (!?!?!) so it looks a bit on the daunting side for the inexperienced.
Also, if you have to adjust anything add another 6 hours to the job because the cams have to come out and be properly installed again. So I'm betting the quote for this will be pretty alarming. I have no intention of asking how much, I'm just going to do it.
Old 09-28-11, 07:03 PM
avgj0F
avgj0F's Avatar
Dealer did my left side to fix engine ticking noises and it didn't solve the problem. Anyway, with shim parts and labors, the warranty repairs came out to almost $2K. I'm sure out of warranty work would cost much more.
Old 09-29-11, 06:00 AM
sickISF
sickISF's Avatar
This is where an extended warranty may be useful.
Old 09-29-11, 12:26 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Not really. Powertrain warranty is to 72k miles. This is maintenance anyway, so they're going to expect you to pay for it regardless. The only way to get them to pay for this is to complain about the valve noises if you have them. If you don't you're pretty much going to pay no matter what.
While it's not exactly cheap, it's still not as expensive or frequent as the GTR transmission service.
Old 11-03-11, 09:43 AM
spddemon
spddemon's Avatar
Has anyone else done the valve clearance check and spark plugs ? On the scheduled 60k maintenance plugs are to be changed, just wondering if you guys are following this. Does anyone see a problem with following mileage over time when it comes to maintenance?
Old 11-03-11, 09:56 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I'm going to check the valves and replace the plugs when I get to 60k. I have less than two thousand to go right now. My expectation is the valves will all be within specification. If they are on the loose side, I'll likely leave them alone because a loose valve is a happy valve. If any are tight, then I'll be removing the cams (much to my dismay) to make adjustments. I might also see if there is an effective way to change the shims without removing the cams.
Having this done at the dealer is going to be ~$500 just for the check. Adjustment will be significantly more.
If I run into any issues to make me believe everyone should be checking this, I'll post up what I find.
Old 11-03-11, 11:00 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
^^ Thanks Lance!!!!
OEM Spark Plug Part number is: 90919-01249 .... Seems to be widely used in the Lexus line up.. and a bit pricey!!
Denso listed Part Number is: FK20HBR11
How do you feel about the coil packs life cycle?
~ Joe Z
Old 11-05-11, 11:32 PM
CCJ22
CCJ22's Avatar
Lance thanks for this thread. Watching this closely
Old 11-06-11, 06:31 AM
DCoolBeans
DCoolBeans's Avatar
Cool, thx Lance!
Old 11-06-11, 06:56 AM
tenspeed
tenspeed's Avatar
From the RockAuto site (listed under ignition):
AUTOLITE Part # XP5325 Xtreme Performance; OE Style; Gap .044 - $4.99
DENSO Part # 3453 {#FKB20H} Iridium Long Life Plug - $12.40
NGK Part # 6858 {#DFH6B11A} Laser Iridium Spark Plug - $17.72
ACDELCO Part # 41835 {#19239702} PLATINUM PLUG - $5.59
DENSO Part # 3473 {#FK20HBR11} - Iridium Long-Life - $12.40
Quick Reply: Done the 60k mile Valve Clearance Inspection yet?
