Door Ajar Light Won't Go Off
Old 06-04-11, 01:28 PM
shvc1991
shvc1991's Avatar
Default Door Ajar Light Won't Go Off
So yesterday, I received my LEDs for the puddle lights in the doors from V-LEDs and I went to put them in. Only one of the four LEDs light up; that is the rear passenger side door. The other three stayed lit for a second and then went out. I then removed the LEDs and put the OEM bulbs back in and those won't light up either. I then noticed that even with all the doors and trunk shut and tight, the door ajar light remains lit and I cannot lock the doors with the key fob; I just get a long beep until I hit the unlock button. The dome light will remain on when in auto and the lights in the front foot wells remain on as well.
When I open the rear doors, the reading light for each corresponding door comes on and shuts off when the doors are closed.
I took the car to Lexus today and they couldn't diagnose the problem. Anyone have any ideas? Please and thanks.
Old 06-04-11, 03:05 PM
shvc1991
shvc1991's Avatar
Anybody?
It kind of sucks that I have to pull the fuse every time I leave the car parked to make sure the battery doesn't get drained.
Old 06-04-11, 04:36 PM
Enigmatic
Enigmatic's Avatar
What you most likely are experiencing is a problem with the door switches. The electronics running from the ECU to the switches has probably gone bad. This would account for why your car doesn't actually know that your doors are shut when in fact they are.
You can read a bit more about this problem at the following links:
https://www.clublexus.com/forums/gs-...p-problem.html
https://www.clublexus.com/forums/gs-...or-issues.html
Old 06-04-11, 09:26 PM
shvc1991
shvc1991's Avatar
Thank you for the response and the links; I've searched and read through those before posting this thread. A Lexus technician tested my switches and said they are all good to go but still cannot source out the problem. I'm so stumped on this. Are the switches and ECU built into the door lock actuators or that a completely different assembly?
Old 06-04-11, 10:51 PM
Enigmatic
Enigmatic's Avatar
That's strange. If it is indeed not the problem then I still think it has something to do with the electronics that deal with the doors to your steering console and them being closed or not.
Old 06-04-11, 11:00 PM
shvc1991
shvc1991's Avatar
I was just outside messing with the door latch and I found that the front passenger door handle needs noticeably more force to get the door to open. I also manually closed the latch mechanism and pull the door handle and it did not release until the 4th time I attempted to make it release. I think the latch may be the problem since the switch is built into that assembly?
Old 01-02-16, 04:27 PM
D9Self
D9Self's Avatar
Default Door dash light on?
Originally Posted by shvc1991
Anybody?
Did you ever figure out how to fix this problem?
Old 06-28-16, 03:31 PM
D9Self
D9Self's Avatar
yes I did, I had to replace the door module, it was blown.
Old 10-25-16, 03:38 PM
Club Lexus Editor
CL Editor
Club Lexus Editor's Avatar
Default How-To Tuesday
Good subject for How-To Tuesday....
https://www.clublexus.com/how-tos/a/...-on-off-363507
Old 10-30-16, 08:45 PM
burteboy
burteboy's Avatar
Thats a simple diagnosis. Lexus should have solve the problem by connecting thetech stream and looking at the data. It would identify the problem door . Knowing that the trace the door switch circuit. It could be a somple door switch or ground.
Old 05-16-19, 01:35 PM
blkstealthpaid4
blkstealthpaid4's Avatar
Is this door module on the driver's side?
Old 07-31-20, 09:08 AM
ph0bolus
ph0bolus's Avatar
Does anyone have the part number for the door module, or point me in the direction of where it is? My Door open light won't turn off either.
Erikzalm
04-27-16 11:40 AM
TexFinn
09-30-13 05:30 AM
MDSC
08-29-11 12:59 PM
mpcguru
Lighting
07-27-04 12:25 PM
spxChrome
02-22-03 04:29 PM
Quick Reply: Door Ajar Light Won't Go Off
