Anyones dash rattling and popping really loud???
I bought this car three months ago and the dash is driving me nuts, it creeks and pops really loudly over uneven surfaces, does anybody have this problem, and how can it be resolved thxx
It's a common ISx50 issue and LEXUS dealers fix this under warranty.
There is a TSB for that in Lexus knowledge database.
Bad thing is that they have to dismantle the dashboard to fix it.
Jamming a few pieces of black eraser in between the windshield and the dash goes a long way into tightening it up so it doesn't move and cause the clips to make noise. It's cheap and easy, seems to work and it keeps your dash in one piece.
Sent mine back to dealer about a month back and they fixed it by installing a new part (rubber clips) to hold the dash. Didn't hear anymore rattle thereafter. Might want to check with your dealer.
Where are the dash clips located that someone mentioned? these noises are no where near as bad as the squeaks on my 4runner were--those ended up being the metal bar that does across the dash for support!
I know mine is not there, i hear the same click/pops even when i have the whole vent section removed. It seems to be from off to 6 inches to the passenger side from center.
You will see the location of the clips.
If the car is still under warranty everything can be fixed by Lexus dealer free of charge with the new parts Lexus has produced.
There is also a new rubber seal that goes to the the middle of the dash on the top of heat exchanger.
Cars made after 2008 don't have these problems because Lexus upgraded the quality of the clips (Rubber ones).
Just look the TSB pdf in the beggining.
