Power Antenna works in reverse - free 6pack to whoever figures this one out!
Old 11-17-10, 08:09 PM
ric4044
ric4044's Avatar
Default Power Antenna works in reverse - free 6pack to whoever figures this one out!
I have a 93SC400 - system was all stock with the wiring harness in all locations fully intact. My power antenna works in reverse. When the radio power is off or the car turned off, it rises up. When the am/fm is selected it goes down; comes back up when selecting cd. I just changed out the old stock Pioneer headunit b/c it kept turning on/off for an aftermarket headunit, wired everything up as said on the discussion boards and the darn thing works in reverse again... All wires on the antenna side in the trunk are intact. Can someone help me on this one?
Side note - When taking apart the rear deck I found my subwoofer still there, but it has never worked. I made the mod for the rca adapter as in the forums and it still doesn't work. I know we splice the wires near the sub amp to keep power to the sub with the antenna up or down; would this crazy azz antenna affect the sub woofer working or is my sub amp fried?
Old 11-17-10, 08:52 PM
FireCode
FireCode's Avatar
Easiest way to find out if your sub amp is working is just to get a little light bulb meter. Check power coming in to it and then check the outlet side. As far as the antenna, I have two ideas..
1. Dont worry anymore about messing with the stock antenna wiring. Run a wire from the deck antenna out directly to the antenna. Make sure it has a power source/tap too. This way, you bypass any old SC wires.
2. Get a different antenna off an SC and see what happens with that one.
Old 11-17-10, 09:04 PM
wagomaniac
wagomaniac's Avatar
so are you planning on shipping that six pack?
Old 11-17-10, 11:26 PM
ric4044
ric4044's Avatar
I can ship the 6pack overnight mail or fedex...wait, that's illegal...or I can paypal some 6pack money....but thanks for the idea. I will test the amp tomorrow to see if its getting power. I might play around with the antenna for a day or two, but will probably just unplug the dammmm thing...kinda annoying to have an antenna slowly rising up as you're getting out of the car.
Old 11-18-10, 08:53 AM
imDementeD
imDementeD's Avatar
idk for sure and it might be a stupid idea..but if you can...look to see if the power is backwards? if that makes since..like flip the connector around and replug it in..see if it changes? .. if it works..i dont drink beer but i do like me some vodka+redbull haha
Old 11-18-10, 09:25 AM
aznxenon
aznxenon's Avatar
I found your solution. S2000 antenna. Send me some 4Loko kthxbai.
Old 12-07-16, 04:08 AM
kevinfab
kevinfab's Avatar
Wink Motor cover issue
Motor cover have two magnetic one is n one is s, if cover install reverse then rotation is reverse
Old 12-07-16, 09:58 AM
DA51
DA51's Avatar
I had the same problem with an electric window regulator. I pulled the wires from the connector and reversed them. The motor does not know up or down. The antenna for FM is in the back window. The electric antenna is for AM. I spent a year trying different antennas-cheap and OEM (salvage) and ended up with a box of parts.
Attached Thumbnails Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2777.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2779.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2781.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2744.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2747.jpg
Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2749.jpg
Old 12-07-16, 12:29 PM
t2d2
t2d2's Avatar
I don't think that's correct. It's a diversity antenna setup, with both working in conjunction to strengthen the signal. As far as I know, both inputs work on either signal (I'm pretty sure I tested that with the power antenna disconnected.)
Old 12-07-16, 06:39 PM
tsmith1315
tsmith1315's Avatar
Indeed.
ric4044: My factory antenna had been replaced when I got the car, so I can't have a look for myself. Is there a relay box attached to the antenna that switches polarity to the motor?
Old 12-08-16, 12:11 PM
ThomasGS4
ThomasGS4's Avatar
I finally fixed my antenna the other day...the sensor was so covered in old, nasty grease, it didn't know when to stop pulling down and would break every antenna you tried to install. Cleaned it out completely and regreased all of the gears and now it works perfectly.
Old 12-09-16, 09:55 PM
DA51
DA51's Avatar
My 92 antenna inner gear that pulled the antenna mast had worn out, so I found a 94 antenna with a broken top (tube). I found out many changes had occurred with the antenna. If you want to replace the antenna assembly, you have to get the same exact year. A fixed antenna is the way to go. Some folks have used a new antenna cable, too. That's what I need. Time to pull the interior apart, again.
Attached Thumbnails Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2751.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2767.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2769.jpg   Power Antenna works in reverse - free 6pack to whoever figures this one out!-img_2747.jpg
xtra
06-11-09 02:16 PM
pablo93
GS - 1st Gen (1993-1997)
07-18-07 06:09 AM
Kyle Harty
12
06-05-03 11:23 AM
1loudlex
12
04-28-03 07:43 PM
Quick Reply: Power Antenna works in reverse - free 6pack to whoever figures this one out!
