How to get rid of the "hyper flash" from installing LED turn signal?
Old 07-26-10, 08:29 PM
GS4_Fiend
GS4_Fiend's Avatar
Default How to get rid of the "hyper flash" from installing LED turn signal?
Don't know have this been cover yet but has anyone used an "Electronic Flasher Relay" instead of a load resistor? I think this alternative way would work much better than having a "load resistor" which runs very hot. Any comments?
BTW, the LEDS that are gonna be put on my car would be the front turn signals, the LED mirror covers, and the LED blue angle mirrors.
Old 07-26-10, 08:52 PM
sam430
sam430's Avatar
I will look it up. you can either buy a relay from vled and others or you can solder two resistor to the existing relay. I would do the later because you get to keep the armed confirmation of the alarm system.
https://www.clublexus.com/forums/gs-...r-relay-6.html
Old 07-26-10, 09:01 PM
Mr Jokster
Mr Jokster's Avatar
I believe VLED is out of stock and/or isnt carrying the relays anymore.... I found these when I did my searching a month ago or so:
Flasher Relay
You want the one on the bottom pn# CF18-08. I wouldnt do the load resistor, they cost more and will eventually stop working thats what happened to me.
Old 07-26-10, 09:15 PM
GS4_Fiend
GS4_Fiend's Avatar
Wow thanks guys! I wonder if we are gonna have any hyper flashing problems with the 01-05 LED mirror covers
Old 07-26-10, 10:02 PM
GS4_Fiend
GS4_Fiend's Avatar
Flasher Relay
After installing the relay you from the link you posted, did you have any problems with the emergency lights, or losing the visual flash when locking and unlocking with the keys?
Old 07-26-10, 10:23 PM
Baliztik
Baliztik's Avatar
If we buy one of these flasher relays how would we go about installing them?
Old 07-26-10, 10:44 PM
sam430
sam430's Avatar
The relay is on the driver side kick panel... There are threads with pictures of the actual location. The relay mod is in the sc section, same relay as gs. The link I provided above leads to the link of how to mod the current relay.
Old 07-27-10, 12:12 AM
Mr Jokster
Mr Jokster's Avatar
I'm actually barley gonna order it, however I believe I read that it does stop the visual flash from keyless entry. As for install, as said above, its under driver side panel up on top. Yes the links have step by step how to locate and remove. Its kinda clamped in, but easy to remove.
Old 07-27-10, 08:58 AM
GS4_Fiend
GS4_Fiend's Avatar
I need to find a good source that sells the non-problem ones. Keep us posted Jokster
Really hating that orange look, it makes a nice looking headlights look bad.
Old 07-27-10, 09:23 AM
GS4_Fiend
GS4_Fiend's Avatar
Checked on eBay looks like V-LEDS,warden_jp, and others are saling the same product.
http://cgi.ebay.com/ebaymotors/Lexus...Q5fAccessories
i think that is for the 2 LED Electronic Flasher Relay. Don't know if the one that Jokster is getting is the same or not.
Old 08-11-16, 10:47 PM
anniverse
anniverse's Avatar
Default Fast blinking flasher
I have a 1999 Lexus GS300 and I changed all flasher lamps to LEDS.
Then I had Fast Blinking.
The reason is that the LEDS draw very little CURRENT and the Current sensor LOOP in the flasher thinks of a bad lamp hence Hyper Flash.
Previously I had the same issue on my Toyota Sequoia 2005 and I took the Flasher unit out and replaced the Current sensing SHUNT Loop
with a 0.15 OHM 1 Watt Resistor. all the lights came back to normal flash.
I did a similar Resistor on my Lexus but it wont Blink at all. So I bought a bunch of resistors which were little Higher and little lower in value and
started experimenting. The one that worked the normal blink came out to be 0.1 OHM at 1 WATT.
I though I hit jackpot but then my Emergency flasher will not flash at all so I added another 0.1 OHM 1 Watt resistor in Parallel.
Everything works now as if it was with Normal lamps.
One other thing that I did not test was what will happen if one of the LEDS burns out----Well I am not going to give it another thought and will leave
it to someone ELSE as I am sure this Handsome LEDS will outlast my Lifetime
Old 08-14-16, 07:11 PM
Mr Jokster
Mr Jokster's Avatar
Just buy a relay, not sure why all the work when its all been done before.
Old 08-15-16, 07:48 AM
AmanO
AmanO's Avatar
....or buy LEDs that have the tech build in.
I have switchbacks in front and back and they neither flash fast nor trip the warning light.
Now my brake LEDs, on the other hand.....but I just read in another thread that it may be the 3rd light bulbs that are doing it. I have not kept those LED and may have put a 194 in by mistake.
Old 08-26-16, 12:16 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Check out the XD-11 11ohm LED Load resistors:
Available in: 3 ohm, 6 ohm, 11 ohm, and 7.5 ohm.
Steve
Old 08-26-16, 02:46 PM
bruceb58
bruceb58's Avatar
I am curious. Why do you guys even bother replacing the turn signal lights with LEDs?
Quick Reply: How to get rid of the "hyper flash" from installing LED turn signal?
