Tilt steering repair
Old 06-12-02, 07:54 PM
c_irie
c_irie's Avatar
Post Tilt steering repair
My power tilt came to a grinding halt yesterday ...the kind with a grrrnching sound anyway I looked on the forum since I remembered seeing a post on the subject before anyway I was able to repair the problem and took a couple of pictures since I could not find any procedures in the factory repair manual.
The first step is to remove the clam shell around the steering column which is held in place by 3 phillips screws, two on the bottom and one on the face which is pictured (you will have to turn the wheel 90 degreees to the right to remove the screw)
The following 4 users liked this post by c_irie:
BammBamm (05-13-23), CamFerazzi (05-03-21), goldsoarer (05-29-18), phil0909 (08-13-20)
Old 06-12-02, 08:30 PM
c_irie
c_irie's Avatar
Default cover plate
next remove the 3 screws that hold the cover plate in place and you will see the worm and worm wheel
the problem was that the worm wheel was not centered on the worm the only area of contact was the edges and it ground the edges and slipped therefore my fix was to place to washers behind the wheel and one on top (washers cost 0.27 each from lowes hardware) to center and maintain the wheel in the correct position put it all back together and voila it works great
The following 2 users liked this post by c_irie:
Old 06-12-02, 08:32 PM
c_irie
c_irie's Avatar
Default cover plate off
worm and worm wheel
Old 06-12-02, 08:34 PM
c_irie
c_irie's Avatar
Default wheel removed
this is the wheel which I removed using two paper clips with the tips bent.
Old 06-12-02, 08:37 PM
c_irie
c_irie's Avatar
this is the washer 0.27 from lowes I used two behind the wheel and one on top to maintain centering of the worm and worm wheel
Old 06-12-02, 08:38 PM
c_irie
c_irie's Avatar
reassembled and working like a charm !!
Old 06-12-02, 08:52 PM
ForNgoods
ForNgoods's Avatar
good job! personally i would have been way to lazy to do this job. it's a good thing for me my tilt steering hasn't gone out.
Old 06-12-02, 09:32 PM
Ryan
Ryan's Avatar
I don't have this problem but just wanted to say thanks for spending a few minutes and adding to our knowledge base. I may need it someday!
The following 3 users liked this post by Ryan:
boggie557 (08-19-18), CamFerazzi (05-03-21), phil0909 (03-28-21)
Old 06-12-02, 09:44 PM
strongsail
strongsail's Avatar
yeah, me neither, hope I never do! Makes me wonder, though - what would cause that little ring gear to get misaligned? The first couple pix don't show any evidence of anybody taking it apart before - no broken spacers were found inside the gearcase, I presume?
Yikes, have we discovered an actual assembly mistake in a Lexus?
BTW, good fix! The washers look like the ones that go in garden hoses, yesno?
Old 06-13-02, 04:16 AM
Keith13b
Keith13b's Avatar
Excellent write up. Thanks for the info. Geess, this SURRRRRRRRRRE would go good in a Tech article section......(cough), (cough). What do you moderators think?
Old 06-13-02, 11:38 AM
c_irie
c_irie's Avatar
I'm not sure if the washers are the type used in garden hoses, they are made of a compressed fibrous material. The main thing I was looking for was to make sure it would fit around the spindle.
What all would be involved in developing the tech/repair/how-to section a lot us have digital cameras and I have no problem with taking pictures of any and all repairs/modifications that are done in order to help out other members, but this has been suggested before
Old 06-13-02, 12:06 PM
lex400sc
lex400sc's Avatar
C_ire, awesome fix! It would have cost you hundreds of dollars at the dealership because their mentality over there is: If it's broke, don't fix it, replace it. For 27 cents, you saved big time!
Old 06-19-03, 08:26 PM
duclex
duclex's Avatar
Default steering column not lowering
C_irie, thanks a bunch on the article!!
I recently have this reoccurring problem and tonight I was able to do exactly what your article demostrated!! Some reason the blue plastic gear does wobble, and when it does, it doesn't allow the mechanical lowering of the steering column. Slipping occurs. I'm glad the gear teeth were not stripped.
Again, thanks. If it happens in the future, I'll just manually lower the column and disconnect the power option. I figure it'll last several years w/o any more problems.
Duc
Old 06-19-03, 09:08 PM
nextlevelcoupe
nextlevelcoupe's Avatar
extremely useful info...good job!!
Old 06-20-03, 12:23 AM
SC400Dude
SC400Dude's Avatar
Dude, this is soooo helpful to me now. My tilt steering problem surfaced a few months ago for me. It'll give me something to do now. Thanks C_irie~!
Quick Reply: Tilt steering repair
