LS 460 door hinges defective--replaced twice
Old 03-08-10, 10:59 AM
bird1028
bird1028's Avatar
Default LS 460 door hinges defective--replaced twice
My 2007 SWB LS 460 with 22,000 miles on it has required replacement of the driver's side door hinges twice and the passenger front door hinges once. This is obviously of concern, since the original fix on the driver's side failed again within 8 months. The car has light single driver use.
My dealer says that Lexus "knows about" the problem. Has anybody else had such an experience?
Old 03-08-10, 11:11 AM
MikeE12345
MikeE12345's Avatar
I haven't seen any postings about this problem.
Old 03-08-10, 12:39 PM
bird1028
bird1028's Avatar
Neither have I, nor could I find anything online.
It strikes me as a real problem that will likely have occurred in other LS460s (which is why I made the inquiry); door hinges are built to be very robust even on the most basic vehicles and almost never fail--to have three hinge failures on a car of this extremely high build quality seems odd.
Old 03-08-10, 01:00 PM
jmcraney
jmcraney's Avatar
You guys up in IL swing on your doors? Or, are you pdrr98 too?
Check this out: https://www.clublexus.com/forums/5105224-post1.html
Old 03-08-10, 04:55 PM
g26
g26's Avatar
Default Had my hinges replaced...
I had to replace the passenger side door hinges on my 2007 LS460L. The door would not close smoothly and had to be be shoved into the closing position for the power door closer to activate.
Important caveat though -- I bought this car CPO so it might have had some undocumented work on it from the previous owner.
The repairs were fixed under the CPO warranty and the door is now fine.
Old 03-09-10, 06:57 PM
bird1028
bird1028's Avatar
jmcraney: No we don't swing on the doors--it's just cold, that's all. No I'm not pdrr98, but his problem is mine exactly.
G26: I have no doubt that this is a more common problem than we know. My dealer stated that Lexus changed door hinges after this problem was seen on the 2007 models. I'll bet that this is not the last time my hinges go bad!
Old 03-09-10, 07:36 PM
jmcraney
jmcraney's Avatar
bird1028,
Thank you for sharing your experience with us. The hinge thing is really disturbing to me. The wind noise, you fix it one time and it is gone forever. Sounds like the hinge is a perpetual problem. I normally keep cars for ten years but it may be time to bailout. Reckon it's that cold weather that's causing the hinges to fail? Yours was the first I had heard about and then a search showed only one other, pdrr98, both of you in IL, and now along comes g26 and he seems to be in FL.
Old 12-16-10, 07:10 AM
Shibumi1
Shibumi1's Avatar
the dealer i got the car from said it was & $80 part..so i may just switch it out.. as the car is outta factory warranty.(an i'm waiting on a call from the extended warranty company)Anyone ever heard of Route 66 warranty?
i guess the previous owner never brought it to the dealer... bcuz it seems there a few TSB's that need to be addressed... well i guess i'll see what "Route" i'll take...
Old 12-18-10, 12:07 PM
Badboyz8
Badboyz8's Avatar
Default Door Hinges
Like, g26, I had the same problem. I rarely have passengers until one day I had to drive a friend back to school and was made aware of the difficulties in closing the front passenger door. Service had to order the hinge and had it done three weeks ago. When I called for an appointment was told about the recall so I lucked out and had both problems resolved at the same time. The recall work took 3 days, NYC, got a loaner for the weekend. Haven't really notice a difference. BTW-I have a CPO 07' LS 460L.
Happy Holidays.
Old 12-19-10, 01:08 AM
I8ABMR
I8ABMR's Avatar
WOW I have never heard of replacing the door hinges on any car period. They are usually designed to last for the normal service life of the car. I am surprised that this would need to be replaced on an LS460
Old 12-19-10, 02:03 PM
Shibumi1
Shibumi1's Avatar
its not the hinge itself.. you'll notice a black plastic piece that attaches to the b pillar and runs into the door..it adds tension to the door and gives u the rest point between 1/4,1/2 or full open.. the prob is that piece either needs adjustment to free the movement more or replacement due to defect...
Old 01-18-11, 04:23 PM
Shibumi1
Shibumi1's Avatar
retraction.. replaced the door check (the piece i described earlier) problem persists. ordered hinges. they'll be in tomorrow. will let u know by they end of the week
Old 01-19-11, 06:15 PM
Shibumi1
Shibumi1's Avatar
success swapped out hinges door works fine.. parts mgr said they've never seen a bad hinge since the original sc400.. so it had to be something else.... but no.. i watched my bodyshop tech 35 mins a few bolts an wow....my goddaughter can open the door w/o using her legs.... hope it lasts..
Old 03-06-11, 11:34 AM
Jjmmd
Jjmmd's Avatar
Default Defective door hinges
I
My ls460l has defective door hinges first appearing at 40000 milesnon passenger side and 60000miles on driver side. My dealer states Toyota is not responsiblenfornthis ...a car innate difficultynopning the doors is useless
Caution::Toyota does not stand by
Yntheir warranty!!!!! I have seen multiple blogs on the Internet concerning thisnproblem and no resolution from lxusbon problem!!!!!!!
I will buy a me cedes or BMW before buying Lexus again,,
Old 03-06-11, 12:55 PM
Nospinzone
Nospinzone's Avatar
Oh that'll be an improvement.
Quick Reply: LS 460 door hinges defective--replaced twice
