Solution to Dual/Single Stage airbags
Old 09-02-09, 09:44 PM
5t341th
5t341th's Avatar
Default Solution to Dual/Single Stage airbags
So wassup fellas. We all know that woodgrain steering wheels are the ish. its just so troublesome for 98-00 guys to swap because they are afraid of messing around with the airbag system. Well worry no more. I came up with a solution that could be useful. lets begine
so you bought urself a woodgrain lexus steering wheel but u dont wanna use ur ugly old 98-00 airbag. go ahead and purchase a 01+ airbag from any car year lexus that matches and take apart the explosive unit/bomb that blows up the airbag in a collsion.
turn to the back of the airbag unit and u will see it
there are 4 8mm nuts that hold on the unit. take them off
heres the dual stage bomb
see the difference?
take your single stage and bolt it back up
BAM! heres your end product. a nice woodgrain steering wheel with the nice 01+ design airbag. you can now look fly and no more worries
i am going to install the steering wheel tomorrow. if anyone is interested, i will make a write-up for it
enjoy!
Old 09-03-09, 12:38 AM
Mr Jokster
Mr Jokster's Avatar
I dont get it? Its well known that 98-00 GS need to buy the 01+ bag for the wood wheel. Has nothing to do with it being ugly, its has to do with the fact that the 98-01 bag doesnt fit the 01+ GS wood wheel. 2 different bags. BTW, how much did the 01+ bag cost from the dealer?
Old 09-03-09, 01:06 AM
5t341th
5t341th's Avatar
the 98-00 bag does fit but it doesnt fit quite right. i got the bag off a wrecking yard so it wasnt much. 200 bones
Old 09-03-09, 05:09 AM
KiPod
KiPod's Avatar
It will work if the holes are the same distance apart. Be careful because there are two different sizes. I think its like 2.75" & 3" or something like that. I did the same thing and mentioned it here https://www.clublexus.com/forums/2ge...ta-airbag.html
Again, if you do this make sure you measure the distance between the bolt holes. There are two different styles of single stage bags with two different measurements between the bolt holes.
989x (03-24-20)
Old 09-03-09, 12:31 PM
Mr Jokster
Mr Jokster's Avatar
wow you actually found an '01+ GS in the junk yard! man, I need to go check MY local yards!
Old 09-03-09, 02:18 PM
5t341th
5t341th's Avatar
Again, if you do this make sure you measure the distance between the bolt holes. There are two different styles of single stage bags with rwo different measurements between the bolt holes.
i took a look at my 2000 airbag and the bomb unit on there fits perfectly with my dual stage airbag. seems like its great way for people that upgrade to not worry about looking for 01-03 rx300 bags. i looked at it and they seem to be the same sizes
bomb unit from my 2000 gs
bomb unit from 01 rx300
they were easily swap-able so its a good solution for others since 98-00 airbag looks ugly on the 01+ wheels
final product looks tight now
Old 09-03-09, 02:37 PM
sakataj
sakataj's Avatar
good job man....and also kipod on doing this awhile ago. steering wheel looks good in your car sir although is it just me or is the bag more sun faded than the steering wheel leather?
Old 09-03-09, 02:40 PM
5t341th
5t341th's Avatar
well yea, the leather on the wheel is very shiny compared to the airbag. maybe i should take some armorall stuff and clean the airbag with it. might make it match
if anyone wants to have a go at this, i do have a black/wood steering wheel for sale in the FS section
Old 09-04-09, 06:00 AM
KiPod
KiPod's Avatar
This is one of the easiest ways to do the swap without having to find an over priced RX airbag. Just please make sure you check the measurements between each hole for the mounting studs. I have worked with over a dozen different airbags for the GS and trust me, there are different sizes. Some will look different but will still work others look the same but are off by 1/4" or so. I included a picture of one 98-00 GS airbag that is different. You have to check what you have first to see if it will even bolt up to the RX airbag. See the difference in shape and size. I just dont want someone buying a dual stage, taking everything apart, and finding out it won't work. You know, measure twice, mod once.
Attached Thumbnails Solution to Dual/Single Stage airbags-single-big.jpg
Old 09-04-09, 01:17 PM
sakataj
sakataj's Avatar
i know i been eyeballing it
Old 09-29-09, 09:43 PM
KingNasGS4
KingNasGS4's Avatar
so wait. this is a conversion from a dual stage airbag to single stage.... right?
Old 09-29-09, 10:10 PM
5t341th
5t341th's Avatar
yes
msg123
Old 09-29-09, 11:27 PM
4play4dr
4play4dr's Avatar
where were u able to find the gray wood grain?
Old 09-30-09, 12:32 AM
5t341th
5t341th's Avatar
its not grey. its tan colored.
Old 09-30-09, 01:31 AM
AlphaJZS
AlphaJZS's Avatar
a lot of ebay steering wheels will say gray in the description but are actually tan in color. Pictures are really deceiving when you take them close up, and if you're color blind even worse. lol.
Btw does everyone have the volume buttons on the left side of their steering wheel? I have them since I'm an 01 430, but I've always wondered if you didn't have them can you buy the buttons and plug them into an existing connector inside the steering column? just curious....
Quick Reply: Solution to Dual/Single Stage airbags
