Foglight fuse blew?
Old 06-28-09, 07:19 PM
Phiber
Phiber's Avatar
Exclamation Foglight fuse blew?
I had my HID fogs on my headlights for a couple month. It was a HID 6000k kit. Today I noticed that both of them is off when I intentionally turn it on. I try to turn it on and off in the car but no help for both side. I even put on my stock ones and it still wouldn't turn on. Does anyone know what the possible problem is? I am guessing the fog light fuse blew?
Old 06-28-09, 07:41 PM
vuiskool
vuiskool's Avatar
Most likely a fuse blew. Foglight fuse for my old maxima was under the hood, might be the same for you.
Old 06-28-09, 07:47 PM
Tchan1
Tchan1's Avatar
That sounds like the foglight fuse, because that has happened to me before. The fuse box is on the driver side under the hood (Right where you add washer fluid). You would need to buy the fuse from Lexus, because it's those smaller kind which I can't find at a local car store.
Old 06-28-09, 08:31 PM
Phiber
Phiber's Avatar
I checked and it seem like it is not the fuse problem. Any other possibility? I am bringing to the dealership most likely..
Old 06-28-09, 09:41 PM
vuiskool
vuiskool's Avatar
You mean you swapped a working fuse in place of what was in the foglight one?
Old 06-28-09, 09:48 PM
Phiber
Phiber's Avatar
no, I took it out to see if it was blown or not. from what I remember it is 10 in the engine compartment.
Old 06-28-09, 10:40 PM
is350drive
is350drive's Avatar
yeah that happened to me. i believe its a 10. well i just put one of the replacement one, i think it was a 25 or something, since the hids are stronger than the normal ones i guess it takes out the fuse faster. (dont know if its true). well its been about 3 months and they are running perfect and strong.
Old 06-29-09, 04:59 PM
xclusivx
xclusivx's Avatar
Phiber,
Were you able to resolve your issue?
I'm having the same problem with my HID fogs. I checked the 15a fuse in the driver's side fuse box, but the fuse still looks good. My HID fogs are connected via a wiring harness with fuse and relay wired inline. I replaced both the fuse and relay, but it still isn't working. I also made sure it was properly grounded.
Any suggestions on what else to check?
Old 06-29-09, 05:01 PM
Phiber
Phiber's Avatar
Originally Posted by xclusivx
Phiber,
I am planning to just bring it to the dealership. I am putting it back to stock before bringing it in..
Old 02-26-13, 04:23 PM
Litcroco
Litcroco's Avatar
Is there an update on the issue cause I'm having the issue. I also check the fuse and it looks fine.
Old 04-02-13, 06:50 PM
levie
levie's Avatar
bump, currently having the EXACT same issue.
Old 01-19-14, 04:58 PM
TheVille
TheVille's Avatar
Bump! Having same problem please help!!!
Old 01-20-14, 06:12 PM
TheVille
TheVille's Avatar
bump!
Anyone solve this problem?
Old 01-21-14, 08:56 PM
smokyis350
smokyis350's Avatar
Just had to replace the fuse.
Old 01-21-14, 11:03 PM
whitebeast
whitebeast's Avatar
i have HID on my foglight without wire harness relay and has no problem. If you are using harness with relay, you should check the fuse for relay as well. Most likely it's fuse. Make sure to check the small box with 4 fuses in there.
Hit me up if you guys in or near Orange county so i could help you guys out!!!!
Quick Reply: Foglight fuse blew?
