P1349 VVT System Malfunction (Bank 1b) blocked oil control valve filter
Old 01-09-09, 04:42 PM
Jason T
Jason T's Avatar
Default P1349 VVT System Malfunction (Bank 1b) blocked oil control valve filter
Vehicle Lexus GS300 / Aristo V300 JSZ161 2JZ-GTE 1997 114,000kms fault code P1349 B1 due to blocked oil control valve filter
Part required 15678-46020 2JZGTE..JZS161; 2JZGE..JZS160..5FC 1 $5.61
Remove filter and clean with compressed air / fuel / brake cleaner or similar screen should be clear
This filter is 100% blocked
VVTi Oil control valve filter location OCV
Size:  27.1 KBName:  OilControlValveFilter.jpg
Toyota originally introduced the VVT-i (Variable Valve Timing - intelligent) as a revolutionary design that increases engine torque and output while addressing environmental issues. By adjusting the intake valve opening timing according to the engine speed, more oxygen is supplied through the air intake valve as more fuel is injected into the combustion chamber. Power and torque is maximised due to larger scale combustion. This optimised fuel to air ratio ensures the air-fuel mixture is combusted more thoroughly.
The VVT-i portion of the system continuously varies intake valve timing throughout the rev range by hydraulically rotating the camshaft relative to its drive gear.
The following 2 users liked this post by Jason T:
n1ck (06-21-18), tiguy99 (02-06-17)
Old 01-10-09, 12:18 PM
BLAZE
BLAZE's Avatar
Welcome and good info, thanx
Old 01-10-09, 02:54 PM
FrankT
FrankT's Avatar
Thanks, this is great preventative maintenance and a good indication of how much sludge is in your motor.
Welcome
Old 01-10-09, 06:45 PM
timgs300
timgs300's Avatar
Default Thanks
Excellent Info!
Old 01-10-09, 09:58 PM
Jason T
Jason T's Avatar
Welcome
Should have been done at 100,000km service previous owner had all seals front and rear crank seals cambelt & water pump all done via Toyota dealer including engine clean out with sump off and this little NZ$ 5.61 filter was not changed
Old 01-11-09, 01:55 AM
JeffTsai
JeffTsai's Avatar
If all maintenance was done on time and good oil is used, that should not happen at all.
Scraape (11-24-17)
Old 02-23-09, 05:42 PM
dmsrated
dmsrated's Avatar
can you change/clean it without doing an oil change?
Old 02-23-09, 09:18 PM
ElitistK
ElitistK's Avatar
yes you can, but have a rag ready to catch about 2 oz of oil that will come out from the vvti bearing cap.
Old 02-24-09, 09:30 AM
sakataj
sakataj's Avatar
that thing is NASTY. looks like other owner didnt keep up good maintanance
Old 09-07-09, 04:45 PM
Sc300Noob
Sc300Noob's Avatar
Default m sc has p1349 code
I followed your directions my filter was clogged and I uncloged it. I'm waiting for the driving cycles to finish ill update when they are done. however what do I do next if the code comes back?
Old 09-07-09, 04:56 PM
MrExecutiv
MrExecutiv's Avatar
wow, an old thread back. lol. to answer your question, if the code is still there make sure you check if the timing is correct or check if the OCV is still good.
Old 11-01-09, 07:25 PM
TxLexus400
TxLexus400's Avatar
does anyone know where this filter is located on a gs400 (V8)? any info will definitely help as im having a p1349 code.
Old 11-01-09, 08:37 PM
LudeNsoL
LudeNsoL's Avatar
^^How exactly do I located this filter on a GS300? The diagram is kind of confusing me. LOL
Old 12-21-09, 03:43 PM
Champstar
Champstar's Avatar
how can i do this for my gs400?
i have that code aong with 6 other ones hopefully they are because of this
Old 12-21-09, 03:54 PM
JeffTsai
JeffTsai's Avatar
If it's really old I would just suggest you replace it instead of cleaning it. The filter housing is made of plastic and it might get brittle and break into pieces. Then those pieces might make it into the VVTi sysetm. They're only $5 a piece, so do what you will
Frankn (03-30-22)
Quick Reply: P1349 VVT System Malfunction (Bank 1b) blocked oil control valve filter
