Taillight removal/Replacement (need help!)
Old 01-13-02, 09:04 AM
SupraCoup3
SupraCoup3's Avatar
Default Taillight removal/Replacement (need help!)
If you guys read my previous post, I got rear ended, and hit on the rear quarter panel. My driver's side tail light is flashing very fast, (it's allso beat to crap -- LX470 bumpers are a bit high...)
So my question is:
Can 95 tail lights go on a 93? What will happen? I've heard of quickly flashing tail lights. Is there anyway to fix that with a modulator of some sort?
also, How do you remove the tail lights? Can someone with a repair manual post the instructions?
Old 01-13-02, 10:16 AM
old_s13
Guest
Posts: n/a
If you purchase another year tail lights for the SC, just be sure to get a new separate wiring harness - thats all.
If my notes are correct, 92-99 SC's use the same wiring harnesses.. its just the actual tail lights and bulb layouts differ.
- Mike / *****************
ps: The tail lights should be held on by several 10mm screws in the trunk. Sorry to hear about the accident dude..
Old 01-13-02, 12:25 PM
anthracitetarga
anthracitetarga's Avatar
to remove the taillights:
1. Take off the gray trunk paneling by removing those black plastic things. (just pull them out)
2. U should see 3 or 4 gold 10mm nuts and u need to remove them. 2 should be near the trunk locking mechanism and either 1 or 2 should be near the end of the taillight.
Hope this helps. IF it doesn't, do a search in the SC Forum under taillight, b/c im sure this removal process has been discussed before.
kdllx470 (05-15-22)
Old 01-13-02, 02:22 PM
SDSC300
SDSC300's Avatar
Attached Thumbnails Taillight removal/Replacement (need help!)-rear2.jpg
kdllx470 (05-15-22)
Old 01-13-02, 02:24 PM
SDSC300
SDSC300's Avatar
Attached Thumbnails Taillight removal/Replacement (need help!)-rearlight.jpg
Old 01-13-02, 05:28 PM
SupraCoup3
SupraCoup3's Avatar
sweet thanks guys. Thanks for all the help, I'll keep you posted (no pun intended)
mrmj2u
SC400 / 300 Classifieds
06-24-17 08:51 PM
acefalcon2
12-17-08 07:49 AM
Lettuce
08-22-03 12:31 PM
The_Hitman
05-19-03 11:06 AM
lex400sc
01-30-02 10:02 AM
Quick Reply: Taillight removal/Replacement (need help!)
