power tilt went south--stays in up position '00 LS
Old 07-24-07, 11:31 AM
jakemt
jakemt's Avatar
Default power tilt went south--stays in up position '00 LS
I have a '00 LS and this morning, noticed the power tilt is not working. I have the pre redesigned ls and the tsib have not been applied. What are my options? Is it an easy fix? Thanx..
Old 07-24-07, 12:35 PM
vredniykot
vredniykot's Avatar
is it copletely dead or does it make a grinding type of noise when you try to lower it?
if it's dead then it may be the motor or the switch
if it's grinding then it's the gears, relatively easy fix, search for school bus mod
edit: here it is https://www.clublexus.com/forums/performance-and-maintenance/49783-tilt-steering-repair.html
edit: nm, i see you posted there already
but just open it up and take a look-see
Old 07-24-07, 01:49 PM
Suneet
Suneet's Avatar
I think PureDrifter will confirm this, but the fix is the same. Go to home depot or Orchrad and get the garden hose washers.. thats what I used, they work excellent. Put one on both sides of the wheel. Power tilt works fine now.
Old 07-24-07, 03:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
il find the link after i get teh response to this question:
when u press the tilt buttons is there a grinding noise of any sort, if there is its an easy fix, if there isnt be prepared for a slightly $$ intensive hunt as the motor itself is prolly gone
Old 07-24-07, 07:32 PM
Kansas
Kansas's Avatar
Here are is the first of the three TSIB's on tilt/telescope issues for the early 2000 LS400 -- the later 2000 LS400's like mine had the redesigned motors installed at the factory.
File Type: pdf
Kansas
Kansas's Avatar
Here is the 2nd TSIB.
File Type: pdf
Old 07-24-07, 07:33 PM
Kansas
Kansas's Avatar
Here is the 3rd TSIB.
File Type: pdf
Old 07-25-07, 06:58 AM
jakemt
jakemt's Avatar
Default Fixed.... for now....
I took the car to various mechanics to check this problem out. Just to give you guys an idea of the incompetents and rip-offs out there, one mechanic said I need to replace the whole steering column for big $$buck$$. Another said the internal vertical motor is gone. A third said something about replacing wiring that will cost also big bucks. Finally the last guy jiggled with the up and down switch for awhile and that did the trick. He said apparently the contacts were the problem and now it works great! No charge. Boy, am I one happy camper!!
Old 03-22-17, 01:50 PM
garyd
garyd's Avatar
Default 2002 Ls430 tilt wheel stuck
Replaced tilt motor and worked great for two months, today opened car door and wheel was tilted all the way up and will not make a sound or move. Telescoping part works but car is hard to drive. I am wondering if it might untilt or move in some way while I am driving and cause accident. Anybody heard of this?
Old 03-22-17, 02:53 PM
winter4w
winter4w's Avatar
Is the car hot? My wheel won't tilt if it is hot inside. I'll have to let the AC run blast for 5-10 min then move it.
Old 03-23-17, 10:01 AM
mmm def
mmm def's Avatar
Any way to manually force the wheel into a more comfortable driving position and leave it?
Old 03-23-17, 10:40 AM
winter4w
winter4w's Avatar
If the motor still work a little like mine you could adjust it then unplug the motor so it wont move anymore.
Old 03-25-17, 03:27 AM
billydpowe
billydpowe's Avatar
IDENTIFY YOUR YEAR MODEL they are NOT all the same
90- 1997 are the same and simple to fix
1998 and up are super hard to work on and or repair
Old 09-18-18, 01:23 PM
dlcoffin
dlcoffin's Avatar
Default Awesome!
A new used car, and this happened just today. A half an hour fix, thanks to you guys! Knock on wood, nothing else major to break
Old 09-18-18, 01:26 PM
dlcoffin
dlcoffin's Avatar
Default Think so
i found when i removed the gear, i could manually turn the shaft to tilt the wheel up or down, and thought about it, leaving it as is, but it's to nice to have the wheel get our of my legs way when i get in and out of the car. So i fixed mine, nuff said.
Oliver Enterprises
10-18-18 08:22 AM
toRT LS430
12-10-13 04:11 AM
joeblo
06-09-11 06:23 PM
encore888
10-13-05 07:27 PM
Gojirra99
12-07-02 12:46 AM
Quick Reply: power tilt went south--stays in up position '00 LS
