DIY: Fuel System Upgrade *Fuel Return Line*
Old 06-06-07, 11:43 AM
JeffTsai
JeffTsai's Avatar
Default DIY: Fuel System Upgrade *Fuel Return Line*
Quick DIY. Not too detailed, but if you're at the point where you can do this then you don't really need that many details. Just a basic guideline of what to do.
Quick Summary:
For those of us running boost, you need to upgrade the fuel system. The stock fuel system is set up as a dead head system where the fuel pressure regulator is inside the gas tank. This prevents us from being able to increase fuel pressure on the onset of boost. Running a return fuel system allows you to increase the fuel pressure and install a high volume fuel system.
Remove intake manifold. Drill and tap the holes for the screws.
Removed ACIS butterfly valve. Good for NA cars, bad for FI. It's a flow restricton and noise maker.
Mount fuel pressure regulator and connect stainless lines.
Picture 2
Run fuel return lines from gas tank to the regulator.
Picture 2
Picture 3
More to come...how to modify the stock fuel pump unit and fuel rail to a return system. Also, how to install a Walbro high flow/pressure pump
Old 06-06-07, 11:44 AM
JeffTsai
JeffTsai's Avatar
Cut off stock injector clip harness and install new ones. Rewrapped everything cleanly with electrical tape and wiring loom.
Another Pic
Old 06-06-07, 11:49 AM
JeffTsai
JeffTsai's Avatar
Blank post...will be used for pictures when I update the thread later.
Old 06-06-07, 11:50 AM
JeffTsai
JeffTsai's Avatar
Blank post....
Old 06-06-07, 12:26 PM
GSoup
GSoup's Avatar
Haha.. Jeff I'm about to do this soon also.
Old 06-06-07, 01:49 PM
pingu
pingu's Avatar
Very nice. Looks like everything is running smooth.
Old 06-06-07, 06:12 PM
bighitbike
bighitbike's Avatar
Really nice DIY Jeff. What Injectors are you running?
Old 06-10-07, 05:59 PM
JeffTsai
JeffTsai's Avatar
Updated with more info...more to come tomorrow when I get everything up and running!
bighitbike: They're 440cc RC Engineering Injectors. I scored them for a pretty good deal. They're not HUGE, but they are big compared to the puny 270cc stock injectors
Old 06-10-07, 07:23 PM
GSoup
GSoup's Avatar
hey jeff, great job !!! Just a thought, if its possible can you add a parts list. I think it would make this the ultimate DIY.
Looking forward to your updates.
Old 06-10-07, 07:25 PM
LEXUS_KID
LEXUS_KID's Avatar
Very nice work there you good old DIY
Old 06-10-07, 08:20 PM
rayy
rayy's Avatar
DAMN... you do all the work on your car, yourself dont you?
Old 06-10-07, 10:06 PM
JeffTsai
JeffTsai's Avatar
Yep, my car has never been at a shop...well not really. I bought the car brand new around June 2005. It's been to the dealer twice for the two complimentary oil changes and never again since that lol. I do all the maintenance myself with the highest quality filters and synthetic fluids. All the modifications and work on the car is done by me in my garage at home(yes that includes all the suspension work and including the building of my custom turbo setup). I do bring the car to a shop occasionally, but thats only to get something welded since I don't have a welder. Hopefully I can get a TIG welder soon so I can do everything at home
Old 06-11-07, 05:57 AM
PRSUIT460
PRSUIT460's Avatar
I wish my car looked that clean underneath...
Old 04-25-09, 10:49 AM
tom steele
tom steele's Avatar
hey jeff what did you do at the gas tank to install the new pump did you take out the stock intank fuel filter i would love to see some pics i am at a stand still thinking i might just weld a new pickup and go with an external pump i am already going to use a inline fuel filter. because i really dont want to mess up the stock plastic pump and filter holder what did you do back there
Old 04-25-09, 11:49 AM
macd7919
macd7919's Avatar
The filter is attached to the pump. There is no need to go external pump unless you are planning on racing against Justin Humphreys. Inline fuel filter is up to the person though it's not really needed as any pump you use will have a filter on the pickup.
The assembly the pump and holder are attached to isn't plastic, it's metal. You can just run a Walbro pump(s) or a Denso pump(s) and you will have all the fuel you ever need. They are more or less a bolt up, very little fabrication needed to make them fit. The return line coming into the tank is self explanatory.
Quick Reply: DIY: Fuel System Upgrade *Fuel Return Line*
