how to install aftermarket radio in 2nd generation gs
Old 05-11-07, 01:28 PM
dusouth
dusouth's Avatar
Default how to install aftermarket radio in 2nd generation gs
this is for the pioneer system not the nak
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-wire-harness-small-.jpg
Old 05-11-07, 01:32 PM
dusouth
dusouth's Avatar
i used two harnesses in this install
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-cut-harness.jpg
Old 05-11-07, 01:38 PM
dusouth
dusouth's Avatar
you have to extend the wires on the harness to reach the glove box so you can make you your speaker connections
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-leads-from-amp-to-speakers-small-.jpg
Old 05-11-07, 01:46 PM
dusouth
dusouth's Avatar
black left rear (pos+)............yellow left rear (neg-)...........red right rear (pos+) .............white right rear (neg-) ................light green/red sub (neg-)...........light green/black sub (pos+)
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-front-spk-colors-small-.jpg
Old 05-11-07, 01:53 PM
dusouth
dusouth's Avatar
front right (pos+).... light green................front right (neg -)..............blue (not the blue with yellow line).............front left(pos+) ...pink..................front left(neg-)............purple
Old 05-11-07, 02:00 PM
dusouth
dusouth's Avatar
use the 6 pin connection to get power behind the radio and ground to the car. don't use the 10 pin harness
the RED ACC wire connects to the grey wire
the YELLOW 12V wire conncets with the blue wire with the yellow stripe
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-factory-radio-connection.jpg
Old 05-11-07, 02:04 PM
dusouth
dusouth's Avatar
this is my contrubution back to the cl fourm. i made this because some of the info i found on here didn't have pics of harness.
heres the finished product
Attached Thumbnails how to install aftermarket radio in 2nd generation gs-finsihed-small-.jpg
Old 05-13-07, 09:56 AM
GS3Tek
GS3Tek's Avatar
Appreciate the detailed write up and the model # dusouth
No more cutting the factory wires
That is a clean installation you have there!
Old 06-06-07, 02:26 PM
TomGS400
TomGS400's Avatar
Default what if I have a nav system in place?
this looks sweet. any idea how to do it while keeping the nav system?
Old 06-06-07, 08:37 PM
Daynja
Daynja's Avatar
Does the sub still work with this setup?
Old 07-25-07, 08:32 PM
AristoPra
AristoPra's Avatar
WOW, definitely a great write-up! ! ! but ditto on TomGS400's question. . .
Old 11-02-07, 07:16 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
do you have a pic of the vss wire and tell me where its located i need it now asap thanks
Old 11-02-07, 09:06 PM
dung0981
dung0981's Avatar
If i remembered correctly, its on the steering ECU( brown color under your steering wheel), The color is purple.
Old 11-02-07, 09:10 PM
dung0981
dung0981's Avatar
The way he did it, actually he just by pass the factory amp. hes just using the cable from the amp.( dont have to run the cable from the Nav to speaker).
Old 11-02-07, 09:25 PM
lexusondubs
dubsonlexus
can you get a pic of the actual wire and location ?? i will give you a set of cl stickers for your troubles !!!
Quick Reply: how to install aftermarket radio in 2nd generation gs
