DIY brake caliper paint write-up (with pics)
Old 04-14-07, 12:41 AM
GlobeCLK
GlobeCLK's Avatar
Default DIY brake caliper paint write-up (with pics)
Sup guys,
last weekend my good friend Ian and I painted my brake calipers. I got the Dupli-Color brush-on caliper paint kit, but in the end I didn't use the actual paint. I went with high-temp spray paint for better coverage. Since I needed to mask everything for the clear-coat anyways, the brush-paint doesn't seem all that practical.
I got some white LEXUS stickers from someone on ClubLexus before, and finally got the chance to use them.
Anyways, here are some of the pics. I started taking pics half way into the process, so missed the earlier parts of the DIY job.
Here's my friend Ian putting on the LEXUS sticker on the front.
Rear. As you can see, the paint is matte black. I needed clear to go over the stickers, so didn't want TOO MUCH shine.
My car jacked up on 4 jack stands.
Rear shot.
The front caliper after a few coats of clear.
The rear caliper after a few coats of clear.
Old 04-14-07, 12:43 AM
GlobeCLK
GlobeCLK's Avatar
Here are some finished shots. My car was not washed so no dirty car comments
I haven't taken any pics after smoked headlights, so I'll probably do a better photoshoot in a few weeks.
Old 04-14-07, 05:29 AM
lexusondubs
dubsonlexus
lexusondubs's Avatar
soo dirty LOL j/k looks very nice !! keep up the good work !!
Old 04-14-07, 06:04 AM
GWELEX
GWELEX's Avatar
Nice job!!! This is going to be my next mod. The rear brakes are beginning to give me that early warning sqeaking, so while there apart it's time to dress them up.
Old 04-14-07, 06:07 AM
Lexbox
Lexbox's Avatar
Paint the hats and mold the kit and your good.
Old 04-14-07, 06:14 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Looks good Ray, thank you for posting the DIY I'm a fan of the new(ish) wheels too
Old 04-14-07, 06:17 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Looks like you did a great job on that
Old 04-14-07, 07:17 AM
olddog
olddog's Avatar
nice job.
but where are you flying to with that rear wing
Old 04-14-07, 08:34 AM
BLUEV8DGS4
BLUEV8DGS4's Avatar
Thumbs up
Originally Posted by GlobeCLK
the GS is tight as **** man!
Old 04-14-07, 09:12 AM
MrG4Life
MrG4Life's Avatar
Job well done. The stickers makes it even better. I see you used some cardboard in your project. Is it fairly easy to do in terms of getting the right parts properly covered? Any tight spots to be worried about when doing this?
Old 04-14-07, 10:33 AM
GlobeCLK
GlobeCLK's Avatar
Thanks for all the comments guys.
The smaller/narrower parts of the calipers I had covered with masking tape paper, and the cardboards are used to cover the bigger areas, such as the rotors and the suspension behind the brakes.
There are 3 holes on the side of the front calipers, if you paint into them they will mark 3 spots on the rotor's edge. You might want to get those covered/stuffed with something. Other than that the masking job is straight-forward.
Old 04-14-07, 01:09 PM
AristoPra
AristoPra's Avatar
Default Nice! ! !
WOW! great job and thanks for the write-up and pics. . . btw, what clear coat did you use?
Old 04-14-07, 01:45 PM
2FiVE8
2FiVE8's Avatar
looks good, so i guess any high temp paint will work??? if thats the case then why do they sell the "caliper" specific paint??? i wonder whats the real difference
Old 04-14-07, 04:53 PM
GlobeCLK
GlobeCLK's Avatar
It's just a high-temperature clear enamel from PepBoys.
I would think that any high-temp paint will work. The key is being able to withstand high temperature that the brake generates. The paint that I used can withstand 1600 F I think.
I think that caliper specific paint is just regular high-temp enamel, except that they come in brighter colors such as red, yellow, and etc. Usually high-temp paint is just black or gray.
The kit I got was interesting because it is actually a paint-on kit, not a spray-on. This eliminates the need for masking. But I had stickers that needed clear coat anyways so I didn't go with the brush. The kit also comse with brake cleaners, so that's good.
Old 04-14-07, 07:08 PM
LexFather
Guest
Posts: n/a
Nice write-up, I painted mine a couple weeks ago and haven't done my write-up yet.
Love your car's look!
Quick Reply: DIY brake caliper paint write-up (with pics)
