alternator replacement how-to?
Old 03-17-07, 08:28 PM
alister
alister's Avatar
Default alternator replacement how-to?
I did a search for some reference material "just in case" without much luck. I found some info on lextreme but haven't went to compare. Does anyone have any other info? TIA!
ken
Old 03-17-07, 08:32 PM
GSteg
GSteg's Avatar
i'll try to post some thing from the lexus manual when I get home from school.
Old 03-17-07, 08:54 PM
alister
alister's Avatar
I appreciate it!
Old 03-18-07, 10:29 PM
GSteg
GSteg's Avatar
Sorry. I came home late last night and I fell asleep.
See attachment for the pdf file. Let me know if it helps. thanks.
File Type: pdf
GSteg
GSteg's Avatar
2nd file.......
File Type: pdf
Old 03-18-07, 10:30 PM
GSteg
GSteg's Avatar
3rd (last) file.....
File Type: pdf
Old 03-18-07, 10:31 PM
GSteg
GSteg's Avatar
download all three attachments.
Old 03-19-07, 12:59 AM
alister
alister's Avatar
Awesome. That is it. You the man, H!
Old 03-09-08, 09:59 AM
RX729
RX729's Avatar
thank you...
Old 12-30-08, 09:58 PM
VipDout
19x11.5 -51
VipDout's Avatar
Helpful but took me 20 mins to find something to wedge in the ps pump pulley ... other than that great help
just to make sure that part had to come out
Old 03-24-09, 10:57 AM
JoelGs
JoelGs's Avatar
this is very helpful hint DIY..but it could be challenging to do...
Old 04-18-09, 02:50 PM
aristo2369
aristo2369's Avatar
i changed the alternator yesterday and i tried to bolt the ground cable to the bolt the holds the alternator and its blowing the 120v fuse, Is the a set area to bolt the ground to the alternator so the fuse doesnt blow? please help. 3.99 a fuse is not cheap and i went thru 4 already... can i bolt it to something else on the car or a set place on the alternator?????HElp
i even downloaded the DYI above and still, im stuck!!!!!!
Old 04-18-09, 03:05 PM
GS4_Fiend
GS4_Fiend's Avatar
Sounds like you got a short in a circuit for it to blow the fuse.
Old 05-08-09, 08:46 AM
kit cat
kit cat's Avatar
would the SST thing to hold the pulley help at all?
did you find out what was causing this?
Old 08-27-09, 05:20 AM
kingkirby
kingkirby's Avatar
i took off the bolts and wires to the alternator (90 min) im newB. and then i couldnt find a hole big enuff to slide it out. so i yanked and cranked it out. it was frustrating. im going to napa today to get a new alternator. i think i might have trouble fitting it back in the hole i pulled it from. and also there was a leak dripping onto the alternator. i read up on it and some said it was the power steering fluid. will lucas power steering stop leak stop a leak in a hose?
Quick Reply: alternator replacement how-to?
